Old 09-04-2015, 06:59 PM   #617
steve99
Drives: FT86
Originally Posted by mcquarrieg View Post
i filled up the 2nd tank of e85 this morning and will do some more closed loop learning and take another log in a few days and resend. glad to know i'm on the safe side. so are guys seeing good afr's (12s) during high rpm wot with stock headers?
yes once maf scaling done and some load limit tweaks you should get mid to low 12 afr on e85 , ie its folowing whats in the open loop fuel table
Old 09-04-2015, 08:01 PM   #618
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
Do I understand correctly that maf scaling shouldn't be done on E85 but on gas instead?
RustySocket is offline   Reply With Quote
The Following User Says Thank You to RustySocket For This Useful Post:
JB86'd (09-04-2015)
Old 09-04-2015, 11:05 PM   #619
steve99
Drives: FT86
you can do it on E85 you just need a stable source of e85 while your scaling maf as if you e% keeps changing you will chase your tail trying to scale maf.
you could probably take the e85 maf scaling out of wayno,s tunes that he has posted up would be a good starting point.
as your e% changes the fuel trims will move up or down but should all go in same direction.
what you dont want is +10 ltft in some areas and -10 in others , your looking for consistency in values accross the rpm range.
bizintine (09-11-2015)
Old 09-11-2015, 05:10 AM   #620
bizintine
bizintine's Avatar
Drives: 2013 whiteout frs
Alright guys so I have been running the OFT Stg 2 EL E85 map for almost 500 miles now. Car is stock other than K&N drop in filter and Greddy Evo GT exhaust. I have been meaning to post some data logs and get some insight as to how everything is running. I am very new to all this and I only know as much as I have read on this forum. Any help is much appreciated!
First link contains two, WOT, 3rd gear pulls and also a cruising log. I set the parameters to check for knock (please correct me if I left any key ones out)
http://www.datazap.me/u/bizintine/kn...5?log=1&data=1
Second link also contains two, WOT, 3rd gear pulls + a cruising log. This time I set the parameters to monitor AFR
http://www.datazap.me/u/bizintine/af...5?log=1&data=1
bizintine is offline   Reply With Quote
Old 09-14-2015, 11:10 AM   #621
mcquarrieg
Drives: Whiteout FR-S "Irene"
I'll let steve99 answer, but from what little i know it looks decent (albeit a tad lean at redline).
mcquarrieg is offline   Reply With Quote
The Following User Says Thank You to mcquarrieg For This Useful Post:
bizintine (09-14-2015)
Old 09-14-2015, 11:13 AM   #622
mcquarrieg
@steve99 - here is the updated post (end of 2nd tank). i deleted a CEL (U0073 i think) and then started recording for the drive home. afr looks the same (i.e. mid/low 11s) while the command afr looks good (mid/low 12s). i tried doing higher gear pulls (4th and 5th), so couldn't get all the way to redline at times lol
http://www.datazap.me/u/mcquarrieg/l...=0&data=1-6-11
Old 09-15-2015, 09:41 PM   #623
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
Hey guys just tuned my car using OFT stage 2 EL E85. I have no clue on how to read the data log since idk what half of the things mean. All i know is My AFR is a bit lower than 12. I don't know if that's bad for the car or not. can someone please take a look at my data logs and let me know if everything is running the way it is suppose to be (LTFT and STFT). Would greatly appreciate it.
3rd Gear pull: http://datazap.me/u/shaynek/log-1442366322?log=0&data=1
cruising at 75: http://datazap.me/u/shaynek/log-1442366322?log=2&data=1
1st and 2nd gear: http://datazap.me/u/shaynek/log-1442366322?log=1&data=1
shaynek is offline   Reply With Quote
Old 09-16-2015, 12:34 AM   #624
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
10 to 12 whole points isn't a tad.
Old 09-16-2015, 01:28 AM   #625
bizintine
bizintine's Avatar
Does this mean I should start some MAF scaling?
Old 09-17-2015, 10:47 AM   #626
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
http://datazap.me/u/el-92/1-3rd-gear...data=1-2-5-8-9
steve99 whats up can you help me out here how does the datalog look should do any maf scaling?
el-92 is offline   Reply With Quote
Old 09-17-2015, 10:54 AM   #627
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Looks like it's running a bit rich, have you done any scaling?
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 09-17-2015, 11:14 AM   #628
el-92
el-92's Avatar
Nope haven't touched any of that yet should I start ? Or should I lean it out a bit ?
Old 09-17-2015, 01:01 PM   #629
sav
sav's Avatar
I would get the MAF scaling right before touching anything else.
95RON SAV Tuned
Old 09-17-2015, 01:18 PM   #630
el-92
el-92's Avatar
Alright any tips or should I just go through the tips on here ?
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
