| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 Black Scion FRS
Winter Tire setup
Hey so Living in Boston I def want winter tires for my frs and was thinking getting 225 in rear and keeping front 215.
Some questions: 1. I def want blizzaks but which blizzaks should I get? 2. Will I be okay lowering my car by an inch or would it be better to get meatier tires? Cuz my car is low enough I already scrape occasionally can't imagine going lower would be like�� 3. Would it be a good idea to keep rear also thicker than front tires? Like the tire trim height? Whatever it's called not sure still learning 4. Also I notice looking at the car from the back the stock tires are in quit a bit I would like some meat to stick out a little if that makes any sense? Thanks |
#2 |
Drives: Asphalt FR-S
I would recommend skinnier or same size tires not wider for winter. I used blizzack lm 60 my first winter and Michelin xice3 (seem more like lm60) but I would recommend ws-70 which I have now for better "lots if snow" preparation as the lm 60 are more for cold light snow conditions while ws70/ws80 are more for deep packed snow/ice. I also went down from oem wheels to 16 inchers. Good luck. Also check out the numerous threads on this.
| The Following User Says Thank You to CB390248 For This Useful Post: | DVNARC (09-15-2015) |
#3 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Yeah I second what CB390238 said. I ran Blizzak WS70's my first year, burn the rears out in 10k km's lol!! I put X-ice in the rear and blizzak on the front last year, worked very well for me. X-ice seem to last longer with my driving habits lol!
| The Following User Says Thank You to go_a_way1 For This Useful Post: | DVNARC (09-15-2015) |
#4 |
Drives: 2013 Firestorm FR-S
WS80s are the way to go. Stock size will be fine, that's what I have. However, getting a set of 16" steelies with some 205/55/16s would work slightly better. But definitely stick with a square setup, and don't go more than the stock width.
Winter is very very fun in these cars.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following 3 Users Say Thank You to Shark_Bait88 For This Useful Post: |
#5 |
I have 205/55/16 General Altimax Arctics on steelies and never had a problem plowing through snow.
#6 |
#7 |
My logic is that the blizzaks will be so good that I can get wider back tires cuz to
Be honest I don't like how thin they are stock :/ |
#8 |
Drives: 2013 Ultramarine FR-S
Skinnier is better in winter if you expect a lot of snow. Non-staggered as previous mentioned. 16" steelies with a 195/55/16 or 205/55/16 are a good decision. That way you don't have to keep getting tires mounted and dismounted a bunch. Tires are also a bit cheaper.
Lows isn't too big a deal... ![]() Though I will say. It's getting lifted an inch from stock height for this winter.
| The Following User Says Thank You to DustinS For This Useful Post: | DVNARC (09-15-2015) |
#9 | |
#10 |
And don't smaller rims allow you to accelerate faster if larger lowers acceleration?
#11 | |
Edit: not really. Tire size will effect the acceleration but the 195/55-205/55 is pretty much the same as stock. Nothing will change
#12 |
If you're basing the sizing of your snow tires on visual desires, you're doing it wrong. Not trying to be harsh, but tires are about function; especially in the snow.
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | DVNARC (09-15-2015) |
#13 |
And would it be ok if they stick out more like this http://www.ft86club.com/forums/showthread.php?t=41083
Looking at my Stock Tires From The rear at An angle I see they are in the car |
#14 |
| WTB: Steelies for winter setup in North NJ/NYC or Philly | bayank | NY / NJ / CT / PA | 0 | 11-12-2014 01:52 PM |
| Winter suspension setup | R2 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 11-02-2013 02:20 PM |
| Winter Wheel/Tires setup - cheap and awesome! | seven | Wheels and Tires | 5 | 02-25-2013 02:12 PM |
| Winter setup | cnk | NY / NJ / CT / PA | 72 | 12-13-2012 08:48 PM |
| RPF1 winter setup | whiteout fr-s | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 10-27-2012 12:29 PM |
