Old 06-16-2015, 05:43 PM   #211
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Club Racer, XP12, W6
I will probably try XP12 or W6 next...
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-16-2015, 08:20 PM   #212
CSG Mike
CSG Mike's Avatar
Originally Posted by OkieSnuffBox View Post
OK so in my case, what would you recommend for pads since I'm going to use the Wilwood kit (32lbs off the front of the car!), that I can run all the time or won't need a special procedure to run a street/AutoX pad on?
I was thinking XP12s and just deal with dust/noise on the street since they aren't hard on rotors and they dust doesn't destroy your wheel finish if it gets wet.
Carbotech used to stay not to switch between the AX6 and the XP series, but I thought remembered Emilio saying this isn't true anymore. Thoughts?
I'm open to other brands, but I've got a bunch of experience with Carbotechs on two different brake setups on Miata's and always liked the feel on the pedal.
If you like em, stick with em!
Old 06-17-2015, 02:47 AM   #213
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Originally Posted by BRZZZZZZZZZZ View Post
Sadly this car was never meant to be lapped after I got my Miata but now that I have realized I am too tall to pass the broomstick test even with a modded seat this is all I have
Scrunch down.
Old 06-17-2015, 08:18 AM   #214
BRZZZZZZZZZZ
Car Nut
Originally Posted by jsimon7777 View Post
Scrunch down.
Its pretty clear when you are doing that, plus its pretty hard to drive properly when you are slumped in your seat and your thighs are touching the steering wheel...
Old 06-17-2015, 01:45 PM   #215
EAGLE5
Dismember
EAGLE5's Avatar
I've seen many people eek by the broom test, the track workers fully aware that they are loose in their seats and scrunching. Then the drivers get in proper position while waiting in line.
Old 07-02-2015, 09:17 PM   #216
cab33
Drives: Fast
What do you guys suggest for a dedicated track day pad(no brake duct cooling kit)?
cab33 is offline   Reply With Quote
Old 08-17-2015, 03:52 PM   #217
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Just signed up for my first track day, and am gonna need to pick up pads obviously. It's at Road America, which has a super long (read: fast) front straight. I was thinking I'd go with either Carbotech XP10s or Project MU Club Racers. Any input?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 08-18-2015, 01:38 PM   #218
redlined600
redlined600's Avatar
Drives: Fr-s
Turn 1 isn't that hard on brakes since the speed delta isn't that great. Turn 5 and 12 are the killers.
I had good luck with the club racers there. Total confidence over two days.
redlined600 is offline   Reply With Quote
Old 09-10-2015, 10:57 AM   #219
Junkwipe
Drives: Toyota Gt86
Hi, I can't find the differences between endless mxrs ep418 and ep472 can anyone help me? Thanks
Junkwipe is offline   Reply With Quote
Old 09-14-2015, 09:50 PM   #220
stevesnj
stevesnj's Avatar
I skimmed through this thread and I am totally confused..lol lots of Mfgs. but good rating system. My question is, I plan to track my car and move through the groups and stay in a group i'm satisfied with. I may go to the track 1-2 times a month so it seems worth it to just switch pads for track days. In that case I'm not concerned about noise and dust just good bite and reliability. I will get slotted and drilled rotors which I can use on the street and track which will help with cooling in both scenarios. I have Project Mu PGFOUR G-Four Brake Fluid on the way also. I will move up to a seperate set of wheels and tires eventually. So what pads would be good for this scenario? I really don't want to spend a lot of money but I don't want something that will only last 5-6 track sessions.
thanks for any help!
My 2016 Build thread
Old 09-14-2015, 11:36 PM   #221
EAGLE5
Dismember
EAGLE5's Avatar
Pfc 08 last for a long long time.
Old 09-15-2015, 07:19 AM   #222
OkieSnuffBox
Drives: '23 BRZ Limited
Just buy blanks.
Old 09-15-2015, 11:46 AM   #223
CSG Mike
CSG Mike's Avatar
The only real fix to that is to get a BBK up front, so you don't spend a lot of money on pads.
Don't bother with "upgrading" rotors. Changing rotors is not an "upgrade". Spend that money on pads instead.
Old 09-28-2015, 05:07 AM   #224
nomis
Drives: Subaru BRZ
Guys i'm after some advice on my brakes. Before I did sandown I got a shop to do track prep service type deal and got among other things Penrite racing super DOT4 brake fluid. Rest of brake setup is stock.
Now it's like a week later and my brakes are still really soft feeling. My research online seems to suggest that is due to boiled brake fluid? Is it possible I boiled the Penrite fluid with stock setup ? Or are the stock pads and rotors ruined from heat.
On way home from work yesterday morning I could barely get ABS to trigger.
Heres pics of my front rotors 1 week later.
http://iforce.co.nz/i/hxmnfeta.awz.jpg
http://iforce.co.nz/i/kdkg2j1z.gmm.jpg
http://iforce.co.nz/i/h0pjunz2.yoc.jpg
http://iforce.co.nz/i/jipoe0oh.ayl.jpg
Both sides have groove that catch a fingernail but I'm not sure if that would affect the feel or not ?
Thanks
nomis is offline   Reply With Quote
Anime Discussion Thread ERA Off-Topic Lounge [WARNING: NO POLITICS] 2698 02-14-2024 11:55 PM
Gundam Universe - General All Discussion Thread poormans_LFA Off-Topic Lounge [WARNING: NO POLITICS] 273 03-23-2014 11:45 PM
S2000 vs BRZ at the track: track oriented discussion CSG Mike Tracking / Autocross / HPDE / Drifting 33 01-13-2013 06:54 PM
Track/Racing Discussion Allch Chcar Tracking / Autocross / HPDE / Drifting 9 05-26-2012 04:39 PM
Forza 3 vs. GT5 Discussion Thread Snaps Off-Topic Lounge [WARNING: NO POLITICS] 386 03-06-2011 12:10 AM
