Drives: 14 Limited BRZ
Turn Signals Blink Extremely Slowly
On my 14 Limited BRZ, my turn signals blink very slowly. I've heard of Hyperflashing but never heard of the opposite. I have stock bulbs in the turn signals, front and rear. I only had the car for two weeks so I know its covered under warranty its just my work hours coincide with all three Subaru dealerships by me, I'm off on Saturdays but all three said Saturdays is just for oil changes and inspections and I cant take a day off for a couple of weeks because of how busy we are.
Has anyone had this problem before? It seems like a bad flasher in my opinion Subaru sells it for $45.00 I think I'd be willing to buy it and just fix it myself if anyone here can confirm hats the problem. Thanks. |
#2 |
Drives: 2015 Limited
| The Following 2 Users Say Thank You to PNW-BRZ For This Useful Post: | MisterSheep (09-16-2015), soulreapersteve (09-15-2015) |
#3 |
Have you compared it to another to see if they are the same? Wouldn't want to spend the money just on a guess and then find out it is normal.
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (09-16-2015) |
#4 |
The turn signal relay is a grey box 2"x3" under the dash I believe above to drivers left. Just turn the signal on and you locate it. give it some sharp taps like from a screwdriver handle. Could be a stuck contact. You can get an LED signal relay for like $10-15 on amazon.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#5 | |
![]() humfrz |
#6 |
#7 |
Killed Scion
Drives: 2013 FR-S Whiteout
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#8 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | stevesnj (09-16-2015), Ultramaroon (09-16-2015) |
#9 |
Drives: Scion FR-S
As a young un' who's still relatively new to cars, i'm still amazed at what kind of products are out there. Blinker fluid is an actual thing. Blinker fluid. What.
#10 |
[ame="http://www.amazon.com/81980-50030-066500-4650-Electronic-Flasher-Toyota/dp/B008C9YS0Y"]Amazon.com: 8-Pin 81980-50030 066500-4650 Electronic LED Flasher Assy Relay Fix For Lexus Scion or Toyota LED Turn Signal Light Bulbs: Automotive[/ame]
| TapFlasher Problems: Turn Signals Stay Lit, Side Markers Don't Blink | bobsacamenoh | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 10-13-2014 10:17 AM |
| AutoWindow 3 blink Tap-Turn Module | schwartzki | Exterior Parts (Aero, Lighting, Etc.) | 1 | 08-13-2013 06:28 PM |
| Is it possible to link the turn signal blink to the side marker on the BRZ? | tracerit | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-09-2013 02:03 PM |
| How to: Fixing hyper blink on LED turn signals | Laika | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-20-2013 06:58 PM |
| Need help with LED turn signals. | Khalis | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-11-2012 11:23 PM |
