Old 09-13-2015, 01:56 AM   #43
Originally Posted by SkiRideDrive View Post
The measurement was takenough with the car not running. I can't get the car to run...wish I could.
daaaaaaa........
OK, it's my understanding that a fully charged 12V battery @ 80 degrees F should be around 12.6 V. Your voltage measurement was rerported to be about 13.5 volts, therefore, I led myself down this pig path that alternator was charging it at the time you measured the voltage .....
OK, OK, @Tcoat ....... ya got me there ......
Old 09-13-2015, 02:07 AM   #44
daaaaaaa........
Rare that I can catch you so taking full advantage while I can!
Old 09-13-2015, 02:07 AM   #45
steve99
Drives: FT86
Take a llok arround page 86 to 88 of the wiring diagrams pdf under (system Circuits- Starting Circuits) check the fuses in those circuits are ok and the clutch switch or park switch is operating ok.
Old 09-13-2015, 02:07 AM   #46
steve99
Drives: FT86
Old 09-13-2015, 02:29 AM   #47
daaaaaaa........
That's OK, @Packofcrows ...... pile on ......
Anyone else want to join in ...... ??
Old 09-13-2015, 02:38 AM   #48
fridayfrs
Drives: Frs
What about mechanism (I'm sure others know this part's name better than I) that is engaged when you push the clutch in? My car behaves that way if I brainfart the clutch when starting the car. Just tossing out a random idea...
fridayfrs is offline   Reply With Quote
Old 09-13-2015, 02:52 AM   #49
joe strummer
Join in?? You made a new fan. Good on ya.
joe strummer is offline   Reply With Quote
Old 09-13-2015, 03:25 AM   #50
Hotrodheart
Hotrodheart's Avatar
Thanks for your interest. I very much appreciate any input.
Problem:
I turn the key and the car doesn't even attempt to crank over.
Summary/Guess:
Theory 1: I unplugged the dimmer switch and trunk switch without disconnecting battery (stupid me).
Theory 2: I may have manipulated the alarm system dongle/wire in some way when removing the kick panel.
Please see a more elaborate explanation below.
Additional Information:
-Car ran fine 5 minutes earlier.
-Everything else works fine, headlights, door locks, trunk opens, etc.
What I've Tried:
-I tried using my spare key - no luck
-I tried disconnecting the battery (both terminals) for 5 minutes - reconnect, same scenario.
What I did after the car ran to cause it to not run:
-I tested out my brand new 86 nanny from beastronix. (http://www.beastronix.com/shop/86nanny-pedal-dance/).
-The 86 nanny plugs into the osb2 port. I tested it and it enabled pedal dance as designed.
-The 86 nanny also acts as a pass through so you can use an obd2 transmitter with torque or other app. I also tested that, that also worked. I was using an ELM327 V2.1 and the Torque app. That worked well also.
-Next on the list was installation of the 86 nanny into the car more permanently. So I shut the car off.
-Installation includes removing the panel on the left side of the dash, then unscrewing two srews, one under that panel, and another near your right knee, to remove the kick panel under the steering column.
-I removed the kick panel, disconnected the two switches (trunk open and dimmer switch) to drill a hole in the small panel to install the 86 nanny activation switch.
-I realized I did not have the right size drill bit and figured I could do it at work on Monday.
-hoping I wouldnt have to reinstall everything, I tried starting the car with those switches unplugged (dimmer and trunk opener). Car won't turn over.
-I tried reconnecting the switches. Car won't turn over.
-I tried disconnecting the battery (both terminals) for 5 minutes. Car won't turn over.
-I tried scanning with the ignition in the on mode with torque/obd2 unit - no codes.
- I tried my spare key, car won't turn over.
-I tried plugging the 86 nanny in just incase the car missed it for some reason and wouldn't start without it, car won't turn over.
-I am stumped.
-Also of note - the car alarm dongle/button unit is on the bottom of the kick panel, that was hanging by the wire when i removed the kick panel. I don't think i hit the button on it (blue) but I may have. Also, perhaps the wire hanging did something to the security system.
-The alarm (flashing red light with lock) light flashes on dash when I am not trying to start the car. I can't remember if that light flashed did that before this whole snafu, I'd be willing to guess it did not, but can't be sure.
Thank you so much!
Did you let @Tcoat work on your car?
Hotrodheart is offline   Reply With Quote
Old 09-13-2015, 03:32 AM   #51
in 4 group hug
Old 09-13-2015, 03:33 AM   #52
in 4 group hug
Not totally convinced that the guy with the ball cap in back is just hugging!
Old 09-13-2015, 11:53 AM   #53
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
in 4 group hug
Me right here
Old 09-13-2015, 01:14 PM   #54
aa_chow
aa_chow's Avatar
Drives: 2015 FR-S, 2020 Mazda 3 Sport
My auto FRS didn't start once upon a time....found out it was my dad who left it in gear (R) and shut off the car (Prius driver)...
aa_chow is offline   Reply With Quote
Old 09-13-2015, 01:24 PM   #55
Packofcrows
Hahaha. Like me turning off my parents Rav4 coming to our driveway. So used to turning off my manual car a few feet from my psrking space. Its a habit.
Old 09-13-2015, 02:48 PM   #56
I do that to my wife's auto car all the time. It doesn't like it much though and starts beeping and buzzing like it is R2D2.
Pushed start.. didnt start im_topher Engine, Exhaust, Transmission 86 11-29-2015 09:57 AM
Where did you start with your FR-S/BRZ jeepmor Scion FR-S / Toyota 86 GT86 General Forum 43 04-10-2014 01:39 AM
Battery dies, push start car in gear.... push start button rhythmM Scion FR-S / Toyota 86 GT86 General Forum 7 02-27-2014 06:06 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 02:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 03:44 AM
