Old 09-10-2015, 02:20 AM   #29
Cop
Cop's Avatar
Drives: 2013 FRS
Originally Posted by rx3 View Post
I initially installed it with the buddy club seat rails.
It did slide well enough but they had significant play. Because I didn't know whether any other slides would have less play I decided to fix the seat directly onto a seat base. However, the planted seat base is heavier than the buddy club rails alone, which is why I flexed some material off (now the screws are also more accessible).
Since I'm the only driver I don't need it to slide and the passenger seat is still the original one. I primarily used it for autocross purposes and most competitors don't use slides either.
It's currently not installed (I'm not driving this car in the winter). I will post pictures once it is installed again.
How was the seat height after switching to just the base and seat?
Cop is offline   Reply With Quote
Old 09-11-2015, 02:38 PM   #30
rx3
Sorry for the late response, I was adjusting/increasing the seat height using something like this (cut to length):
http://www.cap-aluprofile.com/S1084040L.jpg
(I think I have kinda long legs and a short torso, so I'm not sure whether this info is of any use to you).
(FWIW, none of the guys I race against use any slides.)
rx3 is offline   Reply With Quote
Old 09-11-2015, 02:57 PM   #31
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
I also had to drill new holes when installing aftermarket seats using the planted seat bracket. I was expecting a 'plug and play' scenario. That seems to rarely happen these days.
IG: @Lucky_FatPat
10 series // TRD x Turbo Build:
http://www.ft86club.com/forums/showthread.php?t=79474
mmmcambelsoup is offline   Reply With Quote
Old 09-11-2015, 04:42 PM   #32
Cop
Cop's Avatar
Drives: 2013 FRS
How did you change the seat height with that piece? Not visualizing it very well haha
Any issues adjusting to the lower seat height?
Old 09-11-2015, 05:14 PM   #33
mmmcambelsoup
Any issues adjusting to the lower seat height?[/QUOTE]
I'm 5'8 on a good day, so height was't really an issue for me w/ the planted bracket.
IG: @Lucky_FatPat
Old 09-11-2015, 05:53 PM   #34
Cop
Cop's Avatar
Drives: 2013 FRS
I'm 5'8 on a good day, so height was't really an issue for me w/ the planted bracket.[/QUOTE]
Not sure if I conveyed my question clearly, did the aftermarket seat being lower feel weird to you vs the OEM seat height? I know the planted base w/o sliders will drop you a couple inches as far as seating position goes vs OEM. I too am 5'8
Old 09-12-2015, 11:25 AM   #35
rx3
I connected the seat base to the seat side mounts using 4 screws (one in each corner).
I used 4 of these aluminum blocks as washers/spacers (screw goes through the center hole). They were placed between the seat base and the seat side mounts. (In order to get some extra height which I had with the rails before.).
A machine shop cut those aluminum blocks to length (length of about 1.5" each), which took about a minute.
Old 09-14-2015, 01:56 PM   #36
mmmcambelsoup
Def dropped the seat height and took some getting used to, but I prefer my chair to be lower when throwing the car around. I'm running a Nardi 350mm wheel and have it adjusted to the lowest setting as well.
IG: @Lucky_FatPat
Old 10-10-2015, 09:30 PM   #37
Rookie84
Drives: '02 GS300, '12 S80 T5, '15 BRZ 6MT
Here you go.
I also made a buckle bracket such that I could get a belt buckle extension through that opening in the seat.
Very nice! I need to do the same thing as I just purchased Recaro RS-GE for my car.
So did you just shorten the length of the stock belt buckle bracket and connect belt buckle extension? Did you cut the stock one or make a new one?
Rookie84 is offline   Reply With Quote
Old 10-14-2015, 06:20 AM   #38
rx3
I left the stock belt buckle as is.
I made an extension (basically a sheet metal piece with 3 holes, 2 holes to connect with the seat base bracket and one hole to connect with the belt buckle). This extension moved the connection hole to the stock belt buckle about 5 inches to the rear. This way I didn't have to shorten it.
If possible I would weld a new bracket to the seat base, so you don't need an extension. (In my case this wasn't an option because the seat was too far back.)
The Following User Says Thank You to rx3 For This Useful Post:
Rookie84 (10-14-2015)
Old 10-14-2015, 11:41 AM   #39
Rookie84
I see. Thanks for the info! I will try something similar with mine.
Old 07-23-2018, 12:04 AM   #40
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Here you go.
You have a diy or did you purchase from a company for the extender
el-92 is offline   Reply With Quote
FS/FT: Recaro Young Sport child seat Cade01 Miscellaneous 25 08-06-2013 02:35 PM
Recaro Sporster CS installed in BRZ. Racecomp Engineering Cosmetic Modification (Interior/Exterior/Lighting) 27 06-04-2013 05:51 AM
The Perfect Dry CF Recaro Seat for the FRS Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 7 05-17-2013 03:55 PM
Who sells Recaro seat mounts here in the US? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 2 02-05-2013 12:19 PM
