FT86
Drives: 2015 FRS Ultramarine
Bolt on mods or Turbo need help.
Bolt on mods: for about $2,000 with basic bolt on mods + openflash tuning and e85 it will give the car about 20-30whp? If my math is wrong please correct me thank you. (Hoping more HP)
Turbo/Supercharger: Now with this it will run around $6,000 - $8,000. I've asked vendors of turbo/superchargers. I'm getting it will give right about 260whp+ running on 7psi with (I'm not sure maybe it will give more if i use e85) I'll be using the car for Daily driving and a little bit of spirited driving here and there. Ok, after reading the basic bold on mods I am looking at getting couple of things done on my FRS. I hope I understood it right after reading it couple of times, I didn't maybe you guys can help me understand more. Ok here, Basically if I get a UEL headers + front pipe + Exhaust + Tune. If I added it right am I looking at about 30 horse power gain? Green words below are copied from basic bolt on mods. If you run E85 on completely stock car with appropriate E85 tune you can get about 20 Wheel HP gain. Catted header with tune (petrol) about 15 wheel hp Currently I have on the car is very basic. I just bought the car 8/20/15 TRD EXHAUST SYSTEM. K&N Drop in filter. What I want to add are as follow: Total cost around $2,000. UEL HEADERS > Any reliable brand will do. FRONT PIPE <- If this will give an extra boost yes. If not ill use oem. Openflash tune > use e85, then tune with UEL Headers. Perrin Intake tube > On their website it shows it give a couple HP increase is it worth doing it? If I do will it make the car quiet from under the hood? What do you guys think? Thanks.
2015 FRS Ultramarine 8/20/15
TRD Exhaust System | Suntek | Opti - Coat | K&N D.I.F Future mods: Vortech or Fullblown! Need to more then read some more. |
| The Following User Says Thank You to Elliryx For This Useful Post: | Mr.Impreza (09-12-2015) |
#2 |
I love peanut butter
Drives: 2013 SWP BRZ Limited
I have a catless UEL header, axle-back exhaust, k&n air filter, and an openflash stage 2 UEL tune. I am very content with the output for my daily driving needs. Spent under $1000 for the 4 mods.
Mind you, I do not go to the track or anything like that. I personally didn't want to sacrifice reliability and ~$7000 to make my car faster on the highway. This car is my daily driver so having a functional car 24/7 is an absolute must. You could always start out with the bolt-ons and see if you're content. If not, you will have no problems selling the stuff and you can then go with FI. An exhaust system will not do anything for you if you're not going FI, so if you only want some more growl just get an axle back. Same for intake, you are best off getting a K&N filter and using the stock airbox. Front pipe will open up the airways a bit, but will make your exhaust not sound as good (IMO). For a tune, you can get an OpenFlash tablet for $500 or a Tactrix openport 2.0 for $169. Last edited by B-R-Z; 09-12-2015 at 10:02 PM. |
| The Following 2 Users Say Thank You to B-R-Z For This Useful Post: | Elliryx (09-12-2015), Mr.Impreza (09-12-2015) |
#3 | |
FT86
#4 |
Good deal. So yes, that would be all you need to add. I have a Tsudo header--and it is uncatted so I'm sure I would fail emissions tests. There is no CEL since openflash tune disables it.
#6 |
Drives: 2013 FR-S Argento
Get an OFT, tune and run E85. Will probably get you 185-190 whp.
Then look around for used vortech kits on here, you can prob get one for 2500 give or take. Bolt it on yourself, tune for 260-280 whp in a pretty reliable setup. Sent from my iPhone using Tapatalk |
#7 |
Drives: frs
Buy a propper grip tires and enjoy the car as it. When you dominate the car with performance tires
you can add power mods bit by bit. Saludos |
#8 |
Drives: FRS-Raven-MT
E85 and a drop-in got me just shy of 193whp on a dynodynamics.
After that I did uel, pulley, intake, Overpipe/frontpipe, catback. I put down 199whp with that on a dyno jet. I probably spent a little over 2k for all that. Car drives great. If I could go back I would have done header and e85 and called it a day. |
#9 |
ELECTRIC SUPER CHARGER
While it's only 30-40hp, it is 50+ tq. Cost is around ~2200 and can be installed and removed in less than two hours. |
#10 |
Drives: 2014 GT86
+ loooong waiting time to get one.
#11 | |
FT86
#12 | |
Drives: FT86
with a turbo always budget for an oil cooler as well if not included in kit. if your unsure if you want to go turbo\supercharger then just get oft and openflash header no other mods, you can try petrol and e85 tunes. maybe a drop in filter both the oft and openflash header sell very well secondhand with minimal loss of money. just those two mods will get you most of the NA gains and minimal waste or loss if you move on to turbo\sc or go with the oft turbo\sc kits. you could do same thing with ecutek try teir na tunes then jump to turbo\sc if you have ecutek dealer nearby, otherwise you will have to buy ecuteck cable to flash, note ecutek licience is not transferable and neither are their tunes both locked to your car. |
#13 | |
Mr.Fujitsubo
Drives: 2018 STI
So, currently your doing things correctly. The drop in is a great investment and much better than a full intake because the full intake doesn't help much. The exhaust, your getting for sound and weight. So you have that checked off. So I'm the same, drop in and a axel back exhaust for sound and weight. Our next step, should be the OFT. It will bring out the cars potential, add about 10hp and not remove the TQ dip completely, but at least a little. Either way, for the price, this should be the next mod! Once this is done, this is where it becomes tricky. Yes, you can get a header. The UEL will make the car sound more like a boxer (which i don't like) and gain more low end and mid range tq. A EL header will sound like a normal car (which i like) and give you more in the higher rpm (less gain in lower rpm compared to UEL) Either choice, the catless UEL/EL are the next best thing. However....if your worried about emissions, a catted header is better for that. BUT...one huge but. A catted header doesn't work well with the OFT maps, and you'll have to get a custom tune by them for an extra $200.00! *You can run the normal stage 1 map with the header, but the gains are almost zero and sometimes it may run worse) Now it's your choice. I was thinking of getting a catted one until a member helped me calculate costs. A catted header costs usually $300more and plus the custom tune your looking at $500 more! In some ways, it's better to just keep your stock header and replace the headers whenever you need to pass emissions haha. BUT, another but. The $500.00 extra may be worth it if you don't want a loud car! I'm still lost here because i don't want my car to be super loud which header tend to do. Regarding other parts. An overpipe is pointless. Unless your bored and have money and aiming to achieve weight loss. The Front pipe has a very small gain, and the other issue is it increase the noise of the exhaust by quiet a lot if you go catless. If you go catted it's not that bad, but it gets expensive and sometimes it's not worth the money for those 2-4hp. So at the end of the day, the best route (since this is a daily) is go tune next! You may be happy with it and not want more. After, you can choose, fp or header. Header is where the gains are. FP, is if you plan to just stop and not get headers because of noise/emissions etc....the fp will give you another few hp. But if you go header, just forget the fp...it will make the car too loud (fp and catless header) and after the header, a fp won't give you any noticeable gains.
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#14 | |
Drives: Lexus RC-F
| Basic Bolt on mods intake, exhaust tuning guide | steve99 | Engine, Exhaust, Transmission | 204 | 09-12-2022 08:06 PM |
| Visconti Stg 1, and other bolt on mods | Sonolin | Engine, Exhaust, Transmission | 12 | 02-19-2013 05:14 PM |
| Blitz Bolt on turbo | DIG1992 | Forced Induction | 35 | 01-12-2013 09:25 AM |
| Estimated HP gains - bolt on mods and reflash? | ahausheer | Engine, Exhaust, Transmission | 207 | 01-14-2012 06:14 AM |
