Old 09-10-2015, 05:25 PM   #29
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
Originally Posted by Locust View Post
18x12" wheels with 215/40R18 tires.
#stancenation
/thread
fatalelement is offline   Reply With Quote
The Following 6 Users Say Thank You to fatalelement For This Useful Post:
DarkSunrise (09-10-2015), Dream20b (09-27-2015), drewbot (09-11-2015), Hyper4mance2k (02-04-2016), Icanfaptothis86 (09-10-2015), ultra (10-07-2015)
Old 09-10-2015, 06:44 PM   #30
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by fatalelement View Post
That one is such a classic.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 09-10-2015, 07:03 PM   #31
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
So you're telling me I can't just go with 18x9.5 all around on my otherwise stock car and call it a day?
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 09-10-2015, 07:14 PM   #32
DarkSunrise
DarkSunrise's Avatar
Haha that was perfect.
2022 BRZ Build
2013 FR-S Build
Old 09-10-2015, 11:28 PM   #33
SVLTE
This is definitely gospel for track driving, but does it hold any water for autocross? If it did, it seems the ideal setup in CS would be the 205/45/17 RE71R since it has a 7" tread width. I haven't seen anyone claiming to be running that or the 215, just 225 and 245.
SVLTE is offline   Reply With Quote
Old 09-10-2015, 11:53 PM   #34
Skurj
Drives: SOLD...
I can't imagine how bad the understeer would be if that was the only change off the showroom floor on my car. I probably wouldn't have bothered modifying it and just sold it for something else...
My car came off the showroom floor with 225's front and 255's rear on staggered wheels... That first track day was hoooorrrible... talk about understeer..
Ok that was over 2 years ago...
I now run them the other way around... 255 on the front, 225 on the rear..
Actually come to think of it... both my cars came off showroom floor staggered... (only one came that way from the factory) they now are both square for trackdays at least.
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018
and its gone... Sept '18 tho I am sure I will miss it
Replaced with 18 50th edition ND
Skurj is offline   Reply With Quote
The Following 2 Users Say Thank You to Skurj For This Useful Post:
strat61caster (09-11-2015), wparsons (09-11-2015)
Old 09-11-2015, 12:42 AM   #35
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Per the article:
On the other hand, if a tire is too wide for a given wheel width, the sidewall ‘bulges”. This usually results in sloppy handling characteristics, vague steering feel, excessive tread squirm, and the carcass of the tire can also distort and have uneven pressure across the surface of the tire.
The sloppiness is an easy hit to take for a tire that makes larger contact with the ground, the flex means that the tire rolls around and complies continuing to make contact with the ground, couple it with the flex generating additional heat so the tire 'hooks up' faster and that leads you to what is observed on the scene right now.
[ame="https://www.youtube.com/watch?v=pQTFJg7R1KQ"]Critical Velocity Scuff - YAW - Tire deflection - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=sjx8WFXHNLA"]Team VCMC FR-S - AutoX Video 3: Rear Suspension, Subframe, Tire (HD) - YouTube[/ame]
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
SVLTE (09-11-2015), ultra (10-07-2015)
Old 09-11-2015, 07:40 AM   #36
OkieSnuffBox
Drives: '23 BRZ Limited
Typically no. At Auto-X speeds you aren't as worried about rolling resistance and aero, however, the car is typically constantly in transition and can use the extra width.
On a road course, you spend alot of time going straight where the extra width is slowing you down between corners.
The Miata guys have even done testing showing Hoosiers (while having a higher apex speed) will actually lose a few mph at the end of the straight to something like an NT-01 (same width for both) which entered the straight slower.
And that's purely on compound.
The Following 6 Users Say Thank You to OkieSnuffBox For This Useful Post:
CSG Mike (09-11-2015), rallysrt (09-13-2015), strat61caster (09-11-2015), SVLTE (09-11-2015), ultra (10-07-2015), wparsons (09-11-2015)
Old 09-11-2015, 03:59 PM   #37
CSG Mike
CSG Mike's Avatar
Also, note that Hoosiers are WAY, WAY lighter than a NT01 of the same size, and weight is being reduced from the highest point of inertia.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
AreteAuto (09-14-2015), OkieSnuffBox (09-14-2015), ultra (10-07-2015), wparsons (09-11-2015)
Old 09-14-2015, 01:17 AM   #38
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
When I switched to some lighter wheels, and 225 PSS, I lost a couple mph at the end of the back straight at road atlanta. But the rest of the course they were much much quicker than the stock setup of course.
“$20 per diddle? I can diddle myself for free and do a fine job”
AreteAuto is offline   Reply With Quote
The Following User Says Thank You to AreteAuto For This Useful Post:
Old 09-14-2015, 08:24 PM   #39
philooo
Drives: 13' Scion FRS Track car
I ran my car this weekend back to back with a 245 BFG R1 tire setup then later on 225 AD08, and really I can barely tell the difference.
Yes there is a slight edge to wider tires, but if you don't plan on driving your car 10/10 on the track you will be more than fine.
I have a full cage in my car and still I am not looking to drive it 10/10 unless I was racing, which I am not..yet ..
I would love to see real comparison on the same tire make/model and different size, especially 225 on 8" rims and 245 on 9" rims.
I bet they even out, faster turns on 245 and faster straight on 225. I think 225 may be more fun all around.
philooo is offline   Reply With Quote
Old 09-14-2015, 08:52 PM   #40
strat61caster
Road and Track did it with 215 and 235 Dunlop ZI SS, it's exactly as you predict lateral grip vs. acceleration and straightline speed.
http://www.roadandtrack.com/car-cult...ransformation/
Around a track (I believe some iteration of streets of willow, can't tell) the 215's were faster than the 235's.
ineedyourdiddly
ultra (10-07-2015)
Old 09-14-2015, 10:19 PM   #41
redlined600
redlined600's Avatar
Drives: Fr-s
Likely course dependant
redlined600 is offline   Reply With Quote
Old 09-14-2015, 11:46 PM   #42
SVLTE
I appreciate the input on my AutoX question! I'll be sticking with 225's.
Trackwise, I've been running some 17x9 Rota Titans w/ 245/40 PSS. I enjoy driving on the setup, but they are most certainly overkill on my C-street prepped car. I've got those wheels up for sale and plan on dropping to a 17x8 with either 215/45 or 215/40 AD08R's. Has anyone else run a 215/40? My local track has a lot of elevation change and the gearing advantage seems like it would be a welcome one. There are two tricky turns, both are tight, uphill increasing radius right handers. Staying in third puts me out of the power band, but downshifting to 2nd requires an extremely awkward shift back to third before the wheel is straight again.
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 09:23 PM
Best wheel size for performance? themarvz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-13-2013 07:53 PM
Performance and wheel size Howardwei Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-05-2013 11:11 AM
TIRES, TIRES, TIRES! @ Pure Automotive Performance Pure Automotive Wheels and Tires 1 02-04-2013 02:32 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
