Old 09-09-2015, 12:08 AM   #1
kodyo
Drives: Scion FR-S
How close is too close?: Gap between tire & spring perch
I installed SPC camber bolts to the front struts and I just now noticed there is only .125" of clearance between the spring perch on the stock struts and the sidewall of the tire. I haven't noticed any rubbing, but I also haven't done as much hard cornering yet either.
I have a track event on Saturday and was wondering if this may be an issue? Plan is to go from 225 width PSS to 215 PSS in the near future, which I imagine should help a little, but just wanted some more input.
kodyo is offline   Reply With Quote
Old 09-09-2015, 12:19 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Any pics? That will help out.
Old 09-09-2015, 12:23 AM   #3
swarb
I personally would not risk it. I would buy a pair of spacers and have them ready just in case. 10 bucks on spacers is much cheaper than a track day.
What wheel/tire/suspension are you on?
Old 09-09-2015, 12:48 AM   #4
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I've run my car similarly before without much problem. A bit of tire rubbing off on the bottom coil, but not a big deal. a set of 5mm spacers wouldn't hurt either.
Intent > Content
Old 09-09-2015, 12:54 AM   #5
DarkSunrise
DarkSunrise's Avatar
Surprising to hear you have so little clearance. I'm using whiteline (rebranded SPC) bolts up front with -1.5 degrees camber. 235 width tires, +42 offset wheels. Have around 8-9 mm free.
With only 3 mm clearance, I agree with swarb to get a set of spacers. Not worth risking the track day or your safety IMO. There's got to be some thermal expansion as the tire heats up on track.
2022 BRZ Build
2013 FR-S Build
Old 09-09-2015, 02:31 AM   #6
CSG Mike
CSG Mike's Avatar
Get a 3mm spacer. If you can't find it locally, we can get it for you.
Old 09-09-2015, 08:42 AM   #7
wparsons
wparsons's Avatar
Please don't buy $10 spacers...
This must be on stock (or other higher offset) wheels. I've got -2* up front (whiteline bolts and slotted upper strut holes) and have at least enough space that it's not rubbing under any circumstances, it's definitely close though.
17x8 +45 with 225/45's. I've had ZII's and RS3's and neither rubbed. AD08R's go on in the next couple days, not expecting they'll rub either.
flickr
Old 09-09-2015, 09:32 AM   #8
kodyo
Drives: Scion FR-S
The problem is because of my wheel offset more than anything else.
They are SSR Competitions 17x7.5, +50 offset. Suspension is stock springs/struts with SPC camber bolts and HVT camber plates. Tires are PSS 225/45/17.
I'll be looking for a 3mm spacer.
Old 09-09-2015, 02:33 PM   #9
swarb
What is wrong with cheap spacers? I am talking about 3-5mm slip on type. Please inform me.
Old 09-09-2015, 04:03 PM   #10
CSG Mike
CSG Mike's Avatar
The legit 3mm spacers we sell are only $20/pair...
Old 09-09-2015, 04:46 PM   #11
wparsons
wparsons's Avatar
Only spacers I've seen up here at prices even remotely close to that look like cheap metal that might squish under normal torque, and have poor finishes. Can't even blame it on the Canadian dollar, last time I looked locally was before the dollar tanked.
flickr
Old 09-10-2015, 07:08 PM   #12
kodyo
Drives: Scion FR-S
This is best I could find on short notice. Are these going to be sketchy to run long term? Debating using these for now and getting better ones on order.
Old 09-10-2015, 10:03 PM   #13
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
I've been running a wheel and tire combo that gives me only 2mm clearance upfront for 3 years now and have never seen any sign of rubbing. Watch it for signs off rubbing, but I bet you'll be fine.
D18 is offline   Reply With Quote
Old 09-10-2015, 10:28 PM   #14
solidONE
solidONE's Avatar
That's the kind you don't want to use. You want to run hubcentric ones with a 56.1mm bore
http://www.newegg.com/Product/Produc...A&gclsrc=aw.ds
Intent > Content
CLOSE/DONE Jman1759 Want-To-Buy Requests 2 07-22-2015 03:58 PM
close FyeaFRS NY / NJ / CT / PA 8 08-19-2014 06:09 PM
smallest OD coil over / spring perch BadBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-27-2014 01:56 PM
Clearance to spring perch Gearhead1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-07-2014 06:56 PM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 02:00 AM
