Old 08-08-2015, 12:38 PM   #393
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Originally Posted by drewbot View Post
Did you update your template file? I had the same exact issue when I logged with an old template file and tried to import into a new OF manager software
Sent from my A0001 using Tapatalk
Hmm I just updated to 8.2 and still taking a while... I'll leave it for a bit and see if it eventually loads. I was on 8.0 and I was able to load my other file I captured last week (since been removed from OFT).
Myv is offline   Reply With Quote
Old 09-10-2015, 02:48 PM   #394
JS + BRZ
Drives: 2010 MS3
Alright, a quick question. I couldn't find the solution from searching for some reason.
@steve99, my friend has been using OFT for awhile. He never had to install the manager program since he just flashed the stage 2 map and was done with it. He just installed the powerblocks on his car and received the tune for it via email.
How do you install the OFT manager on his Mac? I read about doing it on PC but couldn't find a link for Mac.
Thanks!
Old 09-10-2015, 03:49 PM   #395
OkieSnuffBox
Drives: '23 BRZ Limited
*I don't know since I'm windows*
But could you just run a Virtual windows machine, install Open Flash Manager and do it that way?
Old 09-10-2015, 05:21 PM   #396
JS + BRZ
Drives: 2010 MS3
I never use Mac neither.. that's why I have no idea with it. haha
Old 09-10-2015, 06:20 PM   #397
steve99
Drives: FT86
im not a mac guy either, but the oft guys and shiv use mac,s
i believe you use mac software called parallels or some other emulator that creates a windows enviroment on mac then you load ofm into that
best talk to some mac guys or oft guys
JS + BRZ (09-10-2015)
Old 09-10-2015, 06:35 PM   #398
JS + BRZ
Drives: 2010 MS3
Ah, got it! I'll PM Shiv..
Thank you!
Maybe I should just bring my PC laptop and do it for him real quick. It's pretty simple, right? Just install the program, load up the new tune, transfer it on the device, and reflash ecu?
Old 09-10-2015, 08:05 PM   #399
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Thank you!
Yeah its pretty simple! If anything just pm me. I can help!
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
The Following User Says Thank You to FRS Johnny For This Useful Post:
Old 09-10-2015, 10:20 PM   #400
JS + BRZ
Drives: 2010 MS3
Ahhhh that's right! You have it. haha Will PM on FB later!
Old 09-11-2015, 03:32 AM   #401
FRS Johnny
FRS Johnny's Avatar
I deactivated my fb! so just text me. I'll pm you my number
Old 09-11-2015, 10:28 PM   #402
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Does anyone have a correct link to the latest stage 1 tunes? I seem to find two different websites again
Old 09-13-2015, 12:33 PM   #403
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Originally Posted by ShadowSeraph View Post
All the above does with windows 10 + virtual dyno. To be honest, windows 10 is largely just a streamlined and different User Interface version of windows 8. Pretty much any win 8 driver or program works with win 10. I have all the above programs working well on win 10 on a laptop and desktop setup.
- your friendly forum IT guy.
So should I install the Windows 8 patch while running Windows 10?
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 09-15-2015, 02:33 AM   #404
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Tip in knock or exhaust rattle?
Here is a log I took after (re-re-re)installing a somewhat ill-fitting front pipe (j2 70mm) that doesn't have provisions for the stock doughnut gasket.
http://datazap.me/u/solidone/fp-no-o...=0&data=1-5-12
As you can see, a stupid amount of knock at tip-in and upon throttle closure.
Here's another log I took after having really torqued down the catback to front pipe connection.
http://datazap.me/u/solidone/tip-kno...=0&data=1-5-12
tip-in knock still present. I checked all the connections for leaks and was not able to locate any.
Now, I recall a long while ago there was some discussion about "phantom knock" on these boards. After having taken these logs, I'm suspicious of the vibrations in the exhaust system upon sudden load increase during low RPM operation being mistaken for engine knock by the ECU. What are your thoughts?
Intent > Content
Old 09-20-2015, 02:19 AM   #405
romulus
Drives: 2015 Toyota 86 GT Project
I have the same question. Anyone know the answer?
romulus is offline   Reply With Quote
Old 09-20-2015, 03:04 AM   #406
romulus
Exclamation Checksum HELP!
Is it normal to get a "The checksum of the file has been corrected" message when uploading new BIN files?
I tried with and without the Windows 8 patch on a fresh Windows 10 PC but as I have never uploaded before I don't know if I should be seeing that message
HELP!
To scared to go any further and so want to try the new ROMS!
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
