Old 09-09-2015, 01:47 PM   #197
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Originally Posted by Alltezza View Post
That sounds so sexy
DO you like it?
I am thinking to sell it. Only on my car for 2 days and less than 200 miles.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
The Following User Says Thank You to Figo For This Useful Post:
Alltezza (09-09-2015)
Old 09-09-2015, 02:40 PM   #198
duke_FRS
duke_FRS's Avatar
Drives: 2015 FRS Hot Lava 2014 CT200H
Originally Posted by Figo View Post
Vortech Supercharger V3 kit
Vortech Maxflow race BOV
JDL UEL catless header,
JDL overpipe
JDL ultra quite front pipe (1 HFC + 1 resonator)
ARK Grip catback
The BOV sounds great at shift, but kinda too loud for me at cruising.
So I have changed it back to the one that come with the sc kit.
What the hell is that sound? lol exhaust sounds good with that header setup
Open Flash Tablet Stage 1 93 | Borla Cat-Back | VOSSEN VFS1 | Eibach Sportline
duke_FRS is offline   Reply With Quote
The Following User Says Thank You to duke_FRS For This Useful Post:
Figo (09-09-2015)
Old 09-09-2015, 06:58 PM   #199
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
DO you like it?
Love it....But I do not have a vortech SC and I'll most likely be buying the JRSC and I don't even know if that BOV is compatible
Alltezza is offline   Reply With Quote
Old 09-09-2015, 07:22 PM   #200
DJCarbine
Thupercharged
DJCarbine's Avatar
If you want, you can find out where the JRSC wants the valve to open and compare it with the maxflow valve characteristics. If the kit uses a 25mm/1" hose that goes to a bosch type bypass valve, you can use a greddy flange to 25mm adapter. This is how I mounted my maxflow on the standard charge pipe that vortech supplies. The greddy flange is almost perfect, you just need to drill the holes out slightly larger for the bolts to fit.
Beware, it is LOUD and will scare small children and anger the cops
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 09-14-2015, 12:14 PM   #201
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Can someone snap me a pic of the top of their compressor so I can take a look at the breather valve thinger. A buddy of mine picked up a kit second hand and it was missing several of the smaller components. By the looks of it the compressor still has the shipping plug in it and the guy he got it from said he ran it for like 5k miles.
It has the domed dip stick one and the one to the left has the flat top and looks to still have a dab of something marking it.
also if anyone has a P/N, couldn't decode from the install instructions part list.
*EDIT*
Found what I was looking for:
http://www.jegs.com/i/Vortech/933/7P...ductId=1137094
FyeaFRS is offline   Reply With Quote
The Following User Says Thank You to FyeaFRS For This Useful Post:
bee_are_zee (09-15-2015)
Old 09-20-2015, 10:26 AM   #202
w0wbagger
Drives: GT86
Hey guys,
I just experienced a belt rupture with my Vortech. Well not exactly a rupture in a way that I get a belt with an end and a beginning, but more like a rupture in a way that it has been "cut" into two pieces along the circumfence (if you know what I mean). So to say I now have two belts...
This happend just 5000km after the V-2 has been installed with the 3.125" pulley.
I am wondering if the extra heat by the shared oil with the engine caused a belt failure or of maybe one of my pulleys was not perfectly aligned. Nevertheless I will get the 2.87 pulley installed this wednesday and I already have a Gates HD belt ready for installation.
Do you guys know any alternative for the gates belts? I am looking for a reinforced or extra strong one in particular which is compatible with the 2.87" pulley!
w0wbagger is offline   Reply With Quote
Old 09-20-2015, 10:43 AM   #203
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by w0wbagger View Post
Hey guys,
What size belt were you running with your 3.125" pulley? I've only had issues with the wrong belt size back when no one knew which belt size to run on the smaller pulleys.
2013 FRS
Vortech V3 11psi
Old 09-20-2015, 11:28 AM   #204
w0wbagger
Drives: GT86
To be honest I don't even know.
I bought the belt together with the 3.125" pulley from our german Vortech reseller.
The belt was announced as suitable for the 3.125".
I just brought the car to my shop (not the Vortech reseller). When I get it back I can take a look at what's left of the belt to check for any signs.
Old 09-20-2015, 04:11 PM   #205
DJCarbine
Thupercharged
DJCarbine's Avatar
Yeah man, see if you can grab the size or PN from the belt. I had a belt that was too tight and ended up failing, switched to the correct size in a goodyear gatorback belt and have had no more issues so far.
Goodyear gatorback was #4060967, got it off amazon for 20 bucks. I think now they go under the continental name since a merger/buyout or something
2013 FRS
Vortech V3 11psi
The Following User Says Thank You to DJCarbine For This Useful Post:
germgerm (09-21-2015)
Old 09-21-2015, 08:26 AM   #206
nelsmar
Hey... Don't I have your DI seal install tool sitting on my counter? 0.0
My flickr - Canibeat
Local magazine scout
Old 09-21-2015, 08:35 AM   #207
DJCarbine
Thupercharged
DJCarbine's Avatar
Now that you mention it, I think you do lol
2013 FRS
Vortech V3 11psi
Old 09-21-2015, 08:44 AM   #208
nelsmar
That thing has come in handy so many times... You should PM me your address and I'll mail it back next week!!! I feel horrible for never sending it back! I cant believe I had forgotten about it. 0.0
Old 09-21-2015, 09:34 AM   #209
DJCarbine
Thupercharged
DJCarbine's Avatar
That tool is famous, I think I loaned it to Dezoris for his DI seal video... its been a while haha
2013 FRS
Vortech V3 11psi
nelsmar (09-21-2015)
Old 09-21-2015, 10:39 AM   #210
nelsmar
HAH! Thats awesome!
Its sad too because its been sitting on my kitchen counter for months since I have last used it... I sat it there to remember to ship it back to you and then forgot who i borrowed it from and had accidentally deleted the PM. I saw you post and it clicked in my head. lol
I'll send it out within the next week =D Thanks again!
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
