Old 09-08-2015, 12:06 AM   #3585
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Why not just use an inline thermostat on the kraftwerks oil cooler? [ame="http://www.amazon.com/Derale-25719-Fluid-Control-Thermostat/dp/B004XOQ0R6/ref=sr_1_9?ie=UTF8&qid=1441685114&sr=8-9&keywords=oil+cooler+thermostat"]Amazon.com: Derale 25719 Fluid Control Thermostat Kit: Automotive[/ame]
post_break is offline   Reply With Quote
Old 09-08-2015, 06:31 AM   #3586
FirestormFRS
Originally Posted by post_break View Post
Why not just use an inline thermostat on the kraftwerks oil cooler? Amazon.com: Derale 25719 Fluid Control Thermostat Kit: Automotive
Why add four more failure/leak points to the system.
That RacerX setup looks sweet if it actually works.
FirestormFRS is offline   Reply With Quote
Old 09-08-2015, 08:04 AM   #3587
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
basically what he said. I mean ideally I shouldn't have had to do this in the first place but it is what it is.
Freeman is offline   Reply With Quote
Old 09-09-2015, 04:55 PM   #3588
EquiFox
Drives: 2014 FRS Firestorm
I had a new blower installed by a Kraftwerks authorized reseller/dealer less than 1600 miles ago and the new one failed again...
I had to pay 50% of the value to get a new one (While I wait for the warranty result...) so please Kraftwerks don't tell me I will have to pay again for this, this is getting ridiculous.
It's my daily and I don't track at all with it. My tuner checked everything and the blower def. failed on its own.
He even called you and sent you a video, but again no feedback...
EquiFox is offline   Reply With Quote
Old 09-09-2015, 05:10 PM   #3589
itsibarra
itsibarra's Avatar
Drives: Supercharged Car
Yikes, two rotrex units within 1600 miles? Are these the standard size or the bigger C38-81?
itsibarra is offline   Reply With Quote
Old 09-10-2015, 09:24 AM   #3590
EquiFox
First one lasted 5000 miles and second one 1600. Standard C30-94 kit. All oil lines are good and everything was checker by my tuner... whine like crazy so annoying I drive my beater now.
Old 09-10-2015, 09:33 AM   #3591
Freeman
Freeman's Avatar
Kraftwerks Supercharger Owners Thread
Anyone in here have the new size pulleys for the C30 and know what boost you're hitting at redline? I swapped over to the new pulleys and just got a chance to open it up... Boost on the old ones was ~11.5 and on the new ones I'm seeing between 9 and 9.5. Hoping this is due to the pulley change and not another bad blower, but it does whine very loud....
Old 09-11-2015, 11:48 PM   #3592
vgi
Drives: frs
@EquiFox i would change a tuner and recheck installation - all the lines, filter, and oil reservoir - if i'm not mistaken have to be below or at SS level, ss was primed properly, belt tension is correct, no leaks, etc,, as i find it hard to believe, although not impossible, that 2 SSs failed one after another.
vgi is offline   Reply With Quote
Old 09-17-2015, 12:31 PM   #3593
rj101592
Drives: 2013 scion frs
Question for you guys.. after driving my buddys frs (vortech SC) mine feels a bit sluggish compared to his. I made more and am running more boost though. Thoughts?
rj101592 is offline   Reply With Quote
Old 09-17-2015, 12:34 PM   #3594
Freeman
Freeman's Avatar
What are the mod lists for both cars? What do the Dynos look like?
Old 09-17-2015, 12:54 PM   #3595
rj101592
Mine- Tomei uel header, berk overpipe/catted midpipe/invidia n1 catback..c30 13psi 311whp/221tq
His- Borla Uel/not sure on the rest of his exhaust.. Vortech SC, 9psi, 298 whp
Old 09-17-2015, 03:33 PM   #3596
Dadpool
Drives: 2001 Audi A4 (B5) & 2015 FR-S RS1
Both on pump?
Sent from my SAMSUNG-SM-G925A using Tapatalk
Dadpool is offline   Reply With Quote
The Following User Says Thank You to Dadpool For This Useful Post:
Freeman (09-17-2015)
Old 09-17-2015, 05:22 PM   #3597
rj101592
Yup, 93
Old 09-17-2015, 06:52 PM   #3598
InTune FRS
InTune
InTune FRS's Avatar
Drives: FRS Release
Check valve
Just installed the kit went in great and any question I was able to get someone on the phone pretty quickly. Are most people using the one way check valve that goes in the pcv line. Also tune wise is it worth getting another tune instead of the carb?
InTune FRS is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
