Old 06-03-2012, 11:25 AM   #1
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Customizing BRZ Navigation Start Up Screen
GrimmSpeed DIY Guide Series
Customizing BRZ Start Up Screen
Updated 6/3/12
Introduction: This guide will step through how you can setup your BRZ navigation screen to display a custom image upon startup.
Tools: The tools listed below are suggested for this task. Optional tools are noted.
- Computer
- Image editing software
- SD card and card reader
Tips: If you’re having trouble with image sizing, try downloading the sample that I’ve uploaded and use it as a template.
Procedure:
1. Begin by deciding what you want your Start Up Screen to look like. I’ll be using the basic GrimmSpeed logo, but you could use anything. Find this image and save it somewhere where you’ll find it.
2. Now, open your image editing software and create a hi-resdocument that has a 16:9 aspect ratio. This will be hi-resolution and the correct aspect ratio for the navigation screen.
3. Edit this image to your liking, adding logos, pictures, etc. Save it as a .JPG in a place where you’ll find it.
4. Now, save this image to your SD card. Note that you shouldn’t modify the OEM SD card used for maps, so you’ll need your own card. You don’t need much space, so if you need to buy a card, it shouldn’t cost an arm and a leg.
5. Now that you’ve got your custom Start Up Screen saved to the SD card, get into your car and turn the key to the ON position. Remove the OEM SD card and set it aside. Insert your own SD card and wait for the prompt.
6. The system will begin browsing your card. You can hit the menu button to use the menu on the right hand side to navigate to the directory where you’ve saved your background. I didn’t bury mine in any folders (Root Folder), so it popped right up after I hit ‘Search’. I suspect that the other file with a smaller file size is a thumbnail or something. I selected the larger of the two.
7. Select your file and then touch the image preview on the left to make the image full screen.
8. If you’re happy with the result and your image is displaying correctly, touch the screen again to bring up the menu.
9. Simply touch the ‘Start Up Screen’ button and confirm that you want to overwrite the Start Up Screen. Leave the key in the ON position while the image loads and then you should be all set! Turn the key to the OFF position, swap the OEM SD card back into the system and then turn the key back to the ON position. Your new custom Start Up Screen should display!
All set! Please don’t hesitate to ask for help. We’re always happy to do what we can! Also, if you have additions or corrections, let us know and we'll update the write up; we're all in this together!
- Matt
GrimmSpeed is offline   Reply With Quote
The Following 73 Users Say Thank You to GrimmSpeed For This Useful Post:
ajay (06-06-2012), baldolera (06-16-2012), BareZ (03-07-2016), BRZBlack (01-26-2014), buzznasa (06-06-2012), carma143 (10-07-2014), chanomatik (07-10-2013), chas3wba0 (01-18-2014), ChilOut (06-28-2014), chimera118 (02-21-2013), Choco (01-21-2015), Deslock (06-06-2012), Dimman (06-10-2012), ducatichick (12-11-2012), DyoGTS (06-05-2012), ESBjiujitsu (06-05-2012), Flow (08-01-2014), ftc~brz (04-16-2013), Ganthrithor (03-18-2013), Guff (06-05-2012), hakkoo (04-19-2013), hav0c (07-22-2012), imprttuner2 (08-26-2015), JakeG (03-05-2014), Jayde (06-03-2012), JC0830 (03-10-2014), joshua (06-15-2012), JS + BRZ (01-27-2014), kgc (09-06-2012), kwood9000 (06-03-2012), LeeMaster (02-12-2013), Lighting Red (06-06-2012), Longhorn248 (06-05-2012), loogs (07-02-2013), Marchy (05-24-2013), mattyd97 (11-02-2015), mechaghost (06-05-2012), Meehow86 (03-21-2013), meWant (10-28-2012), mission2toilet (04-13-2014), MJones_RB (04-11-2016), Motopythons (06-04-2012), Mr. J (11-13-2012), muffinz (10-16-2013), NoVtec (06-03-2012), NYC BRZ (06-05-2012), paaji (10-27-2012), percyng (06-27-2012), PoorMansRacing (11-20-2013), Prava (06-03-2012), R2RO (06-23-2013), racecaresuaceb (03-20-2013), RazBRZ (10-05-2012), re-animator (08-25-2017), Ricks919 (01-03-2017), RRnold (06-04-2012), Sato Tatsuya (06-05-2012), Screw Loose Dan (12-05-2013), ShoGun (06-19-2012), Snoopyalien24 (06-06-2012), Sportsguy83 (10-05-2014), Streetice (06-07-2012), suaveflooder (11-10-2013), Tbxgz (06-05-2012), tranat (05-20-2013), tripjammer (01-20-2013), ttknf (06-05-2012), unsurety (08-16-2014), VictorKassil (05-02-2014), xc (06-05-2012), Yamaha_R6 (03-28-2014), ZeHeadBanger (01-07-2014), ZetaVI (06-03-2012)
Old 06-03-2012, 11:37 AM   #2
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Nice job. I like it.
Old 06-03-2012, 11:39 AM   #3
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Good walkthrough. Credits to Perrin for doing it first But again, great walkthrough!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-03-2012, 11:56 AM   #4
GrimmSpeed
GrimmSpeed's Avatar
Haha, I suspect someone at Subaru did it before them, so I'll credit page 282 of the user's manual.
- Matt
The Following 10 Users Say Thank You to GrimmSpeed For This Useful Post:
chanomatik (07-10-2013), Choco (08-28-2014), ESBjiujitsu (06-05-2012), Keenercarguy (06-06-2016), LeeMaster (02-12-2013), Okami (05-08-2014), PoorMansRacing (11-20-2013), SkAsphalt (08-17-2012), StarsGarrador (07-03-2012), wendy86ramos (12-30-2016)
Old 06-03-2012, 12:34 PM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
- Matt
Well I meant posting it here
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-03-2012, 04:09 PM   #6
GrimmSpeed
GrimmSpeed's Avatar
Ohh, I see, I didn't see it. Maybe move it to the DIY guide section?
- Matt
Old 06-03-2012, 10:15 PM   #7
EmilGH
FIA Licensed Rally Driver
EmilGH's Avatar
Drives: Lots...
Send a message via ICQ to EmilGH Send a message via AIM to EmilGH Send a message via MSN to EmilGH Send a message via Yahoo to EmilGH
Here's a few startup screens that I'm thinking of using…
The storm trooper seems appropriate for a white car.
EmilGH is offline   Reply With Quote
The Following 4 Users Say Thank You to EmilGH For This Useful Post:
GrimmSpeed (06-04-2012), Jayde (06-03-2012), MannyO (06-03-2012), NYC BRZ (06-05-2012)
Old 06-03-2012, 10:43 PM   #8
NoVtec
NoVtec's Avatar
Good DIY post!
NoVtec is offline   Reply With Quote
Old 06-03-2012, 11:22 PM   #9
Jayde
Jayde's Avatar
Nice write up and post!!! Curious, but is it possible to reset it back to normal?
Jayde is offline   Reply With Quote
Old 06-04-2012, 12:35 AM   #10
GrimmSpeed
GrimmSpeed's Avatar
Those are awesome, thanks Emil! That last one is my favorite for sure.
Justin
Old 06-05-2012, 12:10 AM   #11
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
Stupid question here.
So once it overwrites and you save the start-up screen it will continue to show up once you pull out your SD card right? Or do you have to have the SD card in at all times?
ihaskrayon is offline   Reply With Quote
Old 06-05-2012, 12:37 AM   #12
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It'll continue to show up after you put the NAV SD Card back in.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-05-2012, 02:57 AM   #13
ihaskrayon
The Comedian
Thanks, I just noticed the SD card in the photo at the end of the write up. I assumed it would save.
Old 06-05-2012, 05:42 AM   #14
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
has anyone tried using a .gif instead of .jpeg?
Im considering possibilities of adding startup animations vs stills
WingsofWar is offline   Reply With Quote
The Following 2 Users Say Thank You to WingsofWar For This Useful Post:
Snoopyalien24 (06-06-2012), sweeney208 (03-17-2013)
BRZ Navigation Audio Run Through F1point4 Electronics | Audio | NAV | Infotainment 84 10-14-2012 11:20 AM
ft86 track video with some cool on screen displays ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 05-10-2012 02:03 AM
BRZ Navigation System Guaruja BRZ First-Gen (2012+) — General Topics 15 04-13-2012 08:52 AM
New Here (Navigation Option Question?) Jokester Scion FR-S / Toyota 86 GT86 General Forum 36 02-19-2012 08:25 PM
Gorgeous GT5 screen shots of FT-86 !!! Axel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 10-29-2009 12:58 PM
