Old 09-07-2015, 02:20 PM   #267
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Originally Posted by Elliryx View Post
Let me apologize for starting this fire storm! When I first got the car there was a Manual and Auto available at the dealer both brand new. I was with my wife, I wanted manual but my wife doesn't like to be driving manual so I decided to get the automatic tranny one. A week later I started having doubts even called the dealer if i could swap it with manual. 3 weeks after purchase I have trd exhaust, opti coat, suntek full hood, bumper fenders all installed. Theres no turning back now. Again i'm coming from a married man stand point ok. (the saying happy wife, happy life). I drive the car in manual mode and use the shifters it feels great regardless of AT or Manual we all know the twins lacks of power. Finally after weeks of reading probably an extra months more of reading I'll have either fullblown or vortech installed that should resolve my problem. Its just that doesn't mean its an automatic it can't be fast. I say with a turbo/supercharger + bolt on upgrades with e85 it should do the trick. Again this thread has been fun somehow.
Good to hear you got the Opti Coat Pro and Suntek Clear Bra done. Like you I drive in manual mode and use the paddle shifters. Looking forward to seeing some pics of your car with the Opti Coat.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 09-07-2015, 02:24 PM   #268
Elliryx
FT86
Elliryx's Avatar
Drives: 2015 FRS Ultramarine
Sure will. I'm just being really occupied deciding which one to get for the turbo. Didn't know that theres so many haters here.
2015 FRS Ultramarine 8/20/15
TRD Exhaust System | Suntek | Opti - Coat | K&N D.I.F
Future mods: Vortech or Fullblown! Need to more then read some more.
Elliryx is offline   Reply With Quote
Old 09-07-2015, 02:29 PM   #269
Bergen23
Drives: '15 Halo FR-S
If it engine blows up probably theyll say it because of the turbo. If you run it @7 psi chances of it blowing is less than running it @9 psi or higher. You drive it with or without it type of thing.
Has nothing to do with psi. Has more to do with a tune.
Bergen23 is offline   Reply With Quote
Old 09-07-2015, 02:34 PM   #270
Elliryx
FT86
Elliryx's Avatar
I was told that with 7psi I shouldn't have a problem with it coming from fullblown and vortech.
Thats another problem to worry about. But if i have to go out of state to get a very shop that will install and tune everything I would to make sure everything goes well.
Old 09-07-2015, 10:26 PM   #271
jaycee842
jaycee842's Avatar
Drives: FRS
Haters? Where? I don't see any...
Sent from my MotoE2 using Tapatalk
jaycee842 is offline   Reply With Quote
The Following User Says Thank You to jaycee842 For This Useful Post:
Ultramaroon (09-08-2015)
Old 09-07-2015, 11:44 PM   #272
Elliryx
FT86
Elliryx's Avatar
here is the closing argument to this auto vs manual.
In the case of the BRZ/FRS, both transmission are full 6 speeds, and AT has a rapid and accurate and very predictably timed paddle/stick up-down operation.
Not just in canyon or open winding roads, but on the race track, both transmission do have very good capacity to do what the driver needs to do.
The gear ratios are slightly different at the base 1-4th, and drastically at 5 and 6th, but for almost any racing under 100mph, 5th and 6th are pretty much not used, and becomes a cruising gear for the highways. The Manual retains the close ratios all the way to 6th for the reason if anyone built an actual dedicated race/track car, they are free to use different final drive gear and tire diameter and still retain the extra room in taller gears, but left as-is, it's very close.
What it boils down to is that they are only different in controls on how it shifts, not why or where. And that difference is the biggest factor for the driver to be proficient in either systems. And that mechanically, there are variables like course layout and asphalt, inclines of the road, and tire capacity, which all just has to meet somewhere to define the actual capability and differences can be good or bad in any given road.
If only for the speed of the two cars with different transmissions, there isn't one faster than another. Biggest variable is the driver proficiency, and where the lap is being run.
Driving experience can be a matter of personal choice and most purists do prefer the driving experience of a manual, but that being said, the Semi-Auto AT in the FRS/BRZ does assist the drivers who do not have the accuracy and refined focus of a veteran motorsports driver. What's faster is exactly, what is faster for the DRIVER in question. I post almost the same lap-times given no other variables, with Manual being slightly more edgy on top times in most places, but also more inconsistent due to it being a machine more prone to errors by the driver. I chose the AT for my first FRS, after 22 years of racing on the track, I felt this was a better overall road car for daily use, with not much lost to fun on the tracks, with 5th and 6th being taller to provide more economy and quieter highway cruising. But it does not mean my #2 and #3 cars will be a Auto, and I intend to have many more of them over the years to come. Definitely in the sweet manual transmission too.
For all intensive purposes, we can no longer classify the full 6 speed semi auto here as anything slower than a manual in the FRS. So the choice is more open for even the hard core enthusiasts. And the preference is down to what fits your usage and feel.
The ONLY "con" here, is if you don't know how to drive a manual well enough to post a lap-times you can set with an AUTO, then you NEED to buy a manual so that you can be proficient a driver, as you want to tout to be in the future, especially in an FRS/BRZ. If you are fast with either, the choice is yours to make.
-- Moto Miwa, Club4AG
The Following 6 Users Say Thank You to Elliryx For This Useful Post:
86geek (09-08-2015), dre208 (09-09-2015), drewbot (09-08-2015), FRed-S (09-08-2015), Hoahao (09-08-2015), Mini&aVette (09-09-2015)
Old 09-08-2015, 12:34 AM   #273
FRed-S
FRed-S's Avatar
Drives: 2015 Scion FR-S
Please God, let this be the closing argument lol.
Sent from my XT1254 using Tapatalk
FRed-S
FRed-S is offline   Reply With Quote
Old 09-08-2015, 12:56 AM   #274
funwheeldrive
TLDR: Automatic transmissions suck.
The Following User Says Thank You to funwheeldrive For This Useful Post:
joe strummer (09-08-2015)
Old 09-09-2015, 12:29 AM   #275
Elliryx
FT86
Elliryx's Avatar
http://www.ft86club.com/forums/showthread.php?t=6485 coming from a guy that knows what he is talking about.
Old 09-09-2015, 12:37 AM   #276
jaycee842
jaycee842's Avatar
Drives: FRS
Did he really say he thinks the FRS is more impressive?? Wtf...
Old 09-09-2015, 01:29 AM   #277
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
*intents and purposes
ineedyourdiddly
The Following 5 Users Say Thank You to strat61caster For This Useful Post:
Atticus808 (09-09-2015), drewbot (09-09-2015), SisterBlue22 (09-09-2015), soulreapersteve (09-09-2015), Tcoat (09-09-2015)
Old 09-09-2015, 10:07 AM   #278
KellieRahne
It's pronounced "Rain"
KellieRahne's Avatar
Drives: 2013 Firestorm 6MT
This thread is awesome. I wish that I had found it sooner.
I want to be the girl with the most cake.
KellieRahne is offline   Reply With Quote
Old 09-09-2015, 10:52 AM   #279
Be easier if it just automatically popped up when you logged in but it is more fun when you find it manually.
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
Atticus808 (09-09-2015), Bergen23 (09-09-2015), Dadhawk (09-09-2015), drewbot (09-09-2015), KellieRahne (09-10-2015), shiumai (09-09-2015), soulreapersteve (09-09-2015), Ultramaroon (09-09-2015)
Old 09-09-2015, 11:15 AM   #280
jaycee842
jaycee842's Avatar
Drives: FRS
You win. I can't even...😂😂
Tcoat (09-09-2015)
BC Coilover settings you guys guys ride on g0lden Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-06-2014 06:56 PM
Buyers remorse? Hardrock4445 Scion FR-S / Toyota 86 GT86 General Forum 14 01-14-2013 03:25 PM
Anyone had 86/BRZ buyers remorse? :) Maj3sty AUSTRALIA 40 11-10-2012 03:14 AM
Buyers Remorse? IntotheOcean Scion FR-S / Toyota 86 GT86 General Forum 134 10-31-2012 03:37 PM
