#57 | |
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Oh I definitely get that but my experience with what's being reported isn't as extreme as some of you make it out to be. I could only describe it as a hard shift where the car noticeably moves forward with the shift but as of now, there's zero negative consequences with it. I've had it happen to me at the top of 4th gear pulls while on track and the car just continues on.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8 |
#58 |
What license?!
Drives: 2015 Scion FR-S
I get this "hard shifting" all the time in D...but I just keep telling myself that TURBO will fix this so ill just deal with it
...Got 15 FRS on December 2014, currently 14K |
#59 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
Sent from my A0001 using Tapatalk |
#60 | |
What license?!
But its just how I keep my mindset as I don't think about this issue again.
#61 |
Drives: Scion FR-S, Ultramarine
It seems to me like everyone is blowing this "issue" way out of proportion. Ive had my car for 3 years now, and I always get hard shift every now and then, and usually its in low/mid rpms.
Im sure its the TCU undergoing hard shifts (as its programmed to do) during a less than ideal throttle position/rpm range for that type of shift. I dont really see an issue with it. My car still downshifts flawlessly, and upshifts flawlessly when i need it to. |
#62 | |
Agree. Sent from my iPhone using Tapatalk |
#63 | |
Drives: '15 Halo FR-S
#64 |
Drives: 2015 Scion FR-S AT
#65 | |
#66 | ||
#67 | ||
Me and Bergen23 have had this issue for quite some time however it is completely non existent when the car is started out in manual mode outright
#68 | |
Yes, it idles weird when this issue appears
#69 |
I've found a link between using cruise control and then switching to manual mode. If I don't use cruise, I don't have a problem. If I do use cruise, then I get the shitty downshifts. Do me a favour please, and go out and put your cruise on above 80kmh (50mph) for a little bit, then switch to manual mode and try your downshift. If it happens then, I think we could be on to something.
#70 | |
Will do problem is I don't see the car for several weeks, I still haven't installed that TCM unit I bought off eBay either and I see no one has one installed or had it replaced either. The last several weeks I drove it before leaving for college there were no issues whatsoever took it on some really good roads and drove it quite hard and the issue never appeared once. I will try the cruise control trick however does the issue occur after holding the throttle in auto mode above 50 mph without cruise control as well?
| Tags |
| automatic, hard, issues, shifting, transmission |
| Hard shifting into first gear; normal? | blalor | Engine, Exhaust, Transmission | 54 | 08-31-2017 09:57 PM |
| AT transmission hard shifting issues | calic | Issues | Warranty | Recalls / TSB | 44 | 11-09-2015 06:17 PM |
| 3 min fix for 2nd gear hard shifting | Black Tire | Engine, Exhaust, Transmission | 22 | 03-23-2014 12:13 PM |
| Transmission noise when up shifting after hard rev | 1Cor10:23 | Engine, Exhaust, Transmission | 2 | 09-03-2013 03:22 PM |
| Hard shifting into 2nd gear when cold | BMWDavid | BRZ First-Gen (2012+) — General Topics | 35 | 06-24-2012 02:22 PM |
