CANADA Canada
Old 09-04-2015, 08:18 PM   #15
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by protpibe View Post
What kind of level are you guys got hot lapping your cars at that camber is your weak link? Lol
Any level of lapping would benefit from more negative camber
your tires will wear much better, more grip, faster laps, etc
drewbot is offline   Reply With Quote
The Following 3 Users Say Thank You to drewbot For This Useful Post:
1Cor10:23 (09-04-2015), Bergen23 (09-05-2015), wparsons (09-04-2015)
Old 09-04-2015, 08:41 PM   #16
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
Camber makes a huge diff in tire wear alone making it worthwhile from a cost perspective. This car benefits quite a bit from new camber for extra grip at any level as @drewbot suggests.
Sent from my SM-N920W8 using Tapatalk
1Cor10:23 is offline   Reply With Quote
The Following 2 Users Say Thank You to 1Cor10:23 For This Useful Post:
Old 09-04-2015, 09:42 PM   #17
wparsons
wparsons's Avatar
With the stock alignment (0*) up front, front grip is a big weak link.
Camber should be set to evenly distribute load across the width of the tire, stock is VERY lacking.
As to your original question:
[ame="https://www.youtube.com/watch?v=4XAwMP9Hnu8"]CTMP DDT - Lapping with Hanson International - YouTube[/ame]
I'm currently sitting at -2* all around, but could use another degree up front to even out grip and balance.
flickr
Old 09-04-2015, 09:56 PM   #18
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
School me on camber adjustments...
Sorry, I didn't do a good job phrasing my question. I know what camber is and its effects, I was more or less curious what the OP was using the car for. Unless you're competing in time attack or other timed events, I was politely asking what's the point? I recently did a bit of a rethink when it came to my suspension settings after I realized I spend about 180 days daily driving my car and maybe 3 or 4 afternoons tracking it (untimed)
Not ragging on anyone, I was just curious to what others thought
Edit: and I'm not trolling, I was genuinely curious if a degree or so of neg camber is that noticeable on stock suspension and tires
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 09-04-2015, 11:37 PM   #19
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
For track use, as mentioned already, helps with better wear on the tire, better grip, better everything.
Plenty of tread remaining on the inner half, but the outer half really took a beating.
Mike
tanner is offline   Reply With Quote
Old 09-05-2015, 10:05 AM   #20
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
I have the white line Comp-Cs knocking on my car and its allowed me to get some more clearance between tire and strut which is why I prefer it to just camber bolts. I talked to some people on an eastern European Subaru forum and they pointed me to a company called silver project based in Poland that has hand made camber plates for $150. Ordered them because why not and we'll see if they are a nice cheap solution to getting more camber in the front!
Canehda is offline   Reply With Quote
Old 09-05-2015, 10:55 AM   #21
Bergen23
Drives: '15 Halo FR-S
I noticed the 2-3* of camber I had on my previous wheel set up just on the street. It has a much sharper feeling when steering.
Bergen23 is offline   Reply With Quote
Old 09-06-2015, 10:23 AM   #22
wparsons
wparsons's Avatar
It is most definitely noticeable in grip and balance, plus it'll even out tire wear as well.
As for street wear, if you have zero (or near zero) toe, you won't see increased inner wear from a couple degrees of camber.
If you're in the -2* range, you'll probably get more even wear averaged out between street and track driving.
This picture is a pretty good illustration why you need more camber up front:
Even with minimal body roll (fully stock suspension, and alignment), you can see that the rear tire is pretty square to the pavement, while the front has gone well into the positive camber range.
flickr
Bergen23 (09-06-2015)
Old 09-06-2015, 01:12 PM   #23
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
I've driven about 15,000 km with -2 and now -2.5 on the front. Wearing pretty evenly.
The rears have a little inner wear though at -2.0 then -1.7. Sorta bummed that I didn't plan it out and get symmetrical tires so I can flip them.
This is 3 track days and 28 AutoX runs
Sent from my A0001 using Tapatalk
Old 01-13-2016, 01:43 PM   #24
RacingCanuk
Drives: 2018 Golf Sportwagen 4Motion Manual
Where do you all go for your alignments in the GTA? Who would you recommend to help achieve the best settings for track days with a completely stock suspension. I can't afford to replace control arms, install camber plates, etc on my car, but I've also learned my lesson by wearing the outside edge of tires on track days... a little negative camber goes a long way and is worth the price of a good alignment and the cost of things like 'crash bolts'.
RacingCanuk is offline   Reply With Quote
Old 01-13-2016, 06:42 PM   #25
wparsons
wparsons's Avatar
There's zero camber adjustment stock, so you're going to have to buy some parts if you want to change anything.
flickr
Old 01-14-2016, 11:05 AM   #26
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I managed to get -1.1 in the front on my whiteline bolts on stock struts and eibach sportlines, but it appears to vary car to car.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 01-14-2016, 11:14 AM   #27
Cole
Not a troll
Cole's Avatar
I just put an order in for these. Did you ever end up installing them? If so, how were they?
Cole is offline   Reply With Quote
Old 01-14-2016, 11:56 AM   #28
D_Thissen
D_Thissen's Avatar
They look really nice! How much was shipping? @Cole
Can someone school me on camber bolts lol scottxnizzle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 03-09-2015 09:19 PM
Pedal adjustments supramkivtt2jz DIY (Do-It-Yourself) Guides 3 03-31-2013 05:56 AM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 09:10 PM
Ridge Racing School; Lapping/school Sept 7th rice_classic Northwest 4 09-05-2012 01:27 AM
Pedal Adjustments? djliquidsteele Engine, Exhaust, Transmission 3 06-09-2012 10:43 AM
