#15 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
I had a clunk too and it was due to the endlink nuts being loosened by the bars movement. Turns out I forgot about the washers and after installing them, I haven't had any noises.
#16 | |
Drives: 2013 DGM BRZ Ltd
After months of insanity trying to figure out intermittent clunking and creaking, I finally realized that the endlinks whiteline specifies for our cars are too long with the ST coilovers. So I ended up buying shorter adjustable whiteline endlinks and now nothing clunks whatsoever. Double check and see if your swaybar hits the LCA when the suspension is in full droop. That is what made me realize there was a problem. |
| The Following User Says Thank You to muffinz For This Useful Post: | smg1138 (04-12-2016) |
#17 |
Drives: Honda Civic Type-R FK2
It's got lots of clearance from the LCA arm. My problem was the bolts got loose, after I re-tighted them the clunk got away. If it happens again I just add some locktite to them to keep them in place.
#18 |
Drives: red frs
Been driving me nuts too..
whitelines end links with the Hotchkis bar upfront. I haven't found my clunk yet because I swore it was a top hat issue. I will check end links tomorrow. |
#19 |
Drives: 2015 FR-S Release Series 1.0
Ahhh, I have this annoying clunk too! I installed RCE Yellow springs on the car and the whiteline adjustable endlinks. Thinking of just going back to the stock links if I can't figure out the problem cause the clunk is driving me crazy.
#20 |
Did you install the endlinks with the car on the ground? I re-installed them that way since there's no stress on the endlinks and the clunk have been gone since then. Some people seems to have problem with the bolts loosend up after a while but that should be cured with some loctite.
#21 | |
Drives: '13 BRZ Ltd
It might not have been OP's issue, but any KW-based coilover changes the distance from the endlink mount to the strut mount, so a shorter endlink is usually needed. In addition, the WL bar is shaped differently than OEM, which is why the WL bars come with their own endlink to begin with. For my KWv3 and WL bar combo, the endlink that came with the WL bar was too short, so I got a shorter set of WL endlinks.
What I posted in another thread: Quote:
| The Following 4 Users Say Thank You to Wepeel For This Useful Post: |
#22 |
Drives: '23 BRZ Limited
I throw blue loctite on ANY suspension bolt that comes off (when it goes back on).
#23 | |
#24 |
I got my car up on a ramp lift so could work under it. For the upper mount I managed to squeeze my hand through the wheel.
#25 |
Drives: 2015 BRZ
Im happy to have found this post. After installing my Skunk2 coilovers I have had a terrible time with the suspension on the BRZ. To the point where I was seconds away from taking the loss and putting everything back stock.
First issue encountered was the movment noise. I could be traveling slowly on a flat road and it would occur. I would call it a "pop" but honestly it sounds more like pulling different sized suction cups off a glass window. Only in the rear however. I also had body roll issues so I ordered Whiteline links and P-Tuning sway bars. Fixed the body roll issue but man the noise in the rear was amplified and occured twice as often. I'll purchase some ramps today and adjust the Whiteline links with load on the chassis. I really hope this works. |
#26 |
Drives: Toyota 86
i joined the forum just to say i have this problem too cant work it out. Please help..
#27 |
Formula GP~/~
Drives: 13' Brz Limited
When you guys adjust the endlink with the car on the ground are you putting one bolt in on the sway bar side and leaving the top off? or vice versa..Thanks
#28 | ||
Drives: Toyota GT86
If you have access to two jacks, it's much easier to do it with the wheels off. Keep the car on jack stands. Then put a jack under each upright (hub) and lift the car both sides just enough till the suspension compresses and and you take the load off the jack stands.
| The Following User Says Thank You to Tor For This Useful Post: | bhmax (01-19-2019) |
| *Sway-Bars/Endlinks/Brakes: Whiteline/Perrin/RCE/AVO/Cusco/DBA/Carbotech/Hawk/@Oakos* | OAKOS Automotive | Brakes, Suspension, Chassis | 157 | 03-01-2016 11:31 AM |
| FS OEM front&rear sway+endlinks | bjun | Brakes, Suspension, Chassis | 7 | 11-15-2014 02:09 AM |
| Eibach Multipro R2, Strano Front Sway Bar with Whiteline Endlinks, Hawk HPS Pads | Eric1855 | Brakes, Suspension, Chassis | 1 | 04-21-2014 08:33 AM |
| Whiteline 20mm front sway and endlinks | JRTritsch | Brakes, Suspension, Chassis | 3 | 04-07-2014 11:27 PM |
| Front Sway Bar endlinks | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-30-2012 05:14 PM |
