Old 09-02-2015, 12:35 AM   #379
blown
Drives: ft86
almost........... had some clutch issues....
blown is offline
Old 09-02-2015, 12:53 AM   #380
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Cool
Originally Posted by sam69 View Post
Any one else got their 335 up and running ??
Been very quite on this thread for a while
@DIE1000DEATHS is up and running and my install is planned for this month.
What happened? Are you still running the stock clutch?
Chad86 is offline
Old 09-02-2015, 04:59 AM   #381
smudge
Drives: Supercharged GT86
My 335 is being installed as I type this. Well, the engine build is happening at the moment before the 335 goes on
Had a 210 on a stock motor and decided to go for the HKS stroker kit and cams before putting the 335 on. Should have some updates in the next week or so
smudge is offline
The Following 2 Users Say Thank You to smudge For This Useful Post:
Chad86 (09-02-2015), sato (09-05-2015)
Old 09-02-2015, 05:03 AM   #382
smudge
Originally Posted by stockysnail View Post
If I do upgrade but want to sell my 210, what parts do I need to make the 210 into a complete kit again and how much would it cost? I'm considering upgrading early next year after tax returns come in.
I sold my 210 kit and replaced it with a 335
I basically bought a new 335 kit and just gave the buyer of my 210 kit the following:
- old 210 charger
- old 210 plastic inlet pipe
- old pulley on 210 charger
And then all the new pipes, wires, intercooler etc from the 335 kit. So I've got my existing 210 setup, basically without the charger, ready for the 335 to be put on top
smudge is offline
Old 09-02-2015, 12:55 PM   #383
stockysnail
Just the tip
stockysnail's Avatar
If you could provide all the parts that you're using to do your engine build that would be great. Hope it's insanely fast for you.
stockysnail is offline
The Following User Says Thank You to stockysnail For This Useful Post:
Chad86 (09-02-2015)
Old 09-02-2015, 01:11 PM   #384
smudge
List of mods (so far) I put up in another thread the other day:
- Sprintex (Innovate) 210 supercharger kit
- Replaced by Sprintex (Innovate) 335 supercharger kit
- Borla UEL manifold
- Cobra overpipe
- Berk high flow cat front pipe
- Invidia Q300 catback with custom midpipe
- Sti front lip
- Bottom line side diffusers
- Sti rear bumper caps
- 18" Rays Gram Lights 57DC's in custom colour
- 18" WedsSports TC-105N's
- 18" Japan Racing JR-11's
- HKS Hipermax GT IV coilovers
- Summit rear camber arms
- Summit rear toe arms
- Adjustable drop links front and rear
- Impreza 16mm rear anti-roll bar
- Custom painted interior
- Blitz gauge pod with 3 Prosport digital gauges
- Sti engine mounts
- Sti gearbox mount
- HKS air intake
- HKS panel filter
- 362mm 6 pot AP racing front brakes
- 08+ Impreza Brembo rear brakes
And as I type this I'm currently installing:
- HKS 2.1l stroker kit
- HKS cams
- Lightweight flywheel
- Stronger, lightweight clutch
- 500cc injectors
- Walbro fuel pump
- Setrab oil cooler
- 3bar map sensor
- Mtec shifter springs
And probably some other bits I've missed...
smudge is offline
The Following 4 Users Say Thank You to smudge For This Useful Post:
Chad86 (09-02-2015), DIE1000DEATHS (09-03-2015), sato (09-05-2015), stockysnail (09-02-2015)
Old 09-02-2015, 03:31 PM   #385
stockysnail
Just the tip
- Cobra overpipe
- Sti front lip
- Sti engine mounts
- Sti gearbox mount
- HKS air intake
- HKS panel filter
- HKS cams
- 500cc injectors
- Walbro fuel pump
- Setrab oil cooler
- 3bar map sensor
Interesting stuff. Quite a bit different than my build.
Old 09-02-2015, 08:35 PM   #386
Chad86
Chad86's Avatar
Drives: Toyota GT86
Question
How much is the engine build costing you?
Chad86 is offline
Old 09-03-2015, 04:31 AM   #387
smudge
Remember that this is all in £ not $
Around £5k worth of parts, excluding the charger and about £3k labour
smudge is offline
Old 09-04-2015, 08:11 PM   #388
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
So here's something we've come up with based on our experience.
We don't recommend going below a 70mm pulley because at that point you're limiting the rev range of the motor if still keeping the SC spinning at reasonable levels. This is not going to be 100% for everyone, but designed to summarize our experience with pulley sizes and knock counts based on application and fuel selection. With e85 you can spin the SC as much as you want, any of them. But stock rods can only hold so much, and there are some exhaust/intake limitations once you take the 335 to the 75mm pulley or smaller. Until that's addressed it isn't really necessary unless you're at elevation or running a built motor. Every 1000 feet of elevation gain can be thought of as going down 1mm in pulley size. So in Denver a 210 non IC on 91 octane can be spun on a 70mm pulley.
For CA customers on CA 91 octane, generally going UP in pulley size isn't a terrible thing. The heat reduction and allowance for extra ignition advance is usually a better thing then throwing more hot boost at it.
Xero-Limit is offline
The Following 8 Users Say Thank You to Xero-Limit For This Useful Post:
brianhj (10-21-2015), Chad86 (09-04-2015), diodelphi (09-05-2015), Dream20b (10-06-2015), Jonesy86 (09-04-2015), sam69 (09-05-2015), smudge (09-05-2015), stockysnail (09-04-2015)
Old 09-04-2015, 09:37 PM   #389
stockysnail
Just the tip
Thanks a bunch for your spread sheet. I like your new logo as well. Basically if I go 335, it would be wise to always run e85 otherwise I should get my engine up to forged status. I'm at 92oct 70mm intercooled, considering e85. There's one station within 5 miles of my work so as long as it doesn't close I'll be ok. Only thing I don't like about e85 is that it gets 5mpg or so lower so I'd have to fill up more often. It used to be a good amount cheaper as well which balanced out the cost of fueling up more often, but that's not the case anymore. Thanks again. I like data and spread sheets.
@Jonesy86 see the chart since you run e85/flex fuel and 72.5mm.
Old 09-05-2015, 11:43 AM   #390
smudge
Thanks Mike
Based on that I'll stick with my 75mm pulley on the 335
We don't get e85 in the UK best is Shell V Power which is 99RON which I think is the equivalent of your 93octane in the States?
smudge is offline
Old 09-05-2015, 10:02 PM   #391
SprintexUSA
SprintexUSA's Avatar
Drives: 2014 FT86
OT: Anyone going to SubieFest or 86Fest, please PM me.
SprintexUSA is offline
Old 09-07-2015, 08:34 AM   #392
smudge
@SprintexUSA
Are you aware of any issues with the 335 units? Just been told that mine may need some "slight adjustments" by the garage...
smudge is offline
500whp or bust, sprintex, sprintex 335
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 24 04-04-2014 02:38 PM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing TyperRspec789 Forced Induction 63 12-31-2013 07:39 PM
