Southern California SoCal
Old 09-01-2015, 05:02 PM   #309
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Originally Posted by LXXXV1 View Post
http://www.trdsparks.com/install/PTR03-18131inst.pdf
Make sure it comes with the 3 bolts/nuts. Removing the exhaust brackets may be a pain in the ass if you don't have the tool, unless you have strong fore arms. Also, fitting a torque wrench for midpipe to muffler will be difficult due to poor design.
Good luck. Pretty straight forward bolt on/off. I reused both my OEM gaskets, but I only had 1500 miles before I swapped. No leaks so far.
I was cheap and didn't want to buy special tools. I used channel lock pliers (only ones that could open wide enough) instead of an exhaust hangar removal tool. Grip the tip of the exhaust hangar, and the back of the rubber bushing and squeeze. Comes out with slight wiggling.
aegisdrgn is offline   Reply With Quote
Old 09-01-2015, 06:11 PM   #310
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
I am only concerned now, because I bought OEM midpipe to muffler gasket (2 bolt set up), and it looks like the TRD flange setup is three bolts.
V_86 is offline   Reply With Quote
Old 09-01-2015, 10:57 PM   #311
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Originally Posted by V_86 View Post
So I'm installing exhaust in the next couple weeks (used TRD). I ordered a new midpipe to to muffler OEM gasket, and I'll be reusing the front to midpipe donut gasket. Anything I'm missing?
Also, I know the front to midpipe should be torqued to 14.3, but what is the specs for the midpipe to muffler?
Will a wider mid pipe make it louder by chance?
Vincenttam is offline   Reply With Quote
Old 09-01-2015, 11:33 PM   #312
V_86
V_86's Avatar
Don't know. But the TRD uses stock piping size. I know the Perrin 3 inch is louder than the 2.5, so I would assume so.
Old 09-02-2015, 02:53 AM   #313
aegisdrgn
aegisdrgn's Avatar
Unfortunately, TRD D-tip exhaust uses pipes with smaller inner diameter than even the stock exhaust.
http://www.ft86club.com/forums/showp...2&postcount=59
Old 09-02-2015, 11:32 AM   #314
V_86
V_86's Avatar
This may not neccissarily be a bad thing, while in theory yes, smaller diameter means more restrictions, it also means the exhaust gasses stay hotter, which may mean a negligible difference if the gasses are moving faster because of the increased heat.
Old 09-12-2015, 02:37 PM   #315
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
ATTENTION: ANYONE who wants to learn how to do brakes/ brake lines and rotors install - i will be working on my car today after 4:30 and installing these parts
located in torrance, pm me or whatever
i could always use a helping hand.
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
LXXXV1 (09-13-2015)
Old 09-12-2015, 02:46 PM   #316
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Maybe I can stop by after I work! I get off at 630
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 09-12-2015, 03:50 PM   #317
VIC_BRZ
VIC_BRZ's Avatar
Drives: 2015 Subaru BRZ
Your R1 rotors finally came in , I'm down to stop by and learn some new stuff.
VIC_BRZ is offline   Reply With Quote
Old 09-12-2015, 04:10 PM   #318
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Yeah, give me a pm if your serious about coming down ill shoot you an pm
yeah the r1 rotors finally came lol
Flex Fuel Turbo BRZ
Old 09-19-2015, 07:33 PM   #319
ringo16
Drives: 15 Asphalt FRS
So I massively failed my first attempt at wrapping my taillights in red vinyl? So can anybody help me vinyl wrap my taillight?
ringo16 is offline   Reply With Quote
Old 09-19-2015, 08:32 PM   #320
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
goodluck, if you find someone to help you i would love to come by and see this performed. i want to wrap my food soon once my wing comes in
Flex Fuel Turbo BRZ
LXXXV1 (09-19-2015)
Old 09-19-2015, 08:34 PM   #321
ryoma
ryoma's Avatar
chicken wing wrap?
The Following User Says Thank You to ryoma For This Useful Post:
LXXXV1 (09-19-2015)
Old 09-19-2015, 09:09 PM   #322
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
LOL ROOF
Flex Fuel Turbo BRZ
