Old 09-01-2015, 09:06 AM   #1
solanum
Drives: Toyota GT86 - Sonic Blue
Advice on wheel/tyre size
I know there are umpteen guides here, but I'd just like a bit of advice based on others experience.
I have a stock 86 GT with the 16" wheels. Whilst letting the back end get a bit loose every now and then is obviously fun, I'm a bit fed up of the brake LSD flicking on when I pull out hard into traffic and even sometimes the slip indicator coming on if I change from 1st to second at 7,000+ RPM.
So I was thinking of getting slightly wider wheels and maybe 17-18" as well to improve on grip. Any advice on width and/or whether stepping up the wheel size to improve performance is worthwhile?
Note that I'm not after filling the wheel arch, just a bit more grip, and I don't find the ride all that hard, so don't mind loosing a bit of compliance due to lower profile tyres.
Thanks.
solanum is offline   Reply With Quote
Old 09-01-2015, 09:25 AM   #2
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
are you still using the stock tires? Change those first, good tires will make a massive difference.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
NyC Zn6 (09-03-2015)
Old 09-03-2015, 08:26 PM   #3
solanum
Yes I am. OK, maybe I'll just look at tyres to start with. Cheaper option for sure.
Old 09-04-2015, 02:41 AM   #4
makesdrivingfunagain
I am in the U.S. where 17x7 are oem . I went to a 16x7 wheel. I then upgraded to max performance summer tire with a 225/50/16 continental extreme contact dw. There was a HUGE improvement over the stock 215/45/17. This was a great street tire! I more recently changed to a225/50/16 Yokohama Advan Neova ADO8R. This has better traction but the ride is noticeably stiffer. I would probably just consider to upgrade to a extreme summer tire.
makesdrivingfunagain is offline   Reply With Quote
Tyre/Wheel rotation and wheel alignment for the 86? FT_86_SM_GP AFRICA 17 11-05-2015 05:01 PM
Tyre size and choice help BadLuckZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-17-2015 12:35 PM
Tyre size for 18x8.5 +44 F 18x9.5 +44 R diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-19-2014 04:44 PM
WTB: GTS wheel and tyre SYDNEY Toyota 86 GT Australia Classifieds 0 03-29-2014 01:15 AM
Wheel + tyre weight diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-30-2013 01:16 PM
