Old 07-01-2015, 04:08 AM   #197
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So I bought a used bumper to replace my slightly damaged one. With this other bumper I could not get the bumper to stay clipped in. I believe its because of the plastic mounting tab closest to the headlight.
Be careful when removing your bumpers. If you damage the tab on the bumper it will cause it to slip out. My original bumper does not have this problem and I've dismounted and remounted that thing more than a dozen times. I'm going to try to repair the tab on this second bumper I bought and let you guys know how it goes.
Old 07-02-2015, 12:37 PM   #198
G-awesome
Drives: 2015 Firestorm Scion FRS
I took my front bumper off for the first time to install my winjets and I didn't notice a big ugly gap when I reinstalled it. It doesn't look as flush as before with a very small gap if you look at it real close....but that was to be expected.
G-awesome is offline   Reply With Quote
Old 07-07-2015, 07:43 PM   #199
Cross
It's the Mad Cow
Cross's Avatar
So I just replaced all the clips and while one side seems better the other just will not stay.
I have taken it back off and made sure everything was lining up but the it doesn't seem to be holding. I am going to try playing with the headlights since that was another suggestion a few made but I am about to say screw it and use a zip tie.
Old 08-15-2015, 12:34 PM   #200
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Zip tie? Where?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-01-2015, 02:19 AM   #201
dj2020
Originally Posted by dkstylezz View Post
I used 1/4 threaded rod from home depot. I got one and cut it it was enough.
used 1/4 titanium drill bit and a smaller drill bit to get it going. After installing it and checking it does seem a whole lot more sturdier than from factory and you can adjust the nuts to get it where you want. i used washers and 2 nuts on each end. forgot what they were called they sell 1/4 size washers but slightly bigger maybe size of a quater or smaller. use them on the bottom of the plastic tray for a bit more surface support with bigger washer. I will update if i run into any other problems with my bumper, just got back from little tujunga canyon and seems to be fine for now.
tried to use the existing holes but there was no way to get behind it with a wrench to hold a nut on the passenger side. drivers side should be fine. also if you use the preexisting holes you would have to either modify the Styrofoam so fit with the metal rod or ditch the Styrofoam(don't recommend).
Is your threaded rod bumper fix still holding up? Also, what's the best way to bend the threaded rod? I'm thinking of doing this soon. Thanks!
dj2020 is offline   Reply With Quote
Old 09-01-2015, 06:22 AM   #202
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
Ended up going with the move over racing quick release latches. And now I have no gap what soever. The rods didn't really hold the bumper much. It did help but the tabs on my bumper were broken. So only option was to replace the bumper or get the latches. Latches were a pita to install tho if you want them looking symmetrical.
Sent from my SAMSUNG-SM-N900A using Tapatalk
dkstylezz is offline   Reply With Quote
The Following User Says Thank You to dkstylezz For This Useful Post:
dj2020 (09-01-2015)
Old 09-01-2015, 06:26 AM   #203
dkstylezz
dkstylezz's Avatar
Size:  21.2 KBName:  uploadfromtaptalk1441103200785.jpeg
Old 09-01-2015, 10:19 AM   #204
dj2020
Do you think any of your JRSC piping was not clearing the fog light housing/bumper? I don't know if you have pictures but which tabs on the bumper are you talking about? I only see the tabs on the black headlight brackets that are supposed to engage the 'loops' on either side of the bumper.
Old 09-02-2015, 02:46 AM   #205
dkstylezz
dkstylezz's Avatar
The Jr tubes are not in the way the bumper will fit proper until I drive it and it sees downforce. It pops back out due to the plastic loops or tabs that are on the bumper are broken and stretched. I don't have pix sorry. The rods will work if the loops and tabs are somewhat still functioning.
dj2020 (09-02-2015)
Old 10-09-2015, 12:30 PM   #206
Phaedrus29
Phaedrus29's Avatar
Has anyone used zipties to fix the bumper gap? I know this isn't an elegant solution but I'm wondering if it would actually work. Is there some place to actually tighten down some zipties (out of sight) to fix the gap?
Phaedrus29 is offline   Reply With Quote
Old 10-09-2015, 02:17 PM   #207
tonystewart
Excellent question!
Old 10-12-2015, 03:07 AM   #208
tracerit
Drives: '13 SSM BRZ Limited 6MT
Hmm this potential problem is discouraging me from installing my Perrin CAI. It's pretty much for sure the bumper will sag after it's been removed?
tracerit is offline   Reply With Quote
Old 10-12-2015, 01:35 PM   #209
kch
Senior Misanthrope
kch's Avatar
As with anything, your results may vary. The first time I took my bumper off it went back on without a problem. Second time it started to sag a smidge.
Old 10-12-2015, 03:45 PM   #210
tonystewart
Don't forget to rescale the MAF after installing the Perrin CAI/
Bumper and fender damage - Hit and Run 01s0uljah Cosmetic Modification (Interior/Exterior/Lighting) 40 12-24-2016 01:44 PM
Worn floor mats - Covered under bumper to bumper warranty? Philly758 Issues | Warranty | Recalls / TSB 45 08-19-2013 01:32 PM
Where to Buy Fender badges and bumper V light?? taimysho0 Scion FR-S / Toyota 86 GT86 General Forum 5 05-17-2013 04:31 AM
WTB: headlamps, fender garnish/cover/vent, and bumper reinforcement mariolefty1 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2013 04:52 PM
Need scratches/scuff marks buffed out of bumper or cheap bumper for sale [Cyanide] NY / NJ / CT / PA 12 12-28-2012 07:34 PM
