go_a_way1
Old 08-31-2015, 09:41 PM   #9381
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Namuna View Post
Also, is the fuse for the auto on/off supposed to be sticking up like this?
Yes to this. What is PWS because I'm slow today.
Installed Mods:
Old 08-31-2015, 09:55 PM   #9382
Namuna
Namuna's Avatar
The actuator thing with the lever that goes behind the accelerator and activates the ESC at partial and full accelerator presses.
Namuna is offline   Reply With Quote
Old 08-31-2015, 09:56 PM   #9383
Sojhinn
Sojhinn's Avatar
The bolt is there to just hold the nut that you need. That's all.
Installed Mods:
Old 08-31-2015, 10:00 PM   #9384
Namuna
Namuna's Avatar
Sorry, get my nuts and bolts mixed up...Let's try again...
Right now, behind the accelerator is just the bolt and a nut.
Do I now:
1. Remove the stock nut, place the PWS/Actuator and then put the stock nut back in and tighten, keeping the extra nut that was taped to the PWS as a spare/extr?
2. Put the PWS/Actuator ON TOP OF the stock nut and then use the extra not to tighten down the PWS/Actuator on top of the stock nut?
I hope that makes more sense.
Thanks.
Old 08-31-2015, 10:01 PM   #9385
Sojhinn
Sojhinn's Avatar
Do I now:
Thanks.
Ah. Use the nut on top of the existing nut. Are you using my install video? It helps a lot.
Installed Mods:
Old 08-31-2015, 10:23 PM   #9386
Namuna
Namuna's Avatar
Man, I watched your vid more often than my favorite porn!...But I just now see that it's your SECOND full install video that has the detailed install of the activation switch.
And another question, my kit doesn't have the drag reduction connection (no connection from the controller and no port off the turbine. I'm guessing this is normal for the v2.0 kits?
The Following User Says Thank You to Namuna For This Useful Post:
Sojhinn (08-31-2015)
Old 08-31-2015, 10:24 PM   #9387
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Doesn't need it for partial throttle. Also I never want that image in my head again.
Installed Mods:
Old 08-31-2015, 10:32 PM   #9388
Sojhinn
Sojhinn's Avatar
Pretty soon here im going to do a completely new install video from square one. The last one was a combination of a few videos.
Installed Mods:
Old 08-31-2015, 11:37 PM   #9389
Namuna
Namuna's Avatar
Thanks for all the help thusfar Sojhinn, much appreciated.
One more question, which OFT map file to use? I've gone to the OFT downloads page, but I only see an option for tune with OFH+ESC, but none for just the ESC.
http://openflashtablet.com/Automotiv...ads/index.html
Everything stock, unless stated otherwise...I've got FRS with: TRD Exhaust, Crawford BPBs and of course the Phantom ESC and will only be using 93octane.
Thanks.
Old 08-31-2015, 11:39 PM   #9390
Sojhinn
Sojhinn's Avatar
Thanks.
Do you still have the power bricks still on? You may lose power by keeping them on. As for the tune just use the one that's in the page for ofh + esc.
Installed Mods:
Old 08-31-2015, 11:54 PM   #9391
Namuna
Namuna's Avatar
Yeah, unfortunately still have the BPBs on.
Old 08-31-2015, 11:55 PM   #9392
Sojhinn
Sojhinn's Avatar
Run it with it at first just pay attention to your logs. I would recommend removing them and selling them when you can.
Installed Mods:
Old 09-01-2015, 02:16 AM   #9393
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Better mileage with the ESC
Originally Posted by Impureclient View Post
I read through 400+ pages when I first came in here a couple months ago but I don't remember reading if anybody using this had done before and after MPG averages. Can anybody with it on for a while give info on that? I am thinking more just driving normal kind of MPG as obviously with this on, the need to push the car harder probably just happens and skews the MPG.
I've wondered about this too. I'm able to average above 30 MPG only on certain tunes, and only with the boost very low. It's possible to get better city mileage using the boost to help accelerate, but the AVCS valve overlap is critical. I've tested, and proven, that the boost is still used when the cruise control is on, even though the throttle pedal shows zero. There is a temptation to just let the boost push a taller gear up highway hills just because it can, but better mileage is made at lower boost, so downshifting for hills is still recommended. I've been using mathematical gradients to compute profiles, and trial and error to find the maximum valve timing for best power and mileage. The OTS OFT tunes for the ESC are very close. They just need a bit more valve advance from .3 to 1.0 loads, and of course @Wayno's additions for maximum loads, cold starts, and radiator fan limits. I've posted my tunes and throttle maps to try to encourage others to refine and improve them. These cars use the most fuel accelerating just to keep up with traffic in the city, it should be possible to get better city mileage with the help of the ESC's boost to accelerate quicker and more efficiently. @Wayno has made it his mission to get better mileage with E85, and I'm making it my mission to get better mileage with the ESC.
KoolBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to KoolBRZ For This Useful Post:
Gums (09-01-2015), Impureclient (09-01-2015)
Old 09-01-2015, 07:21 AM   #9394
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I'm pretty sure I have posted it before but here is my calculated logs (installed ESC on 10/18/2014):
Gas MPG
12/23/13 27.5
12/24/13 31.2 - trip
01/09/14 25.3
01/28/14 24.9
02/17/14 23.5 - playing in snow
03/09/14 26.5 - changed tranny/diff oil/ disabled drl
03/31/14 26.1
04/20/14 25.8
05/12/14 26.5
05/28/14 26.6 - stg 1 flash, K&N installed
06/19/14 25.7
07/12/14 25.5 - batt relocation/reset
08/04/14 27.1
08/24/14 27.2 - stg 2 flash + OFH install
09/16/14 22.0 - stg 2 E85 flash with 2 gallons of premium left in tank
10/08/14 20.1 - 100% E85
10/25/14 20.4 - E85 with 1 gal 93, ESC WOT testing/logging
11/21/14 24.2 - 93 octane
12/14/14 23.4
12/23/14 19.1 - fill up for trip
12/25/14 31.3 - night trip, a few WOT passes
01/09/15 28.8 - night trip + city for a week
02/04/15 23.4
02/27/15 23.8
03/28/15 25.7
04/16/15 26.1
05/12/15 27.2
05/16/15 32.7 - city for a week + night trip
05/22/15 30.9 - city + trip + city
06/15/15 26.6
07/08/15 25.4
08/04/15 25.9
I actually see larger swings in MPG between summer and winter than before after the ESC (winter seems to drop my MPG a lot), *note this is single stage petal switch
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
