Old 08-29-2015, 10:17 PM   #1
AlexWood
Drives:
New rear tires. Car floats all over the highway
So I waited a little too long to get new tires and had one blow on me. Got it to a shop and they put 2 new tires on the rear just to get me by until I can get new wheels. I was driving home tonight on the highway and the car was floating all over the highway, to the point where I was scared to go any faster than 65. While trying to accelerate the car would violently pull to the left. My question is, is this normal behavior with this type of situation?
Some things to keep in mind:
They are cheap Firestone tires
The alignment was perfect before the new tires were installed
The front tires are going bad but not as bad as the rears were
I'm on BC coils lowered about 2inches
I was not there when they installed the tires/test drove the car
From what I can tell, they aren't a directional tire
Let me know what you guys think
Thanks
AlexWood is offline   Reply With Quote
Old 08-29-2015, 10:50 PM   #2
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
What does that mean? You had the alignment checked before the new tires were installed, or just that the car didn't wander as much as it does now?
Old 08-29-2015, 10:54 PM   #3
AlexWood
Drives:
No I didn't have it checked. It tracked perfectly straight though before. I could drive down the highway with no hands on the wheel without a worry, now I have to white knuckle it just to drive 65.
Old 08-29-2015, 11:17 PM   #4
jvincent
jvincent's Avatar
It sounds like you blew a tire while driving. If so, the impact probably messed up the alignment.
Old 08-29-2015, 11:18 PM   #5
venturaII
venturaII's Avatar
What model/size tire did you purchase, and have you ever had the car aligned before? If so, post up the specs and when it was. What are you running for tire pressure?
Old 08-29-2015, 11:39 PM   #6
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Any chance something got damaged by the blow out? It's a possibility that the alignment got messed up.
Were they actually new tires? (Asking since you said it was just to get you by). If they weren't new there's a chance that they are different sizes, which would also potentially cause pulling sideways.
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 08-30-2015, 12:36 AM   #7
AlexWood
Drives:
Well didn't exactly blow. I felt it start pulling funny, then the tire pressure light came on and I pulled over. Wasn't violent at all. That's why I rule out the alignment
Old 08-30-2015, 12:41 AM   #8
venturaII
venturaII's Avatar
A good tire can mask a bad alignment, and a poor tire can make an otherwise good alignment seem bad. And everything in between.
Old 08-30-2015, 12:46 AM   #9
AlexWood
Drives:
I'm on stock wheels so I stayed with 215/45s. Yeah I had the alignment done when I put the coils on. I don't have the print out but toe was pretty good and camber was like 2 in the front 3 in the rear
Old 08-30-2015, 12:47 AM   #10
AlexWood
Drives:
I was on the stock michelins.
Old 08-30-2015, 12:48 AM   #11
AlexWood
Drives:
Yeah brand new. They are cheap firestones which I think might have an impact but it's almost undriveable on the highway.
Old 08-30-2015, 03:45 AM   #12
fx35s
Drives: 2013 Subaru BRZ
Did the car drive fine before you got a new tire?
I am not sure why you are having that issue, but it sounds like your alignment may be somewhat off.
I suspect your rear toe may be in "toe out" position meaning your rear toe may be near somewhere 1?
When I had my rear LCA installed, the camber for both sides were adjusted in "eye," and weren't too terribly off from one side but toe was nearing 0.8 for both and my car drove just as you described.
The rear floats and feels something is loose doesn't it?
If tires are okay, I will have to bet it's the alignment that needs to be checked- especially the rear toe. Rear toe may be in "toe out" spec.
fx35s is offline   Reply With Quote
Old 08-30-2015, 06:00 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, have you checked if air pressure is same on both sides? Also as those tires are temporary .. why not switch front wheels with ones on back with those temporary firestones?
Old 08-30-2015, 08:06 AM   #14
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
It's your alignment. You should be doing all four tires at once as well especially since you're telling us that your fronts are bad as well.
Post up your alignment specs after you get it done.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
BRZ on the highway Champster BRZ First-Gen (2012+) — General Topics 11 06-15-2015 08:32 PM
Put on new rear tires, now my car handles terrible! WTF? 996garage Scion FR-S / Toyota 86 GT86 General Forum 25 12-03-2014 02:41 PM
Rear Parking Brake Guard Rub (Meaty Rear Tires) console_cowboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-13-2013 03:39 PM
I saw one of you on the highway..... Joakim3 Mid-Atlantic 1 07-20-2013 08:43 PM
What would make the rear tires look wider?? Razor Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 02-19-2013 12:16 AM
