Old 08-29-2015, 05:18 AM   #169
EzyBrzy
Drives: 2015 WRB BRZ
Originally Posted by Crazypinoy9 View Post
Had mine on for almost two weeks now on the stiffest setting. driving on the highway is MUCH better than stock now. Not sure about those other people with RSR's but coming from someone that's boosted i can tell you that even at high speeds or quicker acceleration than stock, the suspension is fantastic. I was a little skeptical in buying an $800 set of coils but i'm glad I bought these.
Mike has been a super helpful in answering any questions that i've had so if there's any doubts about this suspension, talk to him and trust me when i say that you'll feel much more at ease about them. I bought them and have no regrets so far. but then again i've only been on them for 2 weeks so maybe check back with me after 10K miles or so lol
Nothing but good initial experiences so far. Thanks for the input.
EzyBrzy is offline   Reply With Quote
Old 08-29-2015, 02:49 PM   #170
CSG Mike
CSG Mike's Avatar
If you told me 12 months ago, or even 2 years ago I'd be comfortable recommending a sub $1k suspension, I'd have laughed in your faces....
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
jawnthen (08-29-2015), Kris86 (09-13-2016), Teseo (08-29-2015), zoth (08-30-2015)
Old 08-29-2015, 03:24 PM   #171
bfrank1972
Drives: 2013 FR-S Argento
Was on the verge of buying some Konis with my sportline springs, but these are appealing to me- can anyone comment on quality of the dampers between these flex z's and Koni yellows?
Old 08-29-2015, 06:55 PM   #172
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
I got mine last week and finally opened box today!
I just need time to install it since my wife and 9 months daughter i need to take care of.
here're some pictures of i took.
To other owners, any setting recommendation?
I am thinking to drop 1.2 inch. I am kinda noob how to adjusting it so teach me!!
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
chaoskaze (08-31-2015)
Old 08-29-2015, 09:10 PM   #173
djliquidsteele
Drives: Scion FR-S
In all honesty, you could probably just slap the damn things on and go. Then adjust from there.
I had to jack the car up and take the wheel off to adjust them once they were on the car. All you do is loosen the collar on the very bottom and grab the whole thing and turn, righty to drop, lefty to raise. Make sure you measure, I just measured the space between collars to match left to right. I did the rears first, then dropped the car. Measure from the center of the wheel to top of the fender arch then dropped the front to match.
Preload should be set just fine from the factory.
djliquidsteele is offline   Reply With Quote
Old 08-29-2015, 09:12 PM   #174
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
I set mine at the book USA default setting. But I also have 18x8.5 wheels.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
Old 08-29-2015, 10:30 PM   #175
Stevenuhh
Drives: 2015 FRS Firestorm
recommendation to fix camber?
Stevenuhh is offline   Reply With Quote
Old 08-29-2015, 11:32 PM   #176
zc06_kisstherain
Drives: SWP BRZ
I could this too but i'm trying to save sometime if someone already dropped near 1.2 inch with stock wheel. then i can use his measurement. i guess i will just have to spend a day and have fun with it when time permits
Old 08-30-2015, 09:41 AM   #177
Shady195
Drives: '13 10 Series FRS #1203
Will need rear LCA's to fix camber, camber bolts may also work depending on how low the car is.
Shady195 is offline   Reply With Quote
Old 08-30-2015, 10:32 AM   #178
SilverFRS
Drives: Silver FRS
How much adjustment will camber bolts make in the rear? Do they go in the hub to LCA position? I have .7 degree difference from side to side in the rear. Would this be better than using SPC LCA?
SilverFRS is offline   Reply With Quote
Old 08-30-2015, 01:44 PM   #179
CSG Mike
CSG Mike's Avatar
In the rear? LCA is the proper way to do it.
Camber bolts only work for the front struts. For the rear, you'll need a LCA to properly adjust camber.
Old 08-31-2015, 02:20 PM   #180
bfrank1972
I agree LCA's are the broader solution for people who want a lot of adjustability - but technically there are camber bolts for the rear.
I actually use H&R camber bolts with the stock LCA's with about .5 degrees of adjustability. Not a lot but enough to dial out some of the negative rear camber from the sportline springs I'm on.
BTW Mike, would you have any experience to comment on my question a few posts up? I.E. debating the Koni Yellow/springs vs Flex Z route, if you have experience with both how'd you rate the dampers between the two? Teins on par? Thanks
Old 08-31-2015, 02:42 PM   #181
CSG Mike
CSG Mike's Avatar
The Flex Z is generally superior out of the box. The Konis can be made superior with an experienced shop designing a custom valving for you, but at that point, you're spending far, far more for the Konis. Unless you're restricted to the Konis due to competition rules, that's not a very cost effective route to go.
bfrank1972 (08-31-2015)
Old 08-31-2015, 03:05 PM   #182
Shady195
@CSG Mike are there any plans for custom valved inserts from you guys? if so any chance of having higher spring rates as well?
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 03:44 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 03:22 AM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 01:10 PM
