Old 10-10-2013, 10:18 AM   #43
ImAwesome
Drives: 99' M3, 13' SWP Brz
reminds me of the older turbo celicas
ImAwesome is offline   Reply With Quote
Old 10-10-2013, 10:22 AM   #44
PhastekSport
PhastekSport's Avatar
Send a message via AIM to PhastekSport Send a message via Yahoo to PhastekSport
The whole air intake idea was nixxed for the time being. Not sure if I noted that.
PhastekSport is offline   Reply With Quote
Old 10-10-2013, 10:24 AM   #45
muffinz
Drives: 2013 DGM BRZ Ltd
I both like and dislike that oil cooler location...
Like because it'll fully drain for oil changes
Dislike because idk how you're going to eliminate air inside the coil...?
Won't it always be slightly airbound and inefficient?
Also, if it has a fan on it, why not hide it behind the fog lights or somewhere less obvious where u dont need air flow / not atop the hot engine?
Just my 2 cents
muffinz is offline   Reply With Quote
Old 10-10-2013, 11:49 AM   #46
PhastekSport
Keep in mind that I am not a tech around here.
I didn't even stay at a Holiday Inn Express last night.
I did read up on people using top mount oil coolers for Imprezas and other vehicles that usually come with TMICs.
This excerpt is from a product offered by one manufacturer:
B-Line Motorsports has developed a top mounted oil cooler kit that essentially mounts in the same location as the factory intercooler. Utilizing the dead space and scoop created by installing a front mount intercooler; our oil cooler can improve the vehicle’s overall cooling capabilities. The advantage of installing this top mounted oil cooler is the fact that the radiator and intercooler will work more efficiently by having one less object restricting air flow. Many hours were expended in the design of the mounting brackets so that the final product would incorporate the factory mounting holes when attaching the oil cooler to the motor. This type of installation allows the oil cooler to move in conjunction with the motor, resulting in a long life span. B-Line Motorsports has also wrapped certain portions of the oil lines that are near extreme heat, such as the turbo and exhaust manifold, with a lightweight sleeving that withstands radiant heat over 800°F. In testing, oil temperatures were measured to drop 30°F to 40°F. Making this kit the most effective and most efficient kit on the market!
Once the thermostats starts to open up, the oil cooler will fill with oil. Any air should be pushed out as the system doesn't function like the cooling system.
Air should flow through the engine bay and be pulled out the bottom of the vehicle. I'm effectively hoping that the downward flowing air and cool air coming in from the hood vent should also flow out the bottom.
Temperature in Houston have been through the roof until recently. The oil cooler works really well.
Old 11-21-2013, 04:17 PM   #47
PhastekSport
Oil temps only got up to 244F in 80 degree weather. Even with 22 laps (track was only around 1 mi).
20131116-LotusClubTrackFeat86-1542 by VictorN07, on Flickr
20131116-LotusClubTrackFeat86-1719 by VictorN07, on Flickr
[ame="http://www.youtube.com/watch?v=g2PKmhaw8h8"]PhastekSport.com - Houston 86 Club (Nov 16, 2013) - Grandsport Speedway - Hitchcock, TX - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=qDFNeHRjV8E"]PhastekSport.com - Houston 86 Club (Nov 16, 2013) - Grandsport Speedway - Hitchcock, TX - YouTube[/ame]
Old 04-13-2014, 07:53 AM   #48
VictorKassil
[||•(==(86)==)•||]
VictorKassil's Avatar
Drives: WRB Subaru BRZ Series.Blue
Send a message via Yahoo to VictorKassil
Originally Posted by PhastekSport View Post
Added top mount oil cooler picture.
I think it does work well if modified for a top mount oil cooler. This is right after I installed a setup. Have to go back and wire a relay, tidy up the wires, etc.
NOTE: This oil cooler DOES have a fan. It really sucks :-).
Which oil cooler is that?
"Guys, I'm bringing the party to you!"
-Tony Stark
______________________________________
VictorKassil is offline   Reply With Quote
Old 08-29-2015, 03:04 PM   #49
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Originally Posted by Panman View Post
Will the hood clear the Innovate/Sprintex/Bullet supercharger?
That's hard to say. I'm not sure I've seen one of those setups in Houston to compare it with.
I think IATs are a little lower. I'm going to have to enlist someone with a similar setup to give me some data.
I put it on the dyno today and with the hood down on one run I actually got a couple more HP but a couple less torque. I'm not a mechanic/tuner so I'm not sure whether or not to attribute this to anything but luck. I rigged an intake to the Vortech, but I think it's going to take more time to perfect the setup.
Any updates on this hood as far as testing and functionality? I would like to know if this will fit with the Sprintex supercharger. How is it with rain? Is there a rain guard option?
Chad86 is offline   Reply With Quote
frs, hood, rksport, scoop, xpel
Yellow Headlight Tint Illegal? Touge86 Southern California 5 05-20-2014 01:21 PM
Replacement hood - RKsport Symbiont Cosmetic Modification (Interior/Exterior/Lighting) 88 04-21-2014 10:02 AM
FS: RKSport FR-S/BRZ Fiberglass hood (Irvine, CA) Symbiont Exterior Parts (Aero, Lighting, Etc.) 2 09-02-2013 05:49 PM
Lamin-X / Xpel headlight protection in CT? tobin NY / NJ / CT / PA 1 07-29-2013 09:04 AM
Leeberbs Tint and Lamin-X Headlight zc06_kisstherain Cosmetic Modification (Interior/Exterior/Lighting) 9 02-23-2013 11:04 PM
