Old 08-27-2015, 06:09 PM   #1
Drakelee117
Drives: Subaru BRZ 2015
Automatic headlights constantly on?
Do you guys know if there is a switch to change the setting for headlights if it is set to auto? The weirdest thing happens to my car.
I usually leave the headlights on auto and never worry about it, but this morning when I pull out from the garage the lights did not turn off. After that I drove for about 5 mins they were still on. I tried to restart the car, still doesn't turn off. After fiddling with the switch for a while, it looks like the auto setting is not working at all and the only way to turn the headlights off is to do it manually. Anybody had the same problem before?
Drakelee117 is offline   Reply With Quote
Old 08-27-2015, 06:16 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Low beam stays on or are you talking about the DRL?
Old 08-27-2015, 06:23 PM   #3
ARTBRZ
Aloha!
ARTBRZ's Avatar
This is new. Does it stay on after you turn off the car? Is the sensor on the dash being blocked or dirty. If not take it to the dealership.
ARTBRZ is offline   Reply With Quote
Old 08-27-2015, 10:46 PM   #4
BRZnut
Drives: BRZ DGM Limited
I never use the auto setting because its not good for the lights to flick on in the garage and them go off as soon as you drive out of the garage, day after day, esp if you have HIDs. Can lead to faster bulb failure.
The Following User Says Thank You to BRZnut For This Useful Post:
soulreapersteve (08-28-2015)
Old 08-28-2015, 12:07 AM   #5
Drakelee117
Low beam or high beam depends on which one I put on.
Old 08-28-2015, 12:11 AM   #6
Drakelee117
It turns off when I turn it off manually using the switch or push the lock button twice. Sensor being blocked is my first and only logical guess, do you know where exactly is the sensor?
Old 08-28-2015, 12:39 AM   #7
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
There's a round circle on the passenger side of the dash.
jawn is offline   Reply With Quote
Old 08-28-2015, 11:56 AM   #8
ARTBRZ
Aloha!
ARTBRZ's Avatar
It's in front of the passenger side.
Old 08-28-2015, 12:50 PM   #9
JS + BRZ
Drives: 2010 MS3
That's cool. I didn't know that. haha
Old 08-28-2015, 09:00 PM   #10
Um I don't think so. Not like there are filaments in there that are heating and cooling. I could be wrong though so if anybody can support BRZ (with some form of documentation please) I am curious. I have always left mine on auto on my previous cars and they all were still perfect after 300,000 miles. Can't find a single official statement on the subject.
Old 08-28-2015, 09:21 PM   #11
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
I agree with you @Tcoat. Doubtful that it will cause the bulb to fail. HID bulbs produce an electrical arc in the inner glass between the two pieces of metal. If anything the ballast will fail, highly unlikely but possible. OEM HID components go under a lot more quality control practices than aftermarket or knock off companies that produce the same type of HID equipment.
Why do you think they're so many OEM branded fakes being sold on places like Ebay. Unsuspecting customers in the masses and it mostly cheap junk posing like Philips, Osram, Bosch... etc
2015 Subaru BRZ Limited AT6
Premium 615 is offline   Reply With Quote
Old 08-28-2015, 09:32 PM   #12
LOL The dollar store near me sells Phileps bulbs and Craest toothpaste exclusively!
ARTBRZ (08-30-2015), Choco (08-30-2015), Premium 615 (08-28-2015)
Old 08-28-2015, 09:53 PM   #13
rookie
rookie's Avatar
Drives: 1991 Formula Red NSX
Craest: Fights Gingervitis
rookie is offline   Reply With Quote
The Following User Says Thank You to rookie For This Useful Post:
Old 08-28-2015, 10:01 PM   #14
Premium 615
@Tcoat and @rookie
Its abundant in just about anything these days.
The Following 2 Users Say Thank You to Premium 615 For This Useful Post:
Choco (08-30-2015), Tcoat (08-28-2015)
Traction Control Light Constantly On Cal3000 Issues | Warranty | Recalls / TSB 26 12-25-2016 05:20 PM
Using handbrake with automatic gt86 and other issues with the automatic version Tommygt86 Scion FR-S / Toyota 86 GT86 General Forum 9 04-06-2015 04:42 AM
Posts deleted constantly gmookher Site Announcements / Questions / Issues 6 12-10-2012 05:06 PM
Suspension options instock: Constantly updated list!!! Kami Speed Brakes, Suspension, Chassis 0 07-17-2012 02:26 PM
Automatic headlights ? miodculae Electronics | Audio | NAV | Infotainment 1 07-01-2012 09:44 AM
