#645 | ||
Lost in the twisties
Drives: 2014 BRZ Dark Gray Metallic
![]() Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft Aztec's Build Thread ![]() |
#646 |
Drives: frs
Safe way for all aftermarket headers?
#647 |
Drives: 2015 Series.Blue
No no no, you use ANTISIEZE on the O2 sensor threads!
Unless you like having to heat the O2 sensor and header up to red hot to remove the O2 sensor in the future... |
#648 |
yeah should be fine, the stock header had a huge heat manifold that made the washer snug
NEW CAR!🚨🏎️⛽
#649 | |
Drives: FT86
and run a M18x1.5 thread tap/chaser through the o2 bungs to clean them up so sensors screw in easy |
#650 |
Drives: 2015 Scion FR-S
Make sure you get the blue label. Avoid green and red, which would make it a permit seize.
#651 | |
NO. Do not use thread locker! Antisieze is what you need. If the threads in the header or O2 sensor are messed up, chase the threads. You can use a thread file too if needed. |
#652 |
#653 |
Drives: 2017 CWP BRZ Performance Package
I have the OFT+OFH set up on my 15 Series blue BRZ.
@Shiv@Openflash when will you push launch control in the tune for 15 series blue BRZ? |
#654 | |
Drives: 2015 Subaru BRZ Series Blue
http://instagram.com/cameronjones239
2015 Subaru BRZ Series Blue Build http://www.ft86club.com/forums/showt...09#post2002909 |
#655 |
Drives: 2015 BRZ
Apologies if this has been asked before, but I know it's highly recommended to replace the gaskets between the header and the engine and overpipe, but I've read many recommend unbolting the front pipe to the mid pipe to maneuver the overpipe away from the header to allow it's removal.
My question is, should the gasket be replaced between the mid pipe and front pipe? Also, apologies if I've gotten my exhaust terminology incorrect. |
#656 | |
Drives: FT86
however we a right hand drive so might be some clearance issues on LHD car dont know the midpipe/frontpipe gasket is a doughnut and can be re-used if you do loosen it see the basic bolt on mods link below its got diagrams and tips on installing header |
#657 |
Drives: silver brz 2013 lmtd
Is it me or are the tunes EXTREMELY raspy, the first 100 miles...
#658 |
Huge E85 fan!
Drives: 2016 Scion FRS
I thought it was just my car? I know I have a shitty gasket between the mid-pipe and axleback, I figured it just got worse over time..... maybe I didn't have to order new gaskets after all and it's jut the tune?
![]() Ah well, the axleback gasket and the donut gasket are getting changed out anyway! |
| Open Flash Header - Sound and Performance Comparison | nlowell | Engine, Exhaust, Transmission | 41 | 05-19-2014 06:29 PM |
| FS: Open Flash Header - SoCal Pickup | nlowell | Engine, Exhaust, Bolt-Ons | 9 | 05-12-2014 06:29 PM |
| Open Flash Tablet | Andrew025 | Engine, Exhaust, Bolt-Ons | 3 | 04-26-2014 05:03 PM |
| Open Flash Header Catless Clip | Vmax911 | Engine, Exhaust, Transmission | 25 | 03-08-2014 06:51 AM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
