#3935 | |
Drives: 13 FRS MT,11 wrx STi, 01Forester MT
What specific test do you get done by Blackstone? I'm sitting here since a month, breaking my head over a good tire setup for the track, mostly erring towards a staggered setup to bring more grip to the rear but without trial and error I really won't know and then there's a part of me that just wants to get whatever and head out to the tracks just to have fun. Sent from my A0001 using Tapatalk
#3936 |
Yep, that's how I recognized the name and asked! You have/had a wrx/sti as well right?
#3937 | |
Drives: 13 BRZ Limited WRB
Depending on what you're going to use the car for, square setup might be the best bet (road course, etc) no reason to stagger if you don't have the extra power to use the grip. I'm sc'd 245whp currently and I run square. 255s, but square. Sent from my HTC6525LVW using Tapatalk
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#3938 | |
Drives: '14 FRS TT5
For tire setup, I run square 225's, mainly because I can only run stock rim width in my autox class. If you're going wider, do you have adjustable suspension? As gopher boy said, stock 86's don't make a ton of power so you shouldn't need extra rear grip (to dial out oversteer). So I'd say run a square setup and adjust handling balance with strut settings (if your suspension is adjustable). Fair disclaimer, I don't have a ton of experience with other tire widths yet, but I will say with square 225's in a sticky tire (Bridgestone RE71R's), the frs is much more neutral. Ps...going back and driving on the stock tires after sticky tires is a ton of fun. Hello drift action! Lol |
#3939 | |
This would be my first experiment. Next, I plan on moving the super sports to the front and go wider for the rear with some rpf1s for the rear and experiment. Sent from my A0001 using Tapatalk
#3940 | |
#3941 | |
And yea, I'll probably have to roll the fenders and or stretch the fenders to accommodate the 235s although it doesn't seem to me that the 2cm is going to add up to that much width. Guess I'll only know after I get it and test it out. Sent from my A0001 using Tapatalk
#3942 | |
#3943 | |
Drives: '14 FRS TT5
And I don't think you'll need to roll fenders for 235's...pretty sure I've read that people are fitting 255's without rolling. And really, I think all 4 of the same tires, square, will be best. Sticky tires do a lot to dial out the oversteer. Appreciate it the oversteer though, because these things rotate much better than STI's! |
#3944 | |
The FR-S is sooo predictable and comfortable for sideways action!! Sent from my A0001 using Tapatalk
#3945 | |
But, it is not my money ![]() Sent from my HTC6525LVW using Tapatalk
| The Following User Says Thank You to Gopherboy6956 For This Useful Post: | driftagoon (08-27-2015) |
#3946 | |
#3947 | |
#3948 |
Miata traitor
Drives: 2002 Miata SE
Let's talk about local classing for a minute. Realistically if I went FI I'd immediately shoot myself in the foot from being competitive in any class, yes? Basing this purely off MNtimeattack classing.
I'd be in "Limited Heavy", that same as evos, and other cars allowed to make similar upgrades. I mean I might be able to compete in some drag class with stock interior and weight but.... straight lines. Matt, Im sure you did research into the local classing and whatnot before supercharging. Did you come to same conclusion and decide to just do it for fun? Some of the other cars in limited heavy per the results from MNtimeattck |
| Check in, eh? | NorthFool | CANADA | 24 | 02-23-2012 07:32 AM |
| *NSFW* "Check Out My Subaru" on You Tube | Axel | Other Vehicles & General Automotive Discussions | 4 | 01-17-2010 05:56 PM |
| how do you check a site | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 3 | 11-21-2009 09:27 PM |
| Video of FT-86 @ TMS from Edmunds. Check out how small the car is next to people. | JDMinc | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 9 | 10-25-2009 08:53 PM |
