Old 08-27-2015, 04:40 PM   #1597
AVOturboworld
On 98 octane (which is about 94 octane in american standard) you should be fine running up to 8psi on the standard setup with an e-tune. WHP is typically between 260-290whp in that setup. With the Fensport tune you should be good.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Jonde875 (08-30-2015)
Old 08-28-2015, 05:55 PM   #1598
Jonde875
Drives: GT86
Talking
So it will be around 300-330hp on engine does it hold all that inside easily?
Jonde875 is offline   Reply With Quote
Old 08-28-2015, 05:57 PM   #1599
AVOturboworld
I'm still on the original kit we fit 3 years ago, and have done about 44,000 miles without issue! You should be fine!
The Following 3 Users Say Thank You to AVOturboworld For This Useful Post:
Astroboy (08-28-2015), Draco_PR23 (08-28-2015), Jonde875 (08-30-2015)
Old 08-28-2015, 06:18 PM   #1600
Astroboy
Astroboy's Avatar
Drives: None
The only things that went out on mine were the factory motor mounts. It could be because of the Texas heat. You also have to watch the oil line above the block that goes through the turbo. It tends to leak but can be fixed with washers from what I was told.
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
The Following User Says Thank You to Astroboy For This Useful Post:
Draco_PR23 (08-31-2015)
Old 08-28-2015, 06:21 PM   #1601
Jonde875
Drives: GT86
Ok thanks a lot of this!
I give an update when I get things go further!
OK thanks
Old 08-31-2015, 04:38 PM   #1602
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
@protpibe
How been your experience with WMI so far? Since I dont E85 in my area, I am considering it.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
Old 08-31-2015, 05:12 PM   #1603
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Originally Posted by Draco_PR23 View Post
@protpibe
I haven't had it tuned to get all of the power I could handle yet, but to be honest, even without the power gains I still see value in not worrying about what kind of moose piss is sitting in the gas station holding tanks up here in Canada.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
Astroboy (08-31-2015), Draco_PR23 (08-31-2015)
Old 09-01-2015, 11:55 AM   #1604
nopocrakr
nopocrakr's Avatar
Drives: CBS BLACK 2013 Subaru BRZ
oil change amounts
I have a dumb question for anyone that would like to help . how much oil do i use after i have changed the oil . Now that I have the AVO Kit on my car.
nopocrakr is offline   Reply With Quote
Old 09-01-2015, 12:10 PM   #1605
protpibe
protpibe's Avatar
Depends if you have an oil cooler or not.
I usually put in 5.5L
Old 09-01-2015, 12:17 PM   #1606
nopocrakr
nopocrakr's Avatar
I was told that because of the added spaces from the reservoir that now it take 2 extra quarts. and no oil cooler
Old 09-01-2015, 12:29 PM   #1607
nopocrakr
nopocrakr's Avatar
I'm not that great at the forum ways . But I was told that because of the turbos reservoir you need to add two extra quarts . And i do not have a oil cooler.
Old 09-01-2015, 12:52 PM   #1608
protpibe
protpibe's Avatar
Wow don't put 2 quarts in lol.
On initial install, you'll have to add a bit of oil, but the amount of oil you will put in on an oil change will be almost the same since the reservoir and turbo won't drain into the pan when the car shuts off.
The Following User Says Thank You to protpibe For This Useful Post:
Draco_PR23 (09-01-2015)
Old 09-01-2015, 04:33 PM   #1609
nopocrakr
nopocrakr's Avatar
Thanks man, that was a big help!
The Following User Says Thank You to nopocrakr For This Useful Post:
Old 09-02-2015, 08:54 AM   #1610
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Got the ultra quiet resonator welded in which helped a bit, but it's still too loud for my liking with the evo3.. so I'm currently getting a magnaflow racemuffler put in right before the bottle resonator. Hoping this #killsthedrone.
Other than that I replaced the turbo to reservoir line with a high temp double wall silicone 5/8th hose and got much wider clamps. I then bought a two pack of DEI protect a boot sleeves, cut one in half and put it around the hose before installing (they can withstand direct heat of 1200F). Hopefully no more seepage - nothing catastrophic yet so I'm going to keep holding my breath.
Lastly the rattling noise!
So I found a few things around the engine bay which I thought were source of the rattle, removed the overpipe heatshield, removed a bracket by the windshield wiper tank that wasn't connected to anything but was touching a charge pipe, found that the oil dipstick could be the real issue all along as its touching another charge pipe and could vibrate. I wrapped it in a lot of tape to see if it went away and it sadly did not. I also put unused hose on the turbo reservoir breather neck to keep it from directly touching another charge pipe as well as flattened out the radiator brace that's right next to it.
No dice by adjusting anything listed.
Soo, the hunt continues..
The rattle comes between 2300-2800rpm, and is coming from the front driver side. Seems to not be present when the car is cold (or atleast is much more quiet). The rattle intensifies to a point after the car is warm. The noise sounds exactly like a heatshield being tapped on with something metallic. Just can't pinpoint it.. If I'm barely on the throttle at between those rpms the noise gets louder, but if I increase the throttle just barely it goes away completely. Can't replicate in neutral either..
Any ideas?
bryan767 is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
