Old 08-01-2015, 09:03 AM   #71
Bergen23
Drives: '15 Halo FR-S
@FRSBRZGT86FAN well, picked my car up today and drove it for about 25 minutes only using the paddles. Didn't have my original issue come up again. Looking at the bill, they swapped the EGI ECU and the code they pulled was P0710- trains control system malfunction.
About to take a 3 hour drive to the beach, we'll see if it surfaces again.
Bergen23 is offline   Reply With Quote
Old 08-08-2015, 06:33 PM   #72
casemanase
casemanase's Avatar
Drives: '15 CWP BRZ
I think I have a way to reproduce it. I always noticed that it showed up when I was in manual, switched to Drive for whatever reason - cruising on the highway with heavy traffic, etc. - and then when going back to manual, rev matching stops working and all of my shifts are jerky, more from 1-2 and progressively better, almost unnoticable 5-6.
I found that if I drive about 2 miles, change back to drive, WOT and let automatic do 3-4 shifts, when I go back to manual it starts doing it. I am not switching to manual right away, usually doing 20-40, then once I let go of the throttle and it is realtively stable, I switch back to manual mode.
I just left the dealer for my 12,000 tuneup and had him make notes that this had been happening. I don't want to suffer from transmission issues because the ECU or whatever is managing rev matching, is forcing my car to beat on the tranny. This first showed up at 300 miles with no spirited driving, and I don't believe I had even broken 2500 RPMs at that point.
I'll be taking this back if I can get some dry days around here to test it a little more - it always happens when the dealer is closed...
casemanase is offline   Reply With Quote
The Following User Says Thank You to casemanase For This Useful Post:
FRSBRZGT86FAN (08-08-2015)
Old 08-08-2015, 07:17 PM   #73
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yup that's exactly what happens to me I've noticed if as soon as I start the car and go to manual mode I have no problems as long as I stay in it. If I go normal drive then its an issue after a while, and I can almost notice it at wot even in drive mode as the transmission feels to lurch I'll bring it up at the first oil change
Sent from my A0001 using Tapatalk
Old 08-08-2015, 07:18 PM   #74
FRSBRZGT86FAN
Did it surface again?
Old 08-11-2015, 02:27 PM   #75
Bergen23
It has surfaced again. Not sure of what to make of it. May let the dealership have another crack at it. If they can't fix it for good in the next visit, I'll be going to another dealership to handle it. Unfortunately the closest one is 30 minutes or so away, compared to the less than 5 of my current dealership.
The Following User Says Thank You to Bergen23 For This Useful Post:
drewbot (08-11-2015)
Old 08-25-2015, 03:04 PM   #76
Bergen23
Originally Posted by SeanD06 View Post
The problem resurfaced as well on mine.. Finally Scion Canada wouldn't help me so they took back my car (rebought my car) without charging me a thing... I bought a BRZ but manual this time so no worries anymore...
I'm gunna see if I can get that
Old 08-25-2015, 03:19 PM   #77
Bring it to London. Have nothing but good to say and hear about their service department.
Old 08-25-2015, 03:50 PM   #78
Bergen23
At this point, I'm done with trying to get it fixed. Been in the shop 3 times now and they don't have a clue what the problem is. I'm escalating this to scion canada when I'm home next.
Old 08-25-2015, 03:53 PM   #79
worth a shot I guess.
Old 08-26-2015, 11:33 PM   #80
FRSBRZGT86FAN
That's not gonna happen in the U.S. for me at least, honestly, I'm not gonna bring it up after this next oil change if they can't fix it for me 2 or 3 times by replacing the TCM or anything of the sort then it's a lost cause it has however come up less though for me.
Old 09-29-2015, 04:38 AM   #81
FRSBRZGT86FAN
Originally Posted by 86_dion View Post
I've had this same issue. No solution. Dont know what causes it. Sometimes those downshifts are scary
Originally Posted by AREN View Post
I've experienced the same issue, probably three times since owning the car for a year. Harsh upshifts and laggy/non rev match downshifts. Restarting the car does make it go away, the other solution was to put in back in "D" and drive for a few miles.
Originally Posted by drewbot View Post
I have these types of issues, but it is always so intermittent it is hard to actually replicate and understand.
My feeling is that perhaps I will get a tranny flush (been on the OEM fluid, never changed and now at 56000 km) and maybe that will rectify it
Originally Posted by phrosty View Post
I've had this happen a couple times as well. I haven't noticed any pattern to it. I'm guessing it's a bug in the ECU.
@casemanase
@SeanD06
I'm tired of being jerked around by dealers saying its normal then the tech saying wow that's unusual never seen that before.
If you would, I would consider it a safety issue in traffic we could group complain to the NHTSA about it, everyone seems to be complaining about it and dealers wouldn't do anything we can escalate it:https://www-odi.nhtsa.dot.gov/VehicleComplaint/
Edit: Found out of a possible TSB today that might help the issue as well because when it occurs the idle starts hunting and guess what, the fix is to the TCM:
Technical Bulletin S-SB-0021-15, issued September 17, 2015, Idle Fluctuation in Park or Neutral.
Applicability: 2015-2016 FR-S
Introduction: Some 2015-2016 model year FR-S vehicles may exhibit a condition where the engine idle speed fluctuates (typically 500 - 1000 RPM) only when the transmission is in the Park or Neutral shift position. This condition occurs after the vehicle has been driven about 25 miles or more at highway speeds. The Transmission Control Module (TCM) logic has been revised to address this condition.
Old 09-29-2015, 08:17 AM   #82
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@casemanase
@SeanD06
Canada here eh. Don't know if me registering would count
drewbot is offline   Reply With Quote
Old 09-29-2015, 04:04 PM   #83
FRSBRZGT86FAN
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Cole (09-29-2015), drewbot (09-29-2015)
Old 09-29-2015, 04:15 PM   #84
DGM33
DGM33's Avatar
Drives: Lightning Red 2015 BRZ;F150 Limited
FWIW, I had this problem a few times but found that it NEVER happens if I only use Manual mode. It only happens if I've been in Auto and then switch to Manual. So I use either one or the other when I'm driving and don't switch back and forth and have no issues.
Yes, my user name is DGM. No, my car is not. It's a long story--and to be honest, not a very interesting one.
DGM33 is offline   Reply With Quote
Can't downshift while warming up HMX-92 Issues | Warranty | Recalls / TSB 25 12-20-2014 02:20 PM
Rev match downshift possible with OFT Simon99 Software Tuning 24 08-17-2014 04:20 PM
downshift to first swpbrz Engine, Exhaust, Transmission 13 05-07-2014 08:33 PM
6th to 5th Downshift Crunch jcat5150 Issues | Warranty | Recalls / TSB 1 04-17-2014 03:41 PM
Downshift rattle?? driftartist Issues | Warranty | Recalls / TSB 17 08-03-2013 10:00 AM
