#2815 |
Drives: Crystal Black BRZ(Sophia)
And the supercharger competition heats up.*puns for dayz*
#2816 | |
Drives:
Jackson Racing Supercharger Owners Thread
Moto-east or tuned at Church? Edit. Just saw. Badass man!!
| The Following User Says Thank You to DaiTT500 For This Useful Post: | SPCorBUST (08-24-2015) |
#2817 |
Drives: GT86-ACE-JRZ-RPF1-Essex
Thanks for the part list. Does someone plan to do it with regular fuel by lowering the compression ratio ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
#2818 |
Drives:
I'm pretty sure Jackson racing tested out this product on 93+ octane on an un-opened motor where you would not need to change the compression.
#2819 | |
Drives: Subaru BRZ / Toyota 86 Experts
| The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post: |
#2821 |
Doesn't that would mean that the other pulley was not the proper size for stock engine/fuel ?
#2822 | |
Drives: JR FR-S,
93 or higher is required to see safe power increases. Technically you can run 91, but you won't see a large power increase. To run the high boost pulley safely on 91 you would have to pull a lot of timing, resulting in about the same output as the standard pulley. So really, there is no reason to go high boost on a strictly 91 octane setup. |
#2823 | |
Drives:
No it means the motor car handle a bit more boost.
#2824 |
So that's a boost pressure change which is the magnitude of a 91 to 93 octane upgrade and not the magnitude of a compression ratio that would go from 12,5 to 10 ?
#2825 |
Fast enough
Drives: 2013 Subaru BRZ AT
How comfortable are you guys with this power level on a stock motor?
Reason I ask is I'm getting close to purchasing a JRSC, I'll be using E85, and I have an Auto. I'd like a bit more torque down low, which the high boost pulley certainly provides, but that top end scares me a bit! ![]() Congrats though. That's a seriously impressive power level for only 12psi on a supercharger. You've got one hell of an efficient compressor there! |
| The Following User Says Thank You to xsnapshot For This Useful Post: | CSG Mike (08-24-2015) |
#2826 |
Drives: 350z
Will this pulley need a smaller belt?
Any videos of this pulley on the 1/4 mile? |
#2827 | |
Drives: 2015 Series.Blue BRZ
Sent from my XT1095 using Tapatalk
#2828 |
Senior Misanthrope
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
