Old 08-24-2015, 03:22 PM   #2815
Yoda
Drives: Crystal Black BRZ(Sophia)
And the supercharger competition heats up.*puns for dayz*
Yoda is offline   Reply With Quote
The Following 4 Users Say Thank You to Yoda For This Useful Post:
Billion (08-25-2015), clayrush (08-25-2015), CSG Mike (08-24-2015), Porcupint (08-24-2015)
Old 08-24-2015, 03:23 PM   #2816
DaiTT500
DaiTT500's Avatar
Drives:
Jackson Racing Supercharger Owners Thread
Originally Posted by SPCorBUST View Post
265 pump, 700cc injectors, E85, UEL headers, 2.5" overpipe, 2.5" catted front pipe, 2.5" catback, foam filter
Grams, DW, Moto-East, Gruppe-S, Perrin
Moto-east or tuned at Church?
Edit. Just saw. Badass man!!
DaiTT500 is offline   Reply With Quote
The Following User Says Thank You to DaiTT500 For This Useful Post:
SPCorBUST (08-24-2015)
Old 08-24-2015, 03:40 PM   #2817
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Thanks for the part list. Does someone plan to do it with regular fuel by lowering the compression ratio ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-24-2015, 03:42 PM   #2818
DaiTT500
DaiTT500's Avatar
Drives:
I'm pretty sure Jackson racing tested out this product on 93+ octane on an un-opened motor where you would not need to change the compression.
Old 08-24-2015, 03:43 PM   #2819
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
We've been testing the small pulley for the past year. If you have any questions, please do not hesitate to contact us.
CounterSpace Garage is offline   Reply With Quote
The Following 3 Users Say Thank You to CounterSpace Garage For This Useful Post:
ATL BRZ (08-24-2015), DaiTT500 (08-24-2015), stoked_on_spool (08-24-2015)
Old 08-24-2015, 03:57 PM   #2820
SPCorBUST
SPCorBUST's Avatar
I did a Flex Fuel tune, so I have 91 results as well. My dyno graph is at home, but I'll share it tonight.
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
Old 08-24-2015, 03:57 PM   #2821
MaximeT
MaximeT's Avatar
Doesn't that would mean that the other pulley was not the proper size for stock engine/fuel ?
Old 08-24-2015, 03:58 PM   #2822
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
DO NOT lower the compression to run the High Boost Pulley.
93 or higher is required to see safe power increases. Technically you can run 91, but you won't see a large power increase. To run the high boost pulley safely on 91 you would have to pull a lot of timing, resulting in about the same output as the standard pulley. So really, there is no reason to go high boost on a strictly 91 octane setup.
Jackson Racing is offline   Reply With Quote
The Following 3 Users Say Thank You to Jackson Racing For This Useful Post:
clayrush (08-25-2015), Jmonty (08-25-2015), MaximeT (08-24-2015)
Old 08-24-2015, 03:59 PM   #2823
DaiTT500
DaiTT500's Avatar
Drives:
No it means the motor car handle a bit more boost.
Old 08-24-2015, 04:02 PM   #2824
MaximeT
MaximeT's Avatar
So that's a boost pressure change which is the magnitude of a 91 to 93 octane upgrade and not the magnitude of a compression ratio that would go from 12,5 to 10 ?
Old 08-24-2015, 05:28 PM   #2825
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
How comfortable are you guys with this power level on a stock motor?
Reason I ask is I'm getting close to purchasing a JRSC, I'll be using E85, and I have an Auto. I'd like a bit more torque down low, which the high boost pulley certainly provides, but that top end scares me a bit!
Congrats though. That's a seriously impressive power level for only 12psi on a supercharger. You've got one hell of an efficient compressor there!
xsnapshot is offline   Reply With Quote
The Following User Says Thank You to xsnapshot For This Useful Post:
Old 08-24-2015, 10:15 PM   #2826
350z
Drives: 350z
Will this pulley need a smaller belt?
Any videos of this pulley on the 1/4 mile?
350z is offline   Reply With Quote
Old 08-24-2015, 10:16 PM   #2827
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
The pulley is bigger, not smaller.
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 08-24-2015, 10:26 PM   #2828
kch
Senior Misanthrope
kch's Avatar
nah man, smaller pulley = faster spinning. to up the boost, you go bigger crank or smaller SC pulley
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
