Old 08-24-2015, 06:43 PM   #1
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release
As you may know already, there has been some hint of a smaller pulley upgrade for the Jackson Racing kit utilizing the Rotrex C30-94 unit. While this information may get lost in the Owner's Thread, we decided this information should be its own separate post. The rumors are true and Jackson Racing has finally released their smaller/high boost pulley option for the Jackson Racing Supercharger kit!
Jackson Racing High Boost Pulley!
The JRSC Rotrex C30-94 unit uses a pulley sized accordingly to work well with pump gas (91 ACN). With the high boost pulley upgrade, proper fuel upgrades and hardware are required to handle the additional potential safely and efficiently. This pulley is NOT recommended to those unwilling to go the extra step to tune for higher octane/alcohol fuel and proper hardware to handle the additional requirements.
Jackson Racing product description:
Raise your FR-S/BRZ Supercharger System to new heights with the High Boost Pulley. Designed specifically for the Jackson Racing supercharger System. This pulled is NOT designed to be plug-n-play on a Factory Tuned System and it is NOT CARB legal**.
The High Boost Pulley REQUIRES:
• Upgraded Fuel Injectors
• Upgraded Fuel Pump
• 93+ Octane or E85 Custom Tuning
* Boost levels dependent on vehicle environment and vehicle modifications.
** This product is intended for off-road, racing use only. This product is not to be used on pollution controlled highways.
@SPCorBUST Dyno chart of his JRSC + HB Pulley setup on full bolt-ons + E85. Dyno performed at Church Automotive's Dynapack. Average baseline reading with new SAE calibration is 165-166HP on this dyno.
Have a question whether or not this pulley is for you and your Jackson Racing rotrex setup? Please do not hesitate to contact us or Jackson Racing regarding the high boost pulley option!
CounterSpace Garage is offline   Reply With Quote
Old 08-24-2015, 07:03 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
How much does this overspin the blower? Thought JR was pretty close to the manufacturer's maximum recommended rotational speed with the stock pulley.
This a track capable setup that won't eat superchargers as a consumable or a glory pull #lookatmydynonumbersoninstagram setup?
Decay107 is offline   Reply With Quote
Old 08-24-2015, 07:07 PM   #3
CSG Mike
CSG Mike's Avatar
The kit uses about 86% in CARB exempt form. This pulley takes it to 95%.
Old 08-24-2015, 07:36 PM   #4
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
I think you may have misunderstood. The supercharger isn't at its limit with the Factory Tuned System, The Fuel system is at its limit. The high boost pulley now puts the supercharger spinning closer to its limit, and the need for Fuel System upgrades becomes apparent.
JDMChris is offline   Reply With Quote
Old 08-24-2015, 07:50 PM   #5
Decay107
Decay107's Avatar
I was indeed speaking of the blower itself.
The search system here sucks, and thus I cannot dig up the specific post in the specific thread. But there was a comparison early on in one of the KW vs JR threads that showed both spinning in the 90,000+ RPM range at the factory redline.
Edit: found it
Stock kits:
JR impeller speed @7400: 7400x1.29x9.49 = 90,591 rpm = 90.6% rated capacity
KW impeller speed @7800: 7800x1.33x9.49 = 98,696 rpm (KW's tune redlines at 7800) = 98.7% rated capacity
Vortech impeller speed @7400 : 41,588 rpm = 83.2% rated capacity
Kits as pictured in graphs:
Jackson Racing: 90.6% - 90,591 rpm (100k max)
Kraftwerks: 93.4% - 93,401 rpm (100k max)
Vortech: 86.0% - 43,022 rpm (50k max)
Mike 86% or 90.6? Either way, looks to come in just under the max impeller speed
Old 08-24-2015, 07:59 PM   #6
autograph
autograph's Avatar
Drives: 6MT Hot Lava
what i want to know is how long will the fa20 last at these power levels lol.. damnit mike. now i have to starting saving my pennies again for a clutch, fuel pump, injectors and this.. and a money reserve if i blow the engine lmao
autograph is offline   Reply With Quote
Old 08-24-2015, 08:26 PM   #7
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Damnit Mike over at CSG got me excited as fck about that Edelbrock E-force SC and then THIS is announced I don't even know what I want anymore........
Alltezza is offline   Reply With Quote
Old 08-24-2015, 08:41 PM   #8
CSG Mike
CSG Mike's Avatar
Edit: found it
84-88% counting for deformation, elasticity, and expected slip (normal for any serpentine/ribbed belt system), but 90.6% if you have a theoretically rigid system.
Old 08-24-2015, 08:41 PM   #9
CSG Mike
CSG Mike's Avatar
Oops
It just means you need boost ASAP.
Old 08-24-2015, 08:44 PM   #10
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Any idea on what we should expect for 93oct tunes?
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 08-24-2015, 08:58 PM   #11
CSG Mike
CSG Mike's Avatar
+20-40, depend on supporting modifications.
Remember, supporting modifications are MANDATORY.
Old 08-24-2015, 09:08 PM   #12
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
OK, so let me guesstimate on prices to go high boost...
$140 bigger pulley
$150-200 fuel pump
$300-400 700+ CC injectors
$50-200 retune
$700 flex fuel kit
$600-1000 clutch
So real cost is about $2000-2200 for me to add on another ~100 hp. Hmmm...
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 08-24-2015, 09:13 PM   #13
CSG Mike
CSG Mike's Avatar
$140 bigger pulley
$150-200 fuel pump
$50-200 retune
$700 flex fuel kit
$600-1000 clutch
Half the price for the same gain over again...
CSG has some packages that will be put together to support the extra boost!
Old 08-24-2015, 09:15 PM   #14
ScionOfHorus
Ooooh. Post something when you do.
But my next mod is bbk, and I'm just waiting until I have the money saved. Current ETA is October 1st, just in time for my birthday
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 07:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
