Old 08-24-2015, 09:01 AM   #15
evomike
Drives: frs
Originally Posted by DavidBob View Post
Installation error? I for one dont think its too complicated to put in two bolts and then hang it up on two hanger but alright then whatever you say. As for being low I'm maxed out on isc coilovers so I can't be too far off?
im on 17's and bc ultra lows
evomike is offline   Reply With Quote
Old 08-24-2015, 09:05 AM   #16
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
DavidBob is offline   Reply With Quote
Old 08-24-2015, 09:13 AM   #17
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
I've seen the same thing happened to a local club member. It wasn't a Buddy Club but a HKS. The failure was due to crappy welds on the hanger support and the said crappy welds failed on him during a track event. He went through HKS customer support and warranty and got it replaced.
Rabbit of Caerbonnog is offline   Reply With Quote
The Following User Says Thank You to Rabbit of Caerbonnog For This Useful Post:
DavidBob (08-24-2015)
Old 08-24-2015, 09:19 AM   #18
DavidBob
DavidBob's Avatar
Sweet thanks. I just emailed them
Old 08-24-2015, 09:31 AM   #19
sorry it's been a while i was on vacation
when i said i heard the exhaust hit the ground i meant i heard it drop. i was driving at about 25mph on a flat road pulling up to a light. i didnt hit any bumps it just dropped to the ground
reading back at this it looks like i was only venting because i was mad haha i am going to email them tonight and try to be as nice as i can i'll update you guys as things happen, thanks for all the imput!
Did somebody else drive your car or something? The only way for the exhaust to melt the diffuser like that it had to be pushed up and held there for a bit. That didn't happen just by the exhaust dropping. That was why I was wondering about marks underneath. Maybe backed into an angled curb that pushed it up without catching it so you didn't even know it happened?
Rabbit of Caerbonnog (08-24-2015)
Old 08-24-2015, 10:42 AM   #20
DavidBob
DavidBob's Avatar
Sorry I was a little unclear, like i said above it would come off the hanger (like slide to the right) and push against the bumper and I guess since it melted a hole through the bumper it couldnt lean on it anymore so thats when it fell on the ground. I don't know when it actually broke from the weld thats just when i noticed it because i went under to put it back on.
The Following User Says Thank You to DavidBob For This Useful Post:
Tcoat (08-24-2015)
Old 08-24-2015, 10:42 AM   #21
extrashaky
Drives: 2014 BRZ Limited
How badly has it hit? Are there marks underneath? I ask because as much as it would certainly appear to be a bad weld it could also have been broke off by repeated hits.
I don't know about the hitting or melting, but that is most definitely a bad weld. Look at the last pic he posted of the hanger. The weld is undercut. It would most likely be undercut on the pipe also, which would make the metal thin and weak right there. It's no wonder it cut loose.
Banging it on the ground didn't help, but a proper weld should have held anyway.
Old 08-24-2015, 10:46 AM   #22
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Last time when my buddy called Buddy Club in California about ordering parts to fix his N1 coilovers they told him to call back because the dude was busy eating his fried chicken lol true story.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Old 08-24-2015, 10:47 AM   #23
Run Away!
Originally Posted by krayzie View Post
Last time when my buddy called Buddy Club in California about his N1 coilovers they told him to call back because the dude was busy eating his fried chicken lol true story.
You never interrupt a man and his fried chicken. Never.
The Following 2 Users Say Thank You to Rabbit of Caerbonnog For This Useful Post:
krayzie (08-24-2015), Tcoat (08-24-2015)
Old 08-24-2015, 11:46 AM   #24
Imrac
Drives: 13 SWP BRZ Prem
Originally Posted by smudge View Post
You do realise that just sticks over the OEM valance? It'll still melt when the exhaust sits up against it like it has
Yes, I understand.. The reason why it melted was because the hanger broke off and caused the tip to come in contact with the OEM Valance. My recommendation (Although semi-sarcastic) still is valid assuming he resolves his hanger issue.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Buddy Club Racing Spec Damper, Buddy Club Ball Joints, Megan Extended Tie Rods, etc Chase Bays Brakes, Suspension, Chassis 14 02-03-2016 09:14 PM
Buddy Club Spec II F/S FastWhite Engine, Exhaust, Bolt-Ons 3 11-23-2014 02:33 AM
WTB: Buddy Club Spec II A r l a N Want-To-Buy Requests 0 04-03-2014 08:34 PM
buddy club spec II and UEL ? FRS-Jonathan Engine, Exhaust, Transmission 4 04-16-2013 09:58 AM
Buddy Club Spec II exhaust!! raz0rbladez909 Engine, Exhaust, Transmission 28 01-23-2013 07:13 PM
