Old 06-27-2015, 03:18 AM   #197
cf6mech
Drives: FRS Silver LS1 swapped.
Glad to see another LS in a FRS/BRZ.....this car was made for this swap. Expect to see alot of them.
cf6mech is offline   Reply With Quote
Old 06-27-2015, 03:23 AM   #198
cf6mech
Another swap in Florida
[ame="https://www.youtube.com/watch?v=Bz2YuyHf1CM"]LS FRS Swap First Start up - YouTube[/ame]
Old 06-27-2015, 01:10 PM   #199
Fernan Andrade
Fernan Andrade's Avatar
Drives: FRS
Originally Posted by AZFA20 View Post
I have TrickFlow heads, FAST 102mm intake manifold, TrickFlow cam, and a lot of other go fast goodies all on the shelf waiting to go in soon.
Really it all depends on your budget and goals as far as recommendations go.
Nice man! What size TB? What is the duration on your cam? I am staying the NA route for now.
Fernan Andrade is offline   Reply With Quote
Old 06-27-2015, 05:49 PM   #200
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
102mm and 291/295 (ad)
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 08-22-2015, 07:54 AM   #201
Traktor
Drives: Subaru BRZ Limited
Originally Posted by Suprastar View Post
That's one of the better aspects of the LSx V8s, they don't wear to the point of needing rebuilt, and there's no need to waste money on stroking even the 6.2L, though it is easy if you have mega $$. To date I've owned a half dozen of these engines, all well over 100,000 miles, and all still had the crosshatch, from honing, easily visible in all of every cylinder. Sure, most need valveseals, but that's part of installing the set of new Z06 or Comp 26918 springs for whatever cam you like.
Do the seals, the thing's ready for another 100,000 miles.
The iron-block truck versions are plentiful and therefore cheap, only 65 # heavier than aluminum-block, and 4.8L versions are going for $300, 5.3L are around $500, and 6.0L starts at $800.
'07-up have better heads and beefier rods, but most are 58x rather than 24x (crank reluctor) But don't use pre-'01. In fact, every one of mine have been '01s. The early 4.8s are good to 7500 RPM with appropriate valvetrain upgrades. All are safe past 6500 RPM. Try to get #799 or #243 heads if getting a later 5.3, and the later 6.0L heads may have the rectangular-port (intake) heads that flow better but reduce off-idle torque. That's the way to go for cost-effective NA power.
Combining LSx power with 4-cylinder gearing is a fail, plan on a T56, or a T5-WC from an '88-'92 Camaro V8 if NA 4.8L, ( TBI was 0.63:1 fifth, TPI was o.73:1, but 0.59:1 and HD 0.80:1 both exist) and for differential gearing, if your Toy / Sub diff doesn't offer a ratio around 3.5:1, then plan on an aluminum Ford 8.8" from a mid-'00s Shelby Mustang Cobra. You'll never break that. Ratios range from 2.47:1 well into the 5s. And more different types of traction diffs than anyone could want.
Any pure-stock LSx can happily pull a 1500 RPM cruise at 65 MPH in these cars, and the T56 offers a 0.5:1 sixth to help. You can combine that with either a 2.66:1 or 2.97:1 first, try for a combined first gear in the 9.00:1 - 10.00:1 range, for rear tires around 26" overall. If you're closer to 25", then calculate accordingly. Bigger cams will need more RPM at cruise, even after a good dyno-tune.
That's part of why I like the '01-'06, they use the #0411 PCM that was figured out long ago, so tuning is cheap and easy, but it can do anything and everything you really need.
I am thinking an L33 aluminium block with 4.8 rods/crank/Pistons would be ideal for the FRS? Should produce just the right amount of power at higher revs which would suit the character of the car nicely. Someday!
Traktor is offline   Reply With Quote
Old 08-23-2015, 05:50 AM   #202
DHitHim
Drives: 2015 CWP Limited BRZ
can you retain AC?
DHitHim is offline   Reply With Quote
Old 08-25-2015, 07:53 PM   #203
AZFA20
AZFA20's Avatar
Originally Posted by DHitHim View Post
can you retain AC?
Mine has A/C......
The Following User Says Thank You to AZFA20 For This Useful Post:
SoCal80six (11-11-2015)
Old 02-01-2016, 10:30 PM   #204
Michaelg497
Drives: 240sx
This is the gnarliest 86. I've seen a clip of it drifting but don't remember where. http://s3mag.com/blog/daisuke-miyazakis-toyota-ft86/
Michaelg497 is offline   Reply With Quote
The Following User Says Thank You to Michaelg497 For This Useful Post:
Chrisgalactic (03-23-2016)
Old 02-02-2016, 11:04 PM   #205
justinsstang
Learn me to LS swap plox
But no seriously how much does this end up costing? I don't know what LS motor to even pick. Long as its around 400 crank I don't see an issue running any of the LS. Just don't know pricing.
justinsstang is offline   Reply With Quote
Old 02-03-2016, 02:05 PM   #206
NOHOME
Drives: RAVEN
How much can you afford?
Bottom line DIY is going to be about $15,000 Send it out to Vorshlag and write the check when they are done is going to be over $50,000
If you are a determined fabricator and scrounger with arms that don't reach all the way to your wallet, you can do it for a lot less. But it is on you to shop and chop.
NOHOME is offline   Reply With Quote
Old 02-03-2016, 07:11 PM   #207
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
http://www.ft86club.com/forums/showp...6&postcount=39
I spent under $10,000 but then my used LS took a dump. You can save money by doing things yourself but if you cheap out on parts eventually something will fail you.
wutsaiu is offline   Reply With Quote
Old 02-08-2016, 02:31 AM   #208
Amir Ghadiri
Amir Ghadiri's Avatar
Ironically my LS took a dump too
Amir Ghadiri is offline   Reply With Quote
Old 02-08-2016, 02:14 PM   #209
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
True, but theoretically, if you had decided to do a full rebuild before installing the motor, your cost wouldn't have increased too terribly much. Your build is still an excellent demonstration of limiting cost.
...And proof that it can be done for less money than the naysayers are proclaiming.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
cf6mech (02-09-2016)
Old 03-31-2016, 12:19 AM   #210
NP86GT
Drives: 2012 Toyota 86
Has anybody done one of these in Australia?
NP86GT is offline   Reply With Quote
Engine Swap: Which Would You Choose!?? EvoFanatic Engine Swaps 149 08-08-2017 04:34 AM
Engine Swap ... Macavely Engine Swaps 220 07-25-2012 04:58 AM
Engine swap question koyv90 Engine, Exhaust, Transmission 4 03-22-2012 02:08 PM
4U-GSE: the new engine swap for old Toyotas no_name Engine Swaps 17 12-19-2011 10:50 PM
engine swap thread aspera Engine Swaps 231 03-15-2011 06:10 PM
