#15 |
Site Moderator
Drives: ichi 86 Project
OMG that quote made me laugh out loud at work!!! I know you weren't trying to be funny or anything, but in my head w some random guy's voice reading that quote made me laugh
#16 |
Proud of FR Layout
Drives: 2013 Scion FR-S 6MT
same here. Feels similar to any miata/s2k Ive driven just a bit louder/more noticable.
#17 |
Drives: SWP BRZ LTD
Which would make sense. Aren't they using basically the same transmission, minus their own custom tweaks?
#19 |
Drives: First SWP BRZ-L
mine thuds too.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#20 |
Considering I've driven a RWD car for all of 10mins in my life, I'll have to get used to this.
| The Following User Says Thank You to Jayde For This Useful Post: | NYC BRZ (06-03-2012) |
#21 | ||
Drives: 2013 BRZ premium dgm
is there any actual technical data showing the actual cause of this occurance? i'll try doing the stop and wait next time i drive |
#22 |
Lex Luger
Drives: 2004 GS430
Gonna test the delayed entry tomorrow as well, since the "thud" caught my attention as well.
#23 | |
Drives: 2017 Subaru BRZ PP
Toyota + Subaru =
#24 |
Drives: RX8
This thud issue was commonly discussed on the RX8 Forums. Try disengaging the clutch, wait for 2 seconds so the input shaft stops spinning, then engage the gear and see if it still thuds. If it does not, the thud is being caused by the shock through the drivetrain when you force the spinning input shaft to suddenly stop by engaging 1st.
A quote from RX8Club: "FYI: The transmission mainshaft is turning when the clutch is engaged (i.e., pedal out) in neutral. (Listen for the sound of the shaft "rattling" against it's bearings in a quiet area.) So when you push in the clutch pedal (disengage the clutch) it takes a bit of time, like a second or less, for the main shaft to spin down. If you shift before that happens, you can get a crunch, thud or whatever you want to call it." |
| The Following 3 Users Say Thank You to AMAXRX For This Useful Post: |
#25 |
Drives: Brz black
Yeah mine does this also
#26 |
Drives: '13 WRB BRZ
Thanks was wondering what this was. This doesn't happen in AWD?
#27 | |
I've never noticed this in 2 awd subis 1 rwd truck and 1 fwd car all manual trans |
#28 |
Yeah, mine does it too every now and then. I'll try leaving it disengaged a bit longer to see if it stops.
