Old 05-31-2012, 07:09 PM   #15
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Mine rolls nicely on hills So I'd guess no.
OMG that quote made me laugh out loud at work!!! I know you weren't trying to be funny or anything, but in my head w some random guy's voice reading that quote made me laugh
Old 05-31-2012, 07:10 PM   #16
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
same here. Feels similar to any miata/s2k Ive driven just a bit louder/more noticable.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 05-31-2012, 07:26 PM   #17
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Which would make sense. Aren't they using basically the same transmission, minus their own custom tweaks?
blu_ is offline   Reply With Quote
Old 05-31-2012, 07:30 PM   #18
mattles
Proud of FR Layout
mattles's Avatar
they all start with the same Aisin AZ1 unit, yep.
Old 05-31-2012, 07:39 PM   #19
Tainen
Drives: First SWP BRZ-L
mine thuds too.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 05-31-2012, 08:44 PM   #20
Jayde
Jayde's Avatar
Considering I've driven a RWD car for all of 10mins in my life, I'll have to get used to this.
Jayde is offline   Reply With Quote
The Following User Says Thank You to Jayde For This Useful Post:
NYC BRZ (06-03-2012)
Old 05-31-2012, 09:45 PM   #21
earthsscum
earthsscum's Avatar
Drives: 2013 BRZ premium dgm
Originally Posted by Draco-REX View Post
My BRZ does it as well. It's as if the clutch doesn't fully disengage.
I'm having trouble getting my shift points down. I think it's a mix of a lighter rotating assembly and overly light clutch.
Originally Posted by blu_ View Post
Oh hey I just posted about this in a different thread.
I think its just the syncros stopping output shaft.
I haven't tried this yet, but try waiting for a while after you stop before shifting into first gear, for the output shaft to stop moving.
ok so apparently this is pretty normal as many others are experiencing this too..
is there any actual technical data showing the actual cause of this occurance?
i'll try doing the stop and wait next time i drive
earthsscum is offline   Reply With Quote
Old 05-31-2012, 10:46 PM   #22
YukiHachiRoku
Lex Luger
YukiHachiRoku's Avatar
Drives: 2004 GS430
Gonna test the delayed entry tomorrow as well, since the "thud" caught my attention as well.
YukiHachiRoku is offline   Reply With Quote
Old 05-31-2012, 10:51 PM   #23
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Originally Posted by bneale View Post
Slightly off topic here. But does the manual BRZ/FRS actually have a hill holder feature?
Just wondering because this will be my first manual car and I would love to have this feature. One of the things which scares me is starting on hills with a manual. So the whole automatic break thing is pretty sweet.
I'm just not 100% sure the BRZ/FRS has this or not.
bneale
It's just a matter of being somewhat quick about it when you let off the brakes. Build the revs a little more than you normally would and slowly slip the clutch out as normal. And don't panic. Even if you do stall, just brake and start the engine again and go. I think I've only stalled on a hill once and that was because I was being super lazy with the clutch and gas. It's really no big deal at all unless somebody is literally on your rear bumper. I actually like being able to roll back without engaging reverse sometimes.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-01-2012, 08:36 PM   #24
AMAXRX
Drives: RX8
This thud issue was commonly discussed on the RX8 Forums. Try disengaging the clutch, wait for 2 seconds so the input shaft stops spinning, then engage the gear and see if it still thuds. If it does not, the thud is being caused by the shock through the drivetrain when you force the spinning input shaft to suddenly stop by engaging 1st.
A quote from RX8Club:
"FYI: The transmission mainshaft is turning when the clutch is engaged (i.e., pedal out) in neutral. (Listen for the sound of the shaft "rattling" against it's bearings in a quiet area.) So when you push in the clutch pedal (disengage the clutch) it takes a bit of time, like a second or less, for the main shaft to spin down. If you shift before that happens, you can get a crunch, thud or whatever you want to call it."
AMAXRX is offline   Reply With Quote
The Following 3 Users Say Thank You to AMAXRX For This Useful Post:
earthsscum (06-01-2012), Fly Guy (06-02-2012), QC-FRS (06-02-2012)
Old 06-01-2012, 08:40 PM   #25
Black brz
Drives: Brz black
Yeah mine does this also
Black brz is offline   Reply With Quote
Old 06-01-2012, 09:44 PM   #26
Partial Stall
Drives: '13 WRB BRZ
Thanks was wondering what this was. This doesn't happen in AWD?
Partial Stall is offline   Reply With Quote
Old 06-01-2012, 11:32 PM   #27
earthsscum
earthsscum's Avatar
Very good info thanks
I've never noticed this in 2 awd subis 1 rwd truck and 1 fwd car all manual trans
Old 06-02-2012, 12:30 AM   #28
Jayde
Jayde's Avatar
Yeah, mine does it too every now and then. I'll try leaving it disengaged a bit longer to see if it stops.
