Old 08-17-2015, 07:51 PM   #43
ravisraval
Drives: 2013 FRS
Quickly jumping in here, did y'all check to see if the stock headunit setting resetted back to "tC"? That's what happened to me when I had my sub and amp installed (not OEM+, different unit). Thought the hu would have some capacitors to keep the settings after disconnecting the battery but it doesn't.
Changed it back to FRS, my preferred setting, and it sounded much better.
It's supposed to be on TC for this system.
ravisraval is offline   Reply With Quote
The Following User Says Thank You to ravisraval For This Useful Post:
soulreapersteve (08-18-2015)
Old 08-18-2015, 06:27 PM   #44
DJCarbine
Thupercharged
DJCarbine's Avatar
Originally Posted by ravisraval View Post
Sennheiser 280, so not the top of the line but certainly good.
Listened a lot when the car is stopped and when driving. Even when it's stopped the quality is meh.
I still rate those are "cheaper" headphones and I usually don't like to compare headphones to speakers.... case in point, I much prefer the sound of my somewhat modest monitors to the sound of the sennheiser HD800 phones.
Does it just sound too flat for your tastes? The more I listen to this system the more I am loving it. Did you find anything wrong with the install/harness connectors? Remember to disconnect the dash speakers?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 08-20-2015, 04:39 AM   #45
ravisraval
Drives: 2013 FRS
Flat would be great. It's oddly muddy at times, often in the midrange. I disconnected (and actually removed) the larger dash speakers. Couldn't find any other issues with the connections.
Old 08-20-2015, 09:47 AM   #46
twag4
Drives: frs
Something isn't right. Mine is not muddy at all. I'd call them!
twag4 is offline   Reply With Quote
Old 08-22-2015, 03:29 PM   #47
DJCarbine
Thupercharged
DJCarbine's Avatar
I took my sub back off and wiggled the connections a lot and got some more slack from the harness that you cut the slot for. Maybe its placebo but the sub sounds stronger and its actually got some more fidelity. I wonder if one of the pins was not making good contact when the sub was installed due to not enough slack...
2013 FRS
Vortech V3 11psi
Old 08-22-2015, 06:20 PM   #48
twag4
Drives: frs
Could be! I hope it works out for you. If not, definitely call them. Great accessibility and customer service. They apparently will answer 24 hours a day 7 days a week
Old 08-23-2015, 05:03 PM   #49
dinoniel
OEM audio plus customer service is second to none. I have dealt with them extensively because I'm picky about how my music sounds and they have worked with me very patiently. I have never had an issue contacting them by phone or email. Would recommend talking to them about your issues.
dinoniel is offline   Reply With Quote
Old 08-30-2015, 09:52 PM   #50
Chrisbrz14
Chrisbrz14's Avatar
Drives: Subaru Brz
Im thinking about buying this system where can i get the best deal?
Chrisbrz14 is offline   Reply With Quote
Old 08-31-2015, 08:31 AM   #51
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
FT86SpeedFactory has 2% off. I'm a deal shopper and this is the best that I could come up with. OEM+ has run promotions before, but nothing current I believe.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
Chrisbrz14 (08-31-2015)
Old 08-31-2015, 05:54 PM   #52
EdibleSmurf
EdibleSmurf's Avatar
Drives: Scion FR-S
Has any tried this? @Chrisbrz14
EdibleSmurf is offline   Reply With Quote
Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! CamryDS Audio/Visual, Electronics, Infotainment, NAV 25 10-23-2015 09:10 AM
Pondering audio upgrade options; have questions, want recommendations SilverlightPony Electronics | Audio | NAV | Infotainment 17 05-11-2014 05:38 AM
soundman's audio build and questions soundman98 Electronics | Audio | NAV | Infotainment 0 01-20-2014 08:59 PM
Scion Display Audio Questions 1ucky11 Electronics | Audio | NAV | Infotainment 13 11-03-2013 11:51 AM
'Noobish' questions as I look to upgrade my car audio audio. DkY in Vcr Electronics | Audio | NAV | Infotainment 0 09-22-2012 09:45 PM
