Old 08-19-2015, 05:45 PM   #15
extrashaky
Drives: 2014 BRZ Limited
@extrashaky
I run autometer for my oil temp and it sits just over 220F on hot days thats why I want to bring it down a little haha!
I wouldn't worry about it. That temp is right in line with what I see in mine. I've been sending my oil off to Blackstone for analysis at each oil change, and the oil reports are coming back with no issues. The engine and the oil seem to be holding up just fine.
The Following User Says Thank You to extrashaky For This Useful Post:
Ultramaroon (08-20-2015)
Old 08-19-2015, 05:46 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
@extrashaky most people don't see the coolant temp gauge go up even during a 20 minute track session in the heat.
ineedyourdiddly
Old 08-19-2015, 05:50 PM   #17
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
LOL I do UOA too! Mine always seem good too!
Old 08-19-2015, 06:25 PM   #18
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Was out at Buttonwillow Raceway this past weekend and even in the later sessions where ambient air temp was 102 degrees, with the car getting a full flogging, the coolant temp gauge needle never budged from it's usual place. I knew coolant temp had to be warmer; just figured the gauge was broken until I read this thread.
PWBRZ is offline   Reply With Quote
The Following User Says Thank You to PWBRZ For This Useful Post:
strat61caster (08-19-2015)
Old 08-19-2015, 10:01 PM   #19
Poodles
Drives: 2015 Series.Blue
@extrashaky
I run autometer for my oil temp and it sits just over 220F on hot days thats why I want to bring it down a little haha! I have no idea what my coolent it though, But thanks for your insight!
Many people start freaking out at oil temp over 200F for some reason. It NEEDS to get above the boiling point of water so it can boil off the contamination.
Old 08-20-2015, 01:46 AM   #20
I disagree with this. Water does not need to be boiling for adequate rate of evaporation. Case in point - oil cooler thermostats are generally designed to maintain oil temp around 180-185 degrees Fahrenheit.
...but 220 is no biggie as long as pressure doesn't drop off. I don't know because I still don't have a pressure gauge
Tcoat (08-20-2015)
Old 08-20-2015, 09:47 AM   #21
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Like the other guy said it boils off as it gets close to 212, it doesnt just happen all at once. I just dont like how the ECU pulls power (I read that somewhere dont quote me, but my butt dyno seems to feel it, although it could just be AIT's getting too high in traffic aswell)
Old 08-21-2015, 01:41 AM   #22
Poodles
Any thermostat will open earlier than the desired peak temp to head off temp spikes. Local heating of the oil is going to be higher than what the overall temp is going to be as well, but getting the oil good and hot every so often (in my case, usually daily) is far better than having it cold. Yes of course there is such a thing as too hot, but the average person isn't going to see that outside of track use.
Most cars will pull timing a bit when things get too hot. You're usually going to have this stuff step in from coolant temp or IAT first though. Never had a car that didn't hate the hot ass summers around here...
Noob help please WhiteShadowFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-24-2014 09:22 AM
radiator noob question/IAT's BRZPDX Forced Induction 4 06-02-2014 10:17 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 12:18 PM
Mishimoto Radiator & Mishimoto Radiator Hose Kit tlinspired830 Engine, Exhaust, Bolt-Ons 5 01-08-2014 08:44 AM
noob help juanam0909 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 09-28-2013 01:17 PM
