Old 07-28-2015, 01:46 PM   #15
jesse_86frs
jesse_86frs's Avatar
Drives:
Originally Posted by mervingee View Post
I'm having the same trouble you had except on mine the V or anything won't light up I'm a little confused on which wires go where. I'm trying to run it with the tails and brakes applied. Can you help possibly? When I unlock and lock the car the V seems to light up along with the emergency hazards.
Pics of your wiring can I see ? Sounds like you have the v light wired up as a turn signal , that happened to me the first time .
jesse_86frs is offline   Reply With Quote
Old 08-08-2015, 07:25 PM   #16
Sgtfluffy16
Drives: White BRZ Limited
this is a little off topic but how is this installed? wiring wise, like I know you pull the factory wiring out from the OEM reverse light. but does the IJDMtoy wiring fit just like the OEM? does it fill the hole with a rubber plug where the wiring exits the vehicle? Does it also have an OEM plug where it plugs into the OEM reverse light wiring
Sgtfluffy16 is offline   Reply With Quote
Old 08-11-2015, 11:20 PM   #17
jesse_86frs
Drives:
No it doesn't from what I remember it just goes through the hole once you removed the oem wire. The wire that comes with brake light plugs right into the oem cable inside the trunk area.
Old 08-14-2015, 11:01 AM   #18
Sgtfluffy16
ehhh i spent more money for the nice, more clean valenti one.
Old 08-18-2015, 11:29 PM   #19
jesse_86frs
Drives:
We all have different likes & taste, congrats on the nice, more clean valenti brake light.
Old 04-21-2016, 11:19 AM   #20
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
i know the valenti one blinks when you press the brakes but the iJDMToy does not. Is that correct?
DuMa is offline   Reply With Quote
Old 04-26-2016, 08:51 AM   #21
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Yes. It's also worth noting that unless you're willing to pull your valenti 4th brake light apart and do some re-soldering, the "V" only comes on with the blinking triangle. The ijdmtoy brake light turns the "V" on with the running lights and the triangle works with the brake lights, as you'd expect. Works great, looks great, glad I went with ijdmtoy over valenti for mine, but all depends on what you want.
xxBrun0xx is offline   Reply With Quote
Old 09-23-2016, 04:46 PM   #22
SlmedFRS
SlmedFRS's Avatar
Drives: Scion FRS, Bagged Lexus IS350
omg good thing I found this thread. I just placed my order on the iJDMtoy one too. Great thing theres good reviews about them!
Hang on a second I'm lowered
SlmedFRS is offline   Reply With Quote
Old 09-30-2016, 10:46 PM   #23
Doctorjobj
Drives: Man
Send a message via ICQ to Doctorjobj
iJDMToy Valenti Brake L
good job man.
i wanted to fab my own led 3rd brake light but when i saw tony selling them, just got that instead.
so on the hatch the cover cant be installed back?
Doctorjobj is offline   Reply With Quote
Valenti Bumper Light $179.99 Tail Light $299.99 Fog Light Kit $90.99 nigel-jdmparts Exterior Parts - Lighting 14 06-23-2015 06:32 AM
SOLD -Valenti Tails and Valenti 3rd light (Smoked) / Wheelhaus' headliner brake light AtlasMick Exterior Parts (Aero, Lighting, Etc.) 8 03-07-2015 06:51 PM
iJDMTOY flashing 4th break light ReaperX43 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-19-2014 09:57 AM
Valenti Fourth Brake Light With Stock Tails mackdaddytran Cosmetic Modification (Interior/Exterior/Lighting) 0 06-20-2014 11:03 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
