Old 08-18-2015, 02:39 PM   #29
AVOturboworld
I'd first find out if you are actually only reaching peak boost at 5000rpm, which sounds quite high.
This is more typical of what we see here on 92 octane.
Old 08-18-2015, 02:45 PM   #30
ChrisD
ChrisD's Avatar
Drives: GT86
Your first response to me has told me all I need to know. I have no desire to provide you with any further information. Enjoy your new found power, however you choose to find it.
haha sorry for not wanting more power for "the right reasons" in your opinion. Jesus, get over yourself. The funny thing is as soon as you asked why I want the extra power I said to my friend I bet whatever I say this guy will not approve... and oh what a surprise, you don't.
My GT86 build so far:
AVO Stage 4 Turbo, Carrillo forged con rods, 10:1 CR Carrillo pistons, AVO 3 inch turbo back exhaust, Helix clutch, TheDriveShaftShop drive shafts, lightweight flywheel, NamelessPerformance hydraulic hand brake, KW V3 coilovers... and lots of other little bits
ChrisD is offline   Reply With Quote
Old 08-18-2015, 02:50 PM   #31
ChrisD
ChrisD's Avatar
Drives: GT86
OK I'll check, but I'm pretty sure from glancing at my boost gauge previously that it is mid/high revs when it hits the highest boost pressure rather than anything like 3K rpm. Oh and I'm using 99 octane most the time.
Old 08-18-2015, 03:35 PM   #32
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, you're using 99 RON It's equivalent to 92.5 octane as most would know on here (that's good 92.5 BTW)
Chris, the basic answer is:
Run lower CR to give you more boost headroom, but at the loss of low end power and raising the spool RPM.
You have to decide whether that is what you want. Some people want a car that has good response, others want a bragging hp/drag car. As pointed out, your boost may be mapped to come in gradually to be kind to the OEM rods. Most would agree it's very expensive (and possibly pointless) to open up the block just to replace the rods and keep the pistons OEM.
.: Stealth 86 :.
Kodename 47 DJ:
ChrisD (08-18-2015)
Old 08-18-2015, 05:13 PM   #33
ChrisD
ChrisD's Avatar
Drives: GT86
Ah ok thanks for the correction. I did think RON and octane were different but I quickly googled the octane of the fuel I use before posting that previous reply and all that came up was "99 RON" so I thought maybe it is just the same as octane after all.
No I don't want a dyno queen or drag race car, I just want to make mine a bit faster by increasing the boost further (as I know it is not running at 100% of the turbo's capabilities at the moment). I always thought the main thing stopping us using maximum boost from this turbo was the potential damage to the rods and pistons, so I figured getting forged internals would solve that problem and a lot of people seemed to recommend getting lower CR pistons for forced induction so that's why I was going for 10:1.
So, without E85, what options do I have for increasing power? Could I just get the stronger rods, stronger valve springs, and stronger pistons but stick with a fairly high CR (let's say 11:1), and then be able to increase the boost a decent amount? or is there still going to be too much engine knock to be able to increase it much? The main thing I'm trying to find out is whether or not it is actually going to be worth the time/money getting the forged internals installed - if we can't actually up the boost that much afterwards then there's no point really
Old 08-18-2015, 05:18 PM   #34
frosty288
frosty288's Avatar
Drives: 2015 BRZ
Water/Methanol injection seems to be what you are looking for, instead of getting forged internals.
frosty288 is offline   Reply With Quote
The Following User Says Thank You to frosty288 For This Useful Post:
ChrisD (08-18-2015)
Old 08-18-2015, 05:26 PM   #35
Kodename47
Kodename47's Avatar
Drives: UK GT86
Piston damage is pretty much solely down to detonation. Rods is torque. You don't need to change anything if you can just increase boost at the top, but I guess you'd need a higher flowing turbo for that?
I'm sorry I can't give you an answer on CR vs boost.
.: Stealth 86 :.
Kodename 47 DJ:
ChrisD (08-18-2015)
Old 08-18-2015, 05:43 PM   #36
ChrisD
ChrisD's Avatar
Drives: GT86
That's not something I'd considered, but I'll do some research on it
Old 08-18-2015, 05:59 PM   #37
350matt
Drives: toyota mr2/ Toyota GT86
with a twin scroll turbo housing you can get something about the size of a GT28 / 30 spooling and making reasonable boost from about 2800rpm - this is on a ported compressor housing and this is a 400Bhp size of turbo
so if you know the size of the turbine and the compressor and what trim is on the wheel you can then make some comparisons to the industry standard turbo machines
I'd say with a lower ratio of 10.5:1 etc you should be able to wake the turbo up a bit earlier with a combination of additional spark and exhaust cam timing
if you research what turbo is fitted to something modern like a Golf R this would give a good indicaiton of what can be achieved with a modern 2.0ltr GDi turbo
350matt is offline   Reply With Quote
The Following User Says Thank You to 350matt For This Useful Post:
ChrisD (01-02-2016)
Old 08-18-2015, 07:12 PM   #38
ChrisD
ChrisD's Avatar
Drives: GT86
But everyone else has just been telling me a lower CR like that will mean the turbo comes on boost later rather than earlier
Old 08-19-2015, 07:33 AM   #39
350matt
this is true
ulitimatly how much power do you want? and what sort of torque curve shape do you want?
if the answer is 300Bhp then leave at 12.5:1 with low boost
if its 400 Bhp then you can just achieve this with 12.5:1 ratio and careful tuning
If its 450-500Bhp then you need to drop the ratio and boost it up
it will always be a compromise unless you fancy going the big boost Supercharger route?
Old 08-19-2015, 09:22 AM   #40
IBill4You
Drives: 2015 Subaru BRZ
You might want to take a look at this thread to find a viable metric to set your expectations.
http://www.ft86club.com/forums/showt...highlight=dyno
IBill4You is offline   Reply With Quote
Old 08-19-2015, 09:41 AM   #41
IBill4You
Post #3 from there is about what you should expect to be comfortable with on a stock motor. http://www.ft86club.com/forums/showp...40&postcount=3
GT2871R turbo
#10 E85 http://www.ft86club.com/forums/showp...0&postcount=10
GTX2867 E85
#69 http://www.ft86club.com/forums/showp...5&postcount=69
this shows the curves of 91 vs E85 for the GTX3076R
From these graphs you're not really going to make near peak torque until just under 5k unless you run a smaller turbo at regular compression. Seems like you would probably be fine keeping stock compression and running a big turbo on E85 at 15psi + to get more than you could handle.
The Following User Says Thank You to IBill4You For This Useful Post:
ChrisD (01-02-2016)
Old 08-19-2015, 12:32 PM   #42
Kodename47
Kodename47's Avatar
Drives: UK GT86
E85 isn't an option, we can't get it (or at least not at pumps, in cans it's ~£4 a litre).
.: Stealth 86 :.
Kodename 47 DJ:
VIDEO GUIDE - Installing Boost/Vaccuum/Oil Pressure/AFR Gauges The Sentinel DIY (Do-It-Yourself) Guides 3 04-25-2016 04:43 PM
WV: 04 STI Low miles Built 400+ AWHP 33K on chassis 1500 on engine $25K dakjones Cars for Sale/Trade 6 09-03-2014 08:05 PM
Anyone has Stroked and Built FA Engine yet ? Whitigir Engine, Exhaust, Transmission 11 03-14-2014 05:31 PM
Boost Pressure Leak Tester whitefrs Forced Induction 32 02-18-2014 02:51 PM
What is the best turbo for a fully built engine scion frs SUB-ZERO Forced Induction 41 09-18-2013 06:41 PM
