Old 08-18-2015, 10:25 AM   #1
yunheng
***** Lurker
yunheng's Avatar
Drives: 2015 GT86 1990 AE92
Question OFT help - A02J calibration ID?
Hi,
I have a 2015 build 86 and today i married the OFT with the car and it shows up CAL ID A02J. When looking through the Off-the-shelf maps, i only found they have A00J and A01J files. Is there a solution to this?
Also at the meantime i tried to log my stock tune, everything seems in order except for IAM values. They are constantly 0 in all 3 logs, from home to the office, office to the gym and gym to home. Could it be the fuel here is so bad that IAM dropped down to 0 throughout the 12k kms i have put it through?
Much appreciated.
Thanks
yunheng is offline   Reply With Quote
Old 08-18-2015, 10:48 AM   #2
yunheng
***** Lurker
yunheng's Avatar
http://www.datazap.me/u/lemonzz/log-...=0&data=1-5-12
http://www.datazap.me/u/lemonzz/log-...4?log=1&data=1
http://www.datazap.me/u/lemonzz/log-...4?log=2&data=1
These are the log files from the A02J tune file.
Old 08-18-2015, 11:33 AM   #3
yunheng
***** Lurker
yunheng's Avatar
It ok guys. I found the tune file i needed. However the IAM at 0 is still a question though..
Old 08-18-2015, 04:17 PM   #4
steve99
Drives: FT86
It will be a logging issue with OFT.
if KC Learned logs ok you can derive IAM from that.
look at your log here
http://www.datazap.me/u/lemonzz/log-...zoom=1274-1474
look at the log at rpm =6800, load = 1.1, KC Learned = 2.34 or around that area.
then look at the Knock Correction Advance Max A table in your tune as below
look up the same rpm/load value you get 2.81
if IAM =1 and no FLKC knock then the value in the Knock correction table should match the KC Learned value
yours is less so IAM is not 1 or you have FLKC (fine learning knock control ) active which you have not logged
If we assume FLKC =0 then
IAM = (KC learned value - FLKC) / (Knock correction Max A Value) at the load rpm point
IAM = (2.34 -0) / 2.81
IAM = about 0.8
the ECU interpolates values between cells so this is only a rough guide and we dont know what FLKC is (which may not logg correctly either.)
see here for more info
http://www.ft86club.com/forums/showthread.php?t=61820
Talk to the openflash guys about the logging they should be able to fix it up for you. email or call them.
Old 08-18-2015, 04:47 PM   #5
yunheng
***** Lurker
yunheng's Avatar
So i guess the fix would be an update to my tablet? Will give openflash guys an email by the end of today..
Old 08-18-2015, 05:00 PM   #6
steve99
Drives: FT86
I suspect the OFT guys will have to fix the logging ram addresses the tablet asks the ecu for for your rom type, once they have corrected that and you update your tablet should be ok, but they will need to fix problem first.
Old 08-18-2015, 05:03 PM   #7
yunheng
***** Lurker
yunheng's Avatar
Ok. Is shiv the correct person for me to pinpoint it to? Or via openflash website would be a good idea?
Old 08-18-2015, 05:08 PM   #8
steve99
Drives: FT86
emailing shiv is best option or emialing the openflash guys
dont use the forum PM messaging as shiv get so many pm's it just gets lost
email shiv at shiv@openflashperformance.com
New RPM Calibration TSB... 5AD86D Issues | Warranty | Recalls / TSB 23 01-21-2015 10:50 PM
changing calibration id garfull Software Tuning 3 09-14-2014 12:30 PM
Need Map calibration number!! Taino-BRZ Software Tuning 0 06-24-2014 10:59 PM
Speedometer Calibration!? AZOOZ_95 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 05-04-2013 08:07 PM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
