Old 08-17-2015, 07:39 PM   #211
JS + BRZ
Drives: 2010 MS3
What's like the usual service/replacement cycle for the bearing? Do you know, Mike?
Old 08-17-2015, 07:51 PM   #212
CSG Mike
CSG Mike's Avatar
Same as the clutch; 100% driver dependent.
On my S2k, my throwout bearing was starting to make noise at about 80k. At 116k, the splines on my clutch disk failed, as a result of heat from the throwout bearing, necessitating a clutch replacement. The clutch disk still had about 60% material left (as measured by thickness). You can imagine how many of those miles were track/canyon.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
JS + BRZ (08-17-2015), tracerit (08-17-2015), Ultramaroon (08-17-2015)
Old 08-17-2015, 07:57 PM   #213
Really!? Hmmmm...
Mine started to squeak back in May I believe. I've done two track days and a lot of hard canyon cruises.
Subaru Pacific just didn't want to open up the transmission and check it. They just told me to come back when it gets worse saying that I still have a lot of warranty miles left....
Well, there are 2 kinds of squeaks at play here.
1. Squeak from dry clutch fork pivot. That only squeaks while the pedal is in motion.
2. Squeak from the seized throwout bearing. This is intense and heard as soon as the throwout bearing comes into contact with the pressure plate.
I've experienced throwout bearing seizure in past vehicles. Cascade faliure of the pressure plate occurs almost immediately after. If you don't know how to drive without using the clutch. Park it and call a tow truck.
CSG Mike (08-17-2015), JS + BRZ (08-17-2015)
Old 08-17-2015, 09:21 PM   #214
That's a shit-ton of miles without seizure. I should mention to everyone that I only have firsthand homespun experience and that I'm pretty conservative about getting to it earlier than later.
Drove home tonight and didn't feel a hint of rumble in my left foot. Grrrr...
Old 08-17-2015, 09:23 PM   #215
CSG Mike
CSG Mike's Avatar
It was still spinning when it was taken out, albeit very, very scratchy.
Old 08-17-2015, 09:29 PM   #216
That's what I'm hoping for. Something that gives me plenty of warning.
Lazybones.
Old 08-17-2015, 09:37 PM   #217
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
I have some marine grease and was hoping to grease the clutch fork. What's the best way to go about that? I'm still getting a squeak daily when clutch is applied regardless of engine being on
Sent from my SM-G900V using Tapatalk
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
Old 08-17-2015, 09:54 PM   #218
There are 2 points. One is easy, the other requires pulling the geabox.
Locate the point where the slave actuator rod meets the clutch fork.
Have a little grain-of-rice sized dab of grease ready on your thumb.
With the same hand carrying the grease, pull the clutch fork forward, collapsing the slave actuator a little bit.
Then, while holding the rod with the other hand, squish that little dab of grease into the mating receptacle and let the rod seat itself back in.
If that doesn't do the trick, it's time to drop the tranny.
Old 08-17-2015, 09:56 PM   #219
CSG Mike
CSG Mike's Avatar
Make sure it's high temp grease.
Old 08-19-2015, 03:51 AM   #220
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by tunami View Post
I picked up my car today and the clutch is back to being smooth and no squeek. The tech said that a few cars have already been in for this fix, I'm sure they will see more
Here are the parts needed:
Wait... 4.5 work hours to replace and my dealer quoted my 1500 just for teardown and inspection? Something is really fishy. @Ultramaroon You work at a Toyota service dep? Can you comment on this? If it's 4.5 work hours by the book then they are charging me $333.33/hr labor? WTF
Intent > Content
Old 08-19-2015, 12:37 PM   #221
I'm just a guy who has had nothing but bad experiences whenever I've turned anything over to someone else. Be it repair, installation, construction, anything, my satisfaction rate is exactly 0%.
Decay107 (08-19-2015), JS + BRZ (08-19-2015), solidONE (08-19-2015)
Old 08-19-2015, 02:34 PM   #222
xlid007
Drives: Scion FRS
This is what was replaced on my claim so you guys have an idea.
https://www.dropbox.com/s/srv7z9a71l...%20PM.jpg?dl=0
xlid007 is offline   Reply With Quote
Old 08-19-2015, 04:08 PM   #223
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
This thread seems more active in the summer time. Now that I'm out of warranty feel like this is just a ticking time bomb. I've only had the noise come back on very hot and humid days. Will keep an eye on it as the temps decrease
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 08-19-2015, 04:42 PM   #224
JS + BRZ
Drives: 2010 MS3
The pics don't show!
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
