#715 |
Drives: 2014 BRZ Limited - 1986 AE86
I just setup Torque Pro on my Nexus 7. I wasn't going to attempt to add Oil Temp as a layout gauge, but then I noticed that it was reporting data in the selection menu. I placed it on the layout and it seems to be giving me a steady stream of oil temp data. It was rading around 195-215 in flowing traffic, didn't spend too much time watching it, but it seemed to be working.
2014 Subaru BRZ LTD - Dark Gray Metalic
1986 Toyota Corolla GTS - CA18DE Powered http://club4ag.com/forums/viewtopic.php?f=7&t=1247 http://www.86garage.com/forums/viewt...hp?f=40&t=1459 |
#716 |
Because compromise ®
Drives: Red Herring
I did on google search in this thread to no avail.
I will be installing a Delicious Tuning flex fuel kit soonish. Can someone tell me if I can activate the ethanol % field in Torque?
#717 | |
Drives: FT86
my understanding is torque app requests predifined factory pid's, ie the factory ecu will respond to these predefined requests. These are standardized across manufacturers hence torque or other apps can request this standard information from many factory ecu's. Ecutek flex fuel is a hack or patch on the standard ecu code, its unlikely that ecutek would also patch the ecu obd request routines so the ethanol content was readable via obd requests and hence torque apps. Ecutek hijacks the rear 02 sensor or evap purge connection to the ecu for flex fuel sensor input. If they did that they would not need to sell you the ethanol readout display kit or bluetooth device to send ethanol readout to your phone/tablet ect :-) |
| The Following User Says Thank You to steve99 For This Useful Post: | Captain Snooze (08-06-2015) |
#718 | |
Drives: BRZ Club blanc perle
Collecteur et frontpipe Supersprint full décat - Catback Remus Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons |
| The Following User Says Thank You to banane63 For This Useful Post: | steve99 (08-06-2015) |
#719 | |
Drives: FT86
although it may not work as ecutek likely disable the normal functioning of these sensor inputs as they would not want the ecu seeing the ethanol sensor inputs as rear 02 or evap purge readings. but i thought he was referring to the pre designated e% pid in torque app ? |
#720 | |
Drives: Red Herring
Delicious Tuning have an Android app for reading ethanol content. Sure, I would have preferred reading the percentage in Torque but this app runs an exceptionally close 2nd.
#721 |
Drives: FT86
not sure if youyr aware but a guy in coff harbour throttlehappy tuning has developed a flex fuel patch for A01G rom and can addapt for other roms, he is using brz edit he is on facebook. He does travel a bit to other cities on east coast.
| The Following User Says Thank You to steve99 For This Useful Post: | Captain Snooze (08-10-2015) |
#722 |
Drives: 2013 Toyota 86 GT
I wanted to add shift lights to my Torque Pro display, so I downloaded this RacingMeter plugin, however I can't seem to display the Oil Temp using their customizable display.
Has anyone used this? https://play.google.com/store/apps/d...ortorque&hl=en |
#723 |
Drives: Subaru BRZ
Disable / Enable seatbelt beep
Hi everybody,
I found something that should be useful to those hating the seatbelt beep (just the beep, if you hate the seatbelt it's another problem and it's in the head, not in the car )First of all, proceed at your own risk, I've tested these PIDs on my car (BRZ 2014) but i'm not responsible if you do something wrong or if your car is somewhat different than mine, To check the current settings add this PID (this should be completely safe as you are just reading): OBD2 Mode and PID: 21A7 Minimum Value: 0 Maximum Value: 0 Scale factor: x1 Unit type: Equation: A OBD Header: 7C0 double check everything and press the TEST button If the response value is 61A7C0 seatbelt beep is on If the response value is 61A700 seatbelt beep is off If the response is different something is wrong, check again PID's configuration and retry If for some reason your response is different from what expected stop here before messing with your car If everything is ok add these PIDs To disable the beep: OBD2 Mode and PID: 3BA700 Minimum Value: 0 Maximum Value: 0 Scale factor: x1 Unit type: Equation: A OBD Header: 7C0 To enable the beep: OBD2 Mode and PID: 3BA7C0 Minimum Value: 0 Maximum Value: 0 Scale factor: x1 Unit type: Equation: A OBD Header: 7C0 Usage is the same, go to the edit page of the PID with the setting you want to write and press TEST DOUBLE CHECK EVERYTHING before writing value to ECU, i'm not responsible if something stop working as expected (even if you wrote the right values) Final warning: don't add these pids as instrument, they aren't meant to be
| The Following 3 Users Say Thank You to maregt For This Useful Post: |
#725 |
Drives: GT86
I will shoooot myself soon if I dont get this oil temperature PID working on torque pro!
![]() I tried many ways about this but still didnt get it! OBD2 Mode and PID: 2101 Minimum Value: -40 Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high) Scale factor: x1 Unit type: C Equation: AC-40 (no space between A and C; "AC" is the location within the response) OBD Header: 7E0 (Auto also works, but seems to take longer) Says only no data! I have 2012 GT86 and I tried that default oil temperature too but that not working either. Adapter is ELM 327, Phone galaxy S4 4G+ |
#726 | |
Drives: '13 Raven FR-S, MT
I'll share my settings once I get my hands on my tablet, will be a few hours Sent from my iPhone using Tapatalk |
#727 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Got to be your adapter. If default setting and the settings on 1st page don't work.
Sent from my XT1575 using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1 DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time) DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler |
#728 | |
Drives: GT86
I will try to uninstall it and install it again and see if it starts to work!
| Tags |
| android, app, boost, gauges, torque |
| Torque app for android question | Brody602 | Electronics | Audio | NAV | Infotainment | 8 | 01-08-2015 05:53 PM |
| Torque for Android | Freeman | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 11-23-2012 12:05 AM |
| Android Torque app questions | Craig | Engine, Exhaust, Transmission | 1 | 11-12-2012 05:14 PM |
| Bluetooth OBD scanner and Android Torque - less than 25 shipped | whataboutbob | Engine, Exhaust, Transmission | 7 | 10-20-2012 02:15 PM |
| Android Tablet + torque | CharlieChaos | Electronics | Audio | NAV | Infotainment | 3 | 10-04-2012 09:23 PM |
