Old 07-28-2015, 03:41 PM   #197
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by Efferalgan View Post
Indeed. Moreover, the replacement blower which I'm buying for my own money will be available (hopefully) only in mid-September. So my car will out-of-action for at least 3 summer months, which is sort of sucks
I was told end of Sept and I am paying air freight otherwise longer.
The Following 2 Users Say Thank You to wbradley For This Useful Post:
Efferalgan (07-28-2015), raven1231 (07-28-2015)
Old 07-28-2015, 04:05 PM   #198
raven1231
You guys are really making me want to get this kit!!!
Old 07-29-2015, 04:36 PM   #199
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I can sell you mine! Cheap! Requires some welding though, filter and traction fluid
BTW: got news from a fellow from Novosibirsk who installed V1 SC before all of us here in Russia and it failed first too - early this year. He has finally opened the failed unit and the picture was apparently identical to the other two units which failed later including mine: thread on the "cover" is gone. But in his case it went further - the body of the unit was cracked and the fluid went out. Waiting for his pictures - will post here once he sends them to me. This design seems to be totally corrupted.
If the replacement blower which I will hopefully get in Sept fails too - I'll be really angry
UPD: Here are the pics.
Efferalgan is offline   Reply With Quote
The Following User Says Thank You to Efferalgan For This Useful Post:
raven1231 (07-29-2015)
Old 07-29-2015, 04:56 PM   #200
raven1231
Thanks man! very very tempting ha ha... This is absolutely ridiculous and pathetic the company doesn't stand behind their product. Clearly this is a manufacturing problem, not user error.
Efferalgan (07-29-2015)
Old 08-16-2015, 08:42 PM   #201
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Originally Posted by DarwinTuning View Post
hks supercharger with no restrictor plate, fuel injectors+pump, no cats. 93 pump gas. It was 91F outside.
Car built and tuned in Moscow, Russia.
is that torque curve real?!
jdmblood is offline   Reply With Quote
Old 08-16-2015, 10:03 PM   #202
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Oh its real, convert the values.
Old 08-16-2015, 10:34 PM   #203
blindfold
Drives: brz
wow, is it really this unreliable, t518z is looking better by the minute
blindfold is offline   Reply With Quote
Old 08-17-2015, 01:29 AM   #204
HaDDeS
Touge worship
HaDDeS's Avatar
Drives: Forester STi SG9
Oh it sure is real and it can get even better !
HKS V2 + Stroker 2.1 + HKS V-cams + Injectors of course no restrictor, no cats ... and tune done in Japan.
400 nm , 295 ft/lb of torque at 6300rpm thats plenty to scare some "beetles" from Germany.
And it is a very reliable setup, the number of deficient units is marginal, but like with any mechanical stuff, it happens.
HaDDeS is offline   Reply With Quote
Old 08-17-2015, 09:31 PM   #205
blindfold
Drives: brz
does exhaust play a major role in the supercharger world? Or is it not as important with turbo (i have a single exhaust that i had plan to use with t518z and on the flip side was thinking getting an Amuse dual for the quieter exhaust note)? And also how is the transmission hold up with this massive amounts of torque, do you foresee any potential problems in the extended use? thanks
The Following User Says Thank You to blindfold For This Useful Post:
HaDDeS (08-18-2015)
Old 08-18-2015, 03:19 AM   #206
HaDDeS
Touge worship
HaDDeS's Avatar
@blindfold
the importnat part of the exhaust is the decat ... if you have a straight pipe and a good catback (Amuse is one of them) it will work just fine. No need for 3" massive exhaust, 60 - 65mm is plenty.
On the transmission, well so far it holds up well, but I treat it well too, no savage starts, not unnecessary hammering. I will soon replace the DriveShafts by Sti ones, and the tranny will be updated next January with the Dog gear Set from Greddy, that takes place in the original housing. That set of straight cut, dog type, gears is good for more than 600hp and 600nm. It also has closer ratios on 1 - 2 - 3 - 4, 5 is identical and 6 longer to catch 300 km/h
The Following User Says Thank You to HaDDeS For This Useful Post:
CxG (08-22-2015)
Old 08-20-2015, 03:37 AM   #207
blindfold
Drives: brz
@blindfold
thank you so much for the reply, i am still debating between a t518z and this hks supercharger unit. I honestly only need smooth 300whp NA like power but for the past two days I have been daily driving a gt28 non rs, non ball bearing 86 and it seems plenty of fun with a bit of lag in between... making the decision even more difficult. With 39mm or even enlarged 42mm retrictor plate, i think 300whp might be tought to hit. Without the restrictor plate, how many pounds/bar of boost are you seeing and does it surge a bit without the plate at all? Regardless I am glad to see a strong HKS supercharged car out there, thanks again for sharing.
Old 08-23-2015, 03:11 PM   #208
Efferalgan
The only HKS remaining (still running, other 3 died) HKS SC in Russia that I know is running almost 1 bar on stock internals w/o restrictor and 700cc DW injectors. That should be really close to 300 whp with a high-power tune (no dyno graph yet), but I think to hit the 300 whp mark with this SC it's better to upgrade the engine internals as it requires >1 bar of boost.
Old 09-04-2015, 04:18 AM   #209
Efferalgan
... and another one bites the dust.
This last one standing failed this week too after couple of weeks at 1 bar.
Old 09-04-2015, 10:08 AM   #210
wbradley
Sarcastic SOB
wbradley's Avatar
Efferalgan,
I should mention to you the replacement I had ordered was switched to a new part number as the current unit in production is for the Ver. 3 kit just coming out. I had to pay significantly more to the dealer I had order thru this week and have them change the part# on the order but I am told it will still arrive late Sept.
Also, you should know the Ver3 part will be the same as the Ver1 unit, it will use the 5 bolt pulley attachment, not the 1 bolt on the Ver2. You might need to get another pulley. Apparently they do sell 5 bolt pulleys individually , but not 1 bolt.
HKS never was able to tell me I had initially ordered a supercharger that could only use a 1 bolt pulley until I questioned them several times over a period of a few weeks, and they kept misinforming me that the Ver2 used a 5 bolt mount that you helped me determine was incorrect.
CxG (09-11-2015), Efferalgan (09-04-2015)
North America to get Subaru version but not Toyota version? Ground N Pound BRZ First-Gen (2012+) — General Topics 42 05-29-2014 12:23 AM
Hot Version Vol.116 ft. 86 & BRZ larryw BRZ Photos, Videos, Wallpapers, Gallery Forum 3 08-05-2013 02:14 AM
Hot Version Vol. 122 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 06-12-2013 10:03 AM
New hot version 4agze Other Vehicles & General Automotive Discussions 19 03-07-2012 09:08 PM
Do you think we are going to see a trd version or 5axis version of the FRS next week DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 9 01-04-2012 06:59 AM
