Old 08-15-2015, 09:08 PM   #1
sam69
Drives: GT 86
J2 Lower Control Arms
Has anyone installed a set of these http://control-arm-shaft-kit.dvautop...w-jmjokrollrjm or have any feedback on them .
Did a search and stuff all came up .
Looking to try and take a bit of twitchyness out of the rear of my 86 and thinking a set of LCA's might help am lowered app 1" .
Running 245 40 17's .
sam69 is offline   Reply With Quote
Old 08-15-2015, 09:39 PM   #2
Bergen23
Drives: '15 Halo FR-S
Just buy the SPC's
http://www.ft86speedfactory.com/spc-...l#.Vc_qJK2COnM
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
sam69 (08-16-2015)
Old 08-16-2015, 06:40 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
What do you mean by "twitchyness"? Rear toe has a huge impact on rear end stability. Do you know what your rear toe is set at? Why do you think lca will help?
kodyo (08-17-2015)
Old 08-17-2015, 09:30 PM   #4
sam69
Drives: GT 86
Rear toe is meant to be set at 0 but maybe need to get it checked again.
What's the best toe setting for the rear with the drop I have ?
I think the LCA's would help as far as traction goes being S charged as well but still learning
Old 08-17-2015, 10:38 PM   #5
kodyo
Drives: Scion FR-S
If you can't get toe zeroed with the stock setup, buy some toe arms. I recently bought some SPC toe arms for the very symptoms you have (twitchyness over bumps).
This place has best deal I could find personally, @$150 for a set, it's a really good deal IMO:
http://thmotorsports.com/spc-perform.../i-495481.aspx
kodyo is offline   Reply With Quote
The Following User Says Thank You to kodyo For This Useful Post:
kalamitykode (09-03-2015)
Old 08-17-2015, 11:30 PM   #6
Captain Snooze
Drives: Red Herring
Does that include exchange rate and freight to Australia?
Old 08-17-2015, 11:33 PM   #7
Captain Snooze
Drives: Red Herring
There is no best; it depends on what you want the rear to be doing. Zero toe makes rotation easier at the expense of stability. For street use I would suggest between 1-1.5 millimeters total toe in. Everything's a compromise.
Rear aftermarket lca arms are for mainly for camber adjustment and added strength. You mention traction issues but have not mentioned the tyres you are wearing. If you are already wearing wider stickier tyres (and don't go crazy wide either because compromise) I would recommend controlling your right foot.
Last edited by Captain Snooze; 08-18-2015 at 08:45 PM. Reason: changed degrees to millimeters
Old 08-18-2015, 11:19 AM   #8
kbye
kbye's Avatar
Drives: 2014 FR-S
There is no best; it depends on what you want the rear to be doing. Zero toe makes rotation easier at the expense of stability. For street use I would suggest between 1-1.5 degrees total toe in. Everything's a compromise.
I hope you mean camber because that is an insane amount of toe.
kbye is offline   Reply With Quote
Old 08-18-2015, 05:13 PM   #9
kodyo
Drives: Scion FR-S
Yeah, I was running .38 deg total toe in before the toe arms and honestly it felt pretty sketchy. Zeroing out the toe made it feel a lot better going over bumps.
Old 08-18-2015, 08:38 PM   #10
Turdinator
Señor Member
Turdinator's Avatar
I think he means millimetres.
A little toe in on the rear will add some stability.
1974 TA22 Celica
2013 86 GT
Old 08-18-2015, 08:43 PM   #11
Captain Snooze
Drives: Red Herring
My mistake. As @Turdinator said I meant millimeters.
kbye (08-18-2015)
Old 08-19-2015, 08:24 PM   #12
sam69
Drives: GT 86
Thanks for the help so just wondering what would be a good DD setup for the alignment?
From what I have gathered so far is about 1.5 camber front and 1 rear but not sure on toe front to rear as like said before still learning about this and my wheel guy just says he'll set it to what I want.
SPC Lower Control Arms(Old and New) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 07-10-2017 09:58 PM
Is there a need for 400$ lower control arms ? Simon99 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 41 09-11-2015 01:04 PM
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
Lower Control Arms iLaw Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 01-26-2015 06:33 PM
WTB: SPC LCA (Lower Control Arms) AG3NT_5CARFAC3 Want-To-Buy Requests 9 02-19-2014 01:30 PM
