Old 08-11-2015, 06:27 PM   #407
Shit Luck
Drives: red frs
Originally Posted by sales@delicioustuning.com View Post
Keith,
Did you happen to fix those injector harnesses that you were popping codes for a couple months back when we last spoke?
Sincerely,
Zach
Yeah I only had that issue that one time. I did however make new injector harnesses just in case. I bought the pro upgrade so that I could get tuned locally but I have to wait till they can get me in. I really want to run some autocrosses. Sick of the car sitting here doing nothing.
Shit Luck is offline   Reply With Quote
Old 08-11-2015, 06:32 PM   #408
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Good that you made new harnesses, those will throw the car into limp mode at a moments notice as I'm sure you experienced. Give me a little bit, and I'll email you to catch up and see about getting you an update in the meantime while you wait.
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Shit Luck (08-11-2015)
Old 08-15-2015, 02:52 AM   #409
Shit Luck
Drives: red frs
Took her out for a drive tonight and randomly popped p0441 code... I am using ebcs though. Anybody know what causes this one randomly.
Old 08-15-2015, 09:33 AM   #410
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
That's an evap code. The ecbs plugs into the evap port, so I'm guessing your tune didn't disable 0441
Just a guess tho
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 08-15-2015, 04:59 PM   #411
Shit Luck
Drives: red frs
What the actual cause of the code?
Old 08-15-2015, 05:02 PM   #412
protpibe
protpibe's Avatar
You have to unplug the Evap solenoid to connect the ECBS
Old 08-15-2015, 05:07 PM   #413
Shit Luck
Drives: red frs
Yeah, but if the boost solenoid is functioning off the signal for the evap solenoid what actually causes it to throw a code? The evap solenoid should be seen as functioning by the ECU since the signal is being used by the ebcs.
Old 08-17-2015, 01:15 AM   #414
Jhood
Jhood's Avatar
Drives: 2014 BRZ Limited [6MT/SWP]
I'm gonna take a guess and say that the ECU is probably looking for more than just a "yes or no" whether the signal is being used or not, considering that the EVAP solenoid controls when to purge and when not to, and now without power it's staying closed... but like I said I could be completely wrong.
But as for the code, my car threw the same one because of the crank case vent hose (under the A/C) not being tapped back into the intake like it was from the factory, as the FBM kit does not come with an intake bung of any kind. They disabled it in the tune and its been good.
|FBM Stage 1 Build|GTX2867R|
|Moto-East Flex Fuel & Dyno Tune|
|360whp / 265tq (E81 @ 12psi)|
Jhood is offline   Reply With Quote
Old 08-18-2015, 07:36 AM   #415
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Good morning @sales@delicioustuning.com ! My car goes in next week for an EFR install. A couple quick questions before I request a F&G tune later this week:
1. You recommended I source a Bosch 3Bar MAP like used in the Cosworth kit. I can not find anything of the sort. Should I just go with a Omni 3Bar unit or similar since they are easier for me to find? Whats the DeliciousTuning 26psi MAP sensor? Is that just a Honda unit?
2. Fueling. Im currently on Delicious Tuning FFBT kit and typically run e85. What should I be looking for on stock injectors/pump? 10psi max? I dont know what the stock components are capable of. Im not trying to max them out, I would just like to know what you recommend I do or if an upgrade is required to run say 16psi. (pump/injectors are more than likely a spring 2016 upgrade)
3. Just to verify, Im sure my installer knows this, But the Pierburg EBCS on the EFR connects to the evap solenoid connector correct? That's the connector the F&G tune uses to control the EBCS? Amiright?
Thanks!
xkalelx is offline   Reply With Quote
Old 08-18-2015, 02:20 PM   #416
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
What's the lead time to receive the update once email requesting it sent and received? Sent request 8/1/15. Also sent you a pm with some requests/notes. @sales@delicioustuning.com
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-18-2015, 03:23 PM   #417
DeliciousTuning
Originally Posted by xkalelx View Post
Good morning Zach! My car goes in next week for an EFR install. A couple quick questions before I request a F&G tune later this week:
Thanks!
1) If the Bosch 3 BAR is not available to you; an OMNI 3 bar will do alright. We've refined our scaling for these beyond what EcuTek's recommended settings, and are much happier with them now.
2) The stock fuel pump and injectors can handle MAYBE 8-9psi on E85. If you're going for 16psi, you'll definitely want to upgrade the pump to something like a DW300c or AEM pump and around 700cc on injectors.
3) The Pierburg EBCS SHOULD plug into the same CPC connector that most other kits use. The last EFR turbo kit we laid hands on was awhile ago, and my memory of it isn't vivid enough to confirm or deny whether that was the case.
Sincerely,
Zach
Old 08-18-2015, 03:24 PM   #418
DeliciousTuning
Hey Yomny,
Normally updates like these are pretty quick. These are taking a bit longer because we're updating a little over a hundred people at a time in the midst of ongoing orders and releasing new products.
Sincerely,
Zach
Old 08-26-2015, 06:12 PM   #419
fasteddy
I am curious if you guys have run the flash-n-go with the high boost pulley on the Jackson Racing Supercharger?
Your tune might be the perfect option for those of us not near a good tuner.
I would love to see your results/dynos on this!
Thanks
Pat
fasteddy is offline   Reply With Quote
Old 08-26-2015, 06:45 PM   #420
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Are there any plans to support the coming Edelbrock SC?
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Most *fun* forced induction bfrank1972 Forced Induction 45 12-22-2016 11:36 AM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Announcements, Contests, Giveaways 115 02-28-2014 12:38 PM
February Sale. All Delicious Tuning e-tunes are 10% off!!! Infamous Performance Announcements, Contests, Giveaways 19 02-28-2014 12:37 PM
Infamous Performance is now offering dyno tunes by Delicious Tuning!!! Infamous Performance Forced Induction 107 02-13-2014 11:36 AM
