Old 08-13-2015, 01:13 AM   #29
@timmydatooth did you get this figured out yet?
Nice job. You scared off another one.
Old 08-13-2015, 01:21 AM   #30
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Instead of tapping into the turn signals, you could connect the red power wire to either the fuse box, or pull it all the way into the cabin, which is how I did it. This guide is pretty comprehensive.
http://www.ft86club.com/forums/showt...738#post701738
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
Tcoat (08-13-2015)
Old 08-13-2015, 01:31 AM   #31
aegisdrgn
aegisdrgn's Avatar
Originally Posted by Chaetagnath View Post
Probably want to double check with a voltmeter, but I am pretty sure red is turn signal, green is parking light, and black is the ground for both.
Or, if you really want it on only when your parking light is on...Chaetagnath's got your back. Tap into the green.
Another person's done it as well:
http://www.ft86club.com/forums/showp...9&postcount=69
Tcoat (08-13-2015)
Old 08-13-2015, 07:33 AM   #32
Just didn't want the poor guy blowing something by hooking into random wires. I knew somebody that actually knows how to do it would eventually reply if he was just patient enough to wait for the answer.
Old 08-13-2015, 11:35 AM   #33
timmydatooth
Drives: Scion Frs
So i tried to do that. But for the life of me i couldnt figure out how to get the t-taps that cane with the kit to work. I put both wires in and closed the t-tap all the way until it clicked. Leds did not turn on. I took the t-tap off and it didnt even look like it cut through the wire. Am i doing it right?
timmydatooth is offline   Reply With Quote
Old 08-13-2015, 12:08 PM   #34
Max FRS
Drives: 2015 Halo FRS Automatic
T-Taps are size specific meaning if you use a 10/12 t-tap on a 14 gauge wire, the t-tap will be too large to cut through the rubber insulator. Most of those wires are probably in the 18-22 gauge range so you need a t-tap that size.
Max FRS is offline   Reply With Quote
Old 08-13-2015, 12:19 PM   #35
timmydatooth
Drives: Scion Frs
Damn that sucks. Ill upload a pic of what they look like when i get home. Is there an easier way to tap into a wire besides the ttaps?
Old 08-14-2015, 08:29 PM   #36
timmydatooth
Drives: Scion Frs
I got those suckers installed FINALLY! Thanks to everyone on this thread who helped out. Couldnt have done it without you guys. Lol i owe all of you a beer! Cheers!
Old 08-14-2015, 08:35 PM   #37
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
Very nice! Good job! What did you learn about the wiring color scheme?
wireman957 is offline   Reply With Quote
The Following User Says Thank You to wireman957 For This Useful Post:
timmydatooth (08-14-2015)
Old 08-14-2015, 08:40 PM   #38
aegisdrgn
aegisdrgn's Avatar
Nice! Congrats and enjoy!
Sent from my HTC One using Tapatalk
Old 08-14-2015, 08:58 PM   #39
Hotrodheart
Hotrodheart's Avatar
Just don't let @Tcoat do your wiring....
Hotrodheart is offline   Reply With Quote
The Following User Says Thank You to Hotrodheart For This Useful Post:
DAEMANO (08-17-2015)
Old 08-14-2015, 09:15 PM   #40
timmydatooth
Drives: Scion Frs
I just went with what other people were suggesting saying green is the power wire. Double checked at the auto store they let me use a volt meter.
Old 08-14-2015, 09:20 PM   #41
timmydatooth
Drives: Scion Frs
I got chills when I saw this pic…I know it will haunt me in my sleep. lol that poor twin...
Old 08-14-2015, 10:10 PM   #42
And that my friend is why we were all so adamant that you not just guess but check it.
That one was a bad tune back in the early days but the potential was there if wired wrong.
timmydatooth (08-14-2015), Ultramaroon (08-15-2015)
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 01:34 PM
Wiring in IAT for SD mrk1 Software Tuning 13 04-14-2023 09:15 AM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 02:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 09:24 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 02:02 PM
