Old 08-13-2015, 12:33 AM   #113
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Sleepless View Post
Mine was even beforehand, so, no.
What's your build date? MY2014, I presume? This was after Fuji Heavy upgraded the subframe bolts I'm guessing.
Intent > Content
Old 08-13-2015, 08:22 PM   #114
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Yes, MY2014. Bought it last Feb.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
solidONE (08-14-2015)
Old 08-14-2015, 02:03 AM   #115
GT86_PRAGUE
Drives: GT86
So, do they really works?
GT86_PRAGUE is offline   Reply With Quote
Old 08-14-2015, 03:37 AM   #116
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Theys works fors the spoons bottoms lines.
Old 08-14-2015, 04:38 AM   #117
juliog
juliog's Avatar
Drives: 86
The collars are magical. They turn the FR-S struts into double wishbones.
juliog is offline   Reply With Quote
Old 08-14-2015, 07:44 AM   #118
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Yes
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-14-2015, 08:00 AM   #119
GT86_PRAGUE
Drives: GT86
I have some concerns. Also I have almost all bushings from Whiteline and some more stuff to sharpen my handling and I have doubts I will see a change after collars installed. Any of you guys who has collars and HEAVY changes in other suspension parts see this mod worth the money?
Old 08-14-2015, 08:01 AM   #120
tonystewart
Yes, my signature lists upgrades
Old 08-14-2015, 10:31 AM   #121
GT86_PRAGUE
Drives: GT86
Yep, you listed Whiteline. That doesnt say much, same for your other stuff, it looks a little bit messy for my taste (no fens). And from the mods you have I would say your priorities are elsewhere, again, no fens.
How would you describe difference after installing them?
Old 08-14-2015, 10:38 AM   #122
GT86_PRAGUE
Drives: GT86
Last edited by GT86_PRAGUE; 08-14-2015 at 10:42 AM. Reason: Dupe post due to network error
Old 08-14-2015, 11:41 AM   #123
tonystewart
Nebuď takový pyj, můžete příměstské polština
Rigid collars changed the jounce
Current Suspension components
Whiteline
KCA434 & 435
KDT922 & 926
Koni
8641 1559 Front Inserts
8041 1416 Rear Spring Dampners
HVT
Front Camber Plates 810TM-FT86
Swift Springs
4F912
GT Spec LCA 1473
SPC Adjustable Toe Arms
Old 08-14-2015, 11:56 AM   #124
Nigelr32
Drives: '14 GT86 project, '13 GT86 DD
Originally Posted by KoolBRZ View Post
Those bolts would help take up the slop in the holes, but they don't address the uneven mating surfaces between the body and the top plate of the subframe bushings as well as the support arm to body connections. These surfaces aren't planed flat nor are they perfectly parallel. The rigid collar's cone actually helps support the bolts, and prevent shearing, while the washers actually lock the mating surfaces together.
Uneven mating faces?? The body is a pressed steel welded construction that is built on a jig. Every assembly in the world requires tolerance, hence the clearance on the holes.
The bolts on the rear subframe pull up through machined steel tubes mounted in rubber bushes. Any angular misalignment of the mating faces is taken up by this rubber. Even if you fit uprated bushes, the bolts will still pull the bush square with the body, and the rigid collar will squash evenly, giving the same result.
As for the front subframe.. how on earth can a solidly bolted component, being removed and bolted solidly back into place with what is no more than an aluminium washer improve ride or jounce??? in fact, I would say that shock loads through the stock assembly are less likely to move anything if they don't have an aluminium washer in place??
Nigelr32 is offline   Reply With Quote
Old 08-14-2015, 12:05 PM   #125
tonystewart
I wish I could answer that question with data, but when three individuals, who are regular passengers in the car, notice an improvement in ride quality, that's no coincidence.
I'm trying to find some for my other Toyota cars
No one is forcing anyone to buy these rigid collars
The Following 2 Users Say Thank You to tonystewart For This Useful Post:
juliog (08-14-2015), mokinbird87 (11-02-2015)
Old 08-14-2015, 12:13 PM   #126
EAGLE5
Dismember
EAGLE5's Avatar
Not exactly a double-blind test. This screams snake oil. And KoolBRZ likes it.
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
tonystewart (08-14-2015), Travisty75 (08-17-2015)
Spoon GT86? c147258 Scion FR-S / Toyota 86 GT86 General Forum 67 04-27-2016 12:31 AM
No Spoon parts for the 86... twincamRob FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 81 06-02-2015 10:37 AM
Fs: brand new pbm subframe collars Guildjs Brakes, Suspension, Chassis 3 10-16-2014 08:54 AM
T1R Differential Collars Mikepage Engine, Exhaust, Transmission 0 05-01-2014 09:18 PM
