Old 08-08-2015, 12:59 AM   #141
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
50% boost at zero throttle?
Originally Posted by Sojhinn View Post
Need to look at the spread sheet for the Procede map. I'm not near a computer can you take a screen shot?
@KoolBRZ
Here it is. Look at the tiny ramp running down from the left-hand corner of 0 at 0.
KoolBRZ is offline   Reply With Quote
Old 08-08-2015, 02:40 AM   #142
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
If I remember correctly that is so you can test the esc without the engine being on.
Installed Mods:
Old 08-08-2015, 02:47 AM   #143
KoolBRZ
KoolBRZ's Avatar
That explanation has no flair, no excitement. How about "That's for quicker starts in cold weather. The heat of compression makes the car start faster. This car's so quick, it even has a supercharged startup routine." That sounds a lot better.
Old 08-08-2015, 10:10 AM   #144
Sojhinn
Sojhinn's Avatar
That's my teacher side coming out. I take extremely complicated things and I have to make it as simple as possible for people to understand.
Also I was on a date with the wife and I didn't want to get in trouble.
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
LucidMomentum (08-08-2015)
Old 08-14-2015, 02:22 AM   #145
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
Alright, I have an issue, and it may be pretty deadly if true.
My wheel shop installed longer studs. Immediately after, I got cel/abs/trac and limp mode. Cleared, came back - they figure they screwed a speed or abs sensor.
Off to the dealer, so removed the phantom, and put the stock intake back. Left the batteries, chargers (unplugged) and the procede controller (with no phantom to spool)
Not trying to hide it, just avoid hassles and some excessive joy rides (I have cameras). Tire shop was going to pay for the sensor repair/replacement.
Anyway, they screwed around with it and somehow cut the ground to the Procede controller. All of a sudden the car was throttle on, throttle off, on, off - sitting in the bay. I have it on video.
On what planet would you have a controller that can actually actively engage the throttle? That would be so dangerous and wreckless I cannot believe it's possible. Or even to block the throttle signal. I know it has taps to MONITOR the throttle position, etc - but how on earth can it send throttle signals to the CAR? The thing should DO NOTHING if there's no phantom in the car.
Now maybe the techs are lying, but to what end? There were 3 of them, and they said that after the redid the ground wire/connect for the Procede the crazy throttle on-off stopped immediately. And I also haven't been able to get the check engine/speed sensor code to come back either....
It's supposed to be nothing more than a fancy engage switch for the Phantom. Nothing else. Right?
Khyron686 is offline   Reply With Quote
The Following User Says Thank You to Khyron686 For This Useful Post:
keen as (08-14-2015)
Old 08-14-2015, 04:33 AM   #146
DAEMANO
Time Traveller
Can you clear something up real quick, cause by reading above I'm kind of confused. You said you have it on video, and then later you said "maybe the techs are lying". Wouldn't the techs story be easy to confirm with the video?
Old 08-14-2015, 11:02 AM   #147
Khyron686
In-car dash cam. I have snippets throughout the day but not a full all-day recording. I just mean it wasn't like they backed it off the lift and were just making crap up to cover up.
I have a clip where you can see the car reving up and down and you can hear them saying "wtf is going on" and "We need to re-hook up that box". But there's a 2 hr gap where they opened the dash that I have nothing - I don't know for sure which wire they cut, only that they were stuck because the car was not running properly at all (and it was when I dropped it off)
I have one part where the senior tech explains that it intercepts the throttle signal and uses that to control the "POS electric supercharger" and "should tell the owner to come get it with a tow truck".
The point I really can't understand is the code really hasn't come back since they re-did the ground. I'm still leaving it stock program, no ESC. Next step is I'M going to remove the ground and see what happens.
But I really really want reassurance that some aftermarket boost controller can't actively block or activate the throttle while I'm driving up to a crosswalk with kids in it.
DAEMANO (08-14-2015)
Old 08-14-2015, 11:49 AM   #148
KoolBRZ
KoolBRZ's Avatar
The Procede controller started as a signal intercepter tuning box, (ala Unichip?) and had no ground, so the power was flowing backwards through the circuitry to the throttle connection. It shouldn't be too hard to add one-way diodes to the throttle and RPM taps. The only question is, would it still work with the diodes installed? @Shiv@Openflash could diodes be used here without impeding the function of the taps?
Old 08-14-2015, 12:06 PM   #149
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Well it wouldn't be the first time techs lied about something they don't know about...
However, the Procede doesn't intercept any signal, rather it reads the signal at the same time the ECU reads it. It does read throttle position, so it might be plausible that if it was wired improperly and lacking a ground, you could get signal noise and feedback that may cause the issue.
But that's like telling people not grounding a live wire can cause issues. It's kind of a given.
TL : DR; It could be possible given that we tap into the ECU to get signal readings, but of course anything's possible if you cut wires and aren't paying attention.
Yeah what he said.
Old 08-14-2015, 12:16 PM   #150
KoolBRZ
KoolBRZ's Avatar
I think the real unsaid questions in everyone's mind is "Can the Procede controller take this kind of abuse, and still work right when it's connected back up properly? Or did this stupid tech break the controller as well?"
Old 08-14-2015, 12:50 PM   #151
DAEMANO
Time Traveller
Additionally, I would want to know why his mechanics were working on anything electrical in the car without first disconnecting the battery. That seems kind of rank amateur.
Old 08-14-2015, 01:12 PM   #152
Sojhinn
Sojhinn's Avatar
I'm trying to figure out how they screwed a sensor while installing studs...
Installed Mods:
Old 08-14-2015, 01:46 PM   #153
Sojhinn
Sojhinn's Avatar
PROcede ESC User Software!
Is it possible they cut the wire and then the wire was grounding out?
@Khyron686
Installed Mods:
Old 08-14-2015, 01:52 PM   #154
Khyron686
Actually THAT is apparently somewhat more common - you have to drop the entire hub to get them in on the rear. Let them drop or hang and can wreck the wire. Fronts - I think they took the hub off as well to use a press and the wire for the sensor is very very short.
Battery may have been disconnected (hence no video).
But again, I'm all for aftermarket toys and gizmos but nothing should be able to either kill or send throttle signals. Or the brakes either.
What does your user name mean? Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 355 05-01-2016 08:52 AM
OFT: New firmware and new user software Shiv@Openflash Software Tuning 9 10-15-2014 02:45 PM
EcuTek End User/Retail Tuning Software Release! Dustin@Dynosty Forced Induction 27 12-19-2013 09:17 AM
user tags scottmcphee Site Announcements / Questions / Issues 3 04-11-2013 03:15 PM
User name trueno86power Site Announcements / Questions / Issues 7 11-28-2012 12:48 AM
